Yes comment them out.
Ok, itâs been a couple days and Iâm still struggling. I attempted to comment those sections of code out per your advice, but I started receiving the error âlock_manager.ini file incomplete or missingâ when running ./setup.sh. I completely wiped out my install and started from scratch and reinstalled everything. Still get stuck at the same problem. I can control the lock using the automatically generated entities, but the lockmanager code doesnât send anything over zwave. It appears to be dead code. I do have a couple errors that may be relevent. See below.
2020-05-14 17:26:21 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-05-14 17:26:42 WARNING (MainThread) [homeassistant.setup] Setup of input_datetime is taking over 10 seconds.
2020-05-14 17:26:42 WARNING (MainThread) [homeassistant.setup] Setup of updater is taking over 10 seconds.
2020-05-14 17:26:42 WARNING (MainThread) [homeassistant.setup] Setup of input_boolean is taking over 10 seconds.
2020-05-14 17:26:42 WARNING (MainThread) [homeassistant.setup] Setup of input_text is taking over 10 seconds.
2020-05-14 17:26:42 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2020-05-14 17:26:55 WARNING (MainThread) [homeassistant.setup] Setup of hacs is taking over 10 seconds.
2020-05-14 17:26:58 WARNING (MainThread) [hacs] Configuration option âthemeâ is deprecated and you should remove it from your configuration, HACS will know if you use âthemeâ in your Home Assistant configuration, this option will be removed in a future release.
2020-05-14 17:30:52 WARNING (MainThread) [aiohttp.websocket] websocket connection is closing.
2020-05-14 17:30:55 WARNING (MainThread) [hacs.deprecated] The â/community_plugin/â is deprecated and will be removed in an upcoming version of HACS, it has been replaced by '/hacsfiles/â, if you use the UI to manage your lovelace configuration, you can update this by going to the settings tab in HACS, if you use YAML to manage your lovelace configuration, you manually need to replace the URL in your resources.
2020-05-14 17:30:55 ERROR (MainThread) [hacs] Tried to serve up â/config/www/community/lovelace-card-mod/card-mod.jsâ but it does not exist
I honestly donât know why it isnât sending z-wave commands. Hopefully someone else can help with that. I do see
which is a starting point. Try removing and re-installing it card-mod in HACS, perhaps?
Yep, you are correct. A reinstall fixed that card-mod. Still experiencing no traffic when adjusting settings in lock manager.
I didnât do any of the âAdditional Setup (Optional, but strongly reccomened)â steps. Is there anything in this that must be present for this to work? I chose not to attempt these until I had a working lock manager since this might just complicate thingsâŚ
They might be worth doing. Since that optional stuff is for monitoring when the z-wave network is ready, itâs probably worth doing, just to see if it makes a difference. Perhaps itâs not really so optional. Someone with time to go through the code would have to say for sure though.
Yes I had issues till I did the optional settings.
Ok, started trying the optional settings. Not sure Iâm putting the code in the correct places since Iâm getting the following errors:
Error loading /config/configuration.yaml: while parsing a block collection
in â/config/automations.yamlâ, line 1, column 1
expected , but found â?â
in â/config/automations.yamlâ, line 23, column 1
I pasted input_booleans and binary_sensor into configuration.yaml. I pasted the the rest of the code (startup, cleanup and custom cleanup) into automations.ymal. Where am I going wrong?
Without seeing automations.yaml, configuration.yaml, and the scripts, itâs hard to say whatâs wrong. Hereâs the relevant code from my setup:
configuration.yaml
binary_sensor: !include binary_sensor.yaml
input_boolean: !include input_boolean.yaml
script: !include scripts.yaml
homeassistant:
input_boolean.yaml
#Used for the garage side door lock
#https://community.home-assistant.io/t/simplified-zwave-lock-manager-update/166419/24
#https://github.com/FutureTense/lock-manager/blob/4c8adaebcb0a2b0412ae71c5952538f433dae084/FrontDoor.ini
allow_automation_execution:
name: 'Garage Side Door Lock Add-in Automation Block'
system_ready:
initial: off
binary_sensor
sensors:
allow_automation:
friendly_name: "Allow Automation"
value_template: "{{ is_state('input_boolean.allow_automation_execution', 'on') }}"
system_ready:
friendly_name: "System ready"
value_template: "{{ is_state('input_boolean.system_ready', 'on') }}"
device_class: moving
automations.yaml (added through the web UI)
- id: '1588459516157'
alias: homeassistant start-up
description: ''
- event: start
platform: homeassistant
condition: []
- data: {}
entity_id: script.1588459432325
service: script.turn_on
- id: '1588459691457'
alias: Zwave_loaded_Start_System
description: ''
- event_data: {}
event_type: zwave.network_ready
platform: event
- event_data: {}
event_type: zwave.network_complete
platform: event
- event_data: {}
event_type: zwave.network_complete_some_dead
platform: event
condition: []
- data: {}
entity_id: script.1588459315583
scripts.yaml (added from the web UI)
'1588459315583':
alias: system_cleanup
sequence:
- data: {}
entity_id: input_boolean.system_ready
service: input_boolean.turn_on
- data: {}
entity_id: input_boolean.allow_automation_execution
'1588459432325':
alias: customstartup
sequence:
- data: {}
Thanks for your files. That helped immensely and I fixed several errors based on it. Iâm not sure how to use the UI to add script and automation. What do I select for Action type? I notice you have several entity IDs in your automation.yaml. Does this refer to a device? If so, what device am I selecting for each of these items? Where do you find these and what is it referring to? This isnât clear to the novice in the github directions.
