Migrating to ZwaveJS2MQTT, trying to setup KeyMaster per the documentation. I have Schlage BE469ZP deadbolts. While I have 16 entities for the lock, I don’t see a user code sensor or access control sensor. The entities I have are:
Thanks for making this great integration, it seems like exactly what I’m looking for to manage the pins on my locks.
I’ve been trying to set it up and while I’ve run into a few hurdles along the way I’ve managed to sort most of them out so far, however I’ve gotten a bit blocked and I’m not sure what’s wrong now. What’s happening is that all the pin statuses are always “Adding” or “Deleting” rather than “Added” or “Deleted”. I checked the locks and confirmed that there doesn’t seem to have been any changes to the codes as far as I can tell, it seems like they aren’t communicating. I saw this section in the wiki Troubleshooting · FutureTense/keymaster Wiki · GitHub but it hasn’t seemed to resolve itself.
I am having the exact same issue with it hanging on “Adding”.
I am using a Yale YRD216 lock. The only thing I noticed was that when pairing it through Z-wave, it failed secure enrollment. It still added it, so I simply continued. I wonder if this is causing the problem?
IIRC S0 means it wasn’t securely added but I didn’t see a separate option to secure add in Zwave JS like in the old Zwave integration. I assume ZwaveJS supports secure inclusion if others have gotten it working though, is there something special that needs to be done here?
Just got it to add securely. I think distance was my original problem. I’ll likely permanently resolve it with a repeater, but for now, the HA instance is a few feet away. My debugging logs look a lot more promising, but now, codes are stuck on “deleting”.
I think I need to wipe the slate clean and start fresh
You may be alright now that you have successfully paired the lock securely. I know that the Kwikset lock has a ‘whisper’ function used during pairing to reduce the risk of someone outside intercepting your pairing. Once I synced my locks by having the hub closeby, I was able to move it back where it was in my data closet. Not sure if this is also true for your particular lock.
Just wanted to close the loop with my issue. Once I moved the HA box closer and re-paired the lock, it securely enrolled. I was then able to re-add the integration and everything worked as it should.
I’m circling back around to this again, I’m curious what security level is require for this to work. With the S0 Legacy security it still doesn’t seem to be working for me.