The line - id: â1588459516157â not an entity id, it seems to be an ID number of the automation. The scripts also have an ID when you do them from the web UI.
Automation action type will be âcall serviceâ, service is âscript.turn_onâ, and the name is whatever name you gave the script. If you do it and youâre not sure, you can save it, then select âedit as YAMLâ to compare it to mine and then play around with that until you get it. Once you have it all done, restart HA, watch for you z-wave network to be ready, then check the automations âlast triggeredâ to see if they fired. If they fired, check the state of your booleans and binary sensors to make sure everything is communicating.
Ok, I got to be really close now. My files are looking more like yours now. I Still have the following error, but I donât understand the message
Invalid config for [input_boolean]: invalid slug input_boolean.system_ready (try input_boolean_system_ready) for dictionary value @ data[âinput_booleanâ]. Got OrderedDict([(âallow_automation_executionâ, OrderedDict([(ânameâ, âAllow Automationâ), (âinitialâ, False)])), (âinput_boolean.system_readyâ, OrderedDict([(ânameâ, âSystem Readyâ), (âinitialâ, False)])), (ânotify_frontdoor_1â, OrderedDict([(ânameâ, âNotificationsâ)])), (âdaterange_frontdoor_1â, OrderedDict([(ânameâ, âUse Date Rangeâ)])), (âsmtwtfs_frontdoor_1â, OrderedDict([(ânameâ, âUse SMTWTFSâ)])), (âenabled_frontdoor_1â, OrderedDict([(ânameâ, âEnabledâ)])), (âaccesslimit_frontdoor_1â, Orde⌠(See /config/configuration.yaml, line 17).
Config.yaml
Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: example.duckdns.org:8123
Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
scene: !include scenes.yaml
input_boolean: !include input_boolean.yamlhacs:
token: !secret HACS_github
appdaemon: true
theme: truehomeassistant:
packages: !include_dir_named packageszwave:
usb_path: /dev/ttyACM0
Scripts.yaml:
â1589578080898â:
sequence:
- data: {}
service: input_boolean.turn_on- data: {}
â1589580122412â:
sequence:- data: {}
service: automation.turn_on- device_id: ââ
domain: ââ
entity_id: ââ
Automations.yaml
- id: â1589577285592â
alias: HomeAssistant Start-Up
description: Lock Manager Startup Script
- event: start
condition:
action:- entity_id: script.customstartup
service: script.turn_on- id: â1589578886811â
description: Home Assistant Start-Up Automation
- event: start
condition:
action:- data: {}
service: script.turn_on- id: â1589579154920â
description: ââ
- event_data: {}
platform: event- event_data: {}
platform: event
condition:
action:- data: {}
entity_id: script.1589578080898
Binary_sensor.yaml:
sensors:
/FrontDoor.ini
allow_automation:
friendly_name: âAllow Automationâ
value_template: â{{ is_state(âinput_boolean.allow_automation_executionâ, âonâ) }}â
system_ready:
friendly_name: âSystem readyâ
value_template: â{{ is_state(âinput_boolean.system_readyâ, âonâ) }}â
input_boolean.yaml:
initial: offinput_boolean.system_ready:
initial: off
You have a problem with the naming of your system_ready input_boolean. Compare it to allow_automation_execution and youâll figure it out, Iâm sure. The rest of it I canât help you with though. I canât read it (point 11 How to help us help you - or How to ask a good question).
Kevin,
Thanks for the help! I very much appreciate your time and knowledge. After you cued me into the issue, the log message started to make more sense. I went through all of the code again and didnât see an issue. But the log suggested a fix which worked (at least in partâŚ) I changed input_boolean.system_ready from the GitHub instructions to input_boolean_system_ready. Upon doing a check config, I got the lovely green check mark.
Results:
Now the interface works when I change the code and enable the code slot 9. I see messaging over the zwave log when I manipulate all of the basic functions of each slot.
Issues:
- Slot 1 which has a previously programed code will not change when a new code is input in HA. I do see traffic going over Z-Wave. I need to continue to digest the messages to attempt to figure out for myself.
- When disabling a slot, I see traffic going over the zwave network. However, the previous code continues to function.
- I have not attempted the advanced settings yet because the basic settings are still not fully functional. Therefore, I donât expect time limiting to work since I canât disable codes anyway.
So my questions are as follows:
Is there a problem in the directions on GitHub or did I make a mistake somewhere else? I assume that the answer is that I screwed something up somewhere. With that, here is my assesment:
a) I still donât understand how the âinput_boolean_system_readyâ is being called, so Iâm not sure where to start troubleshooting. The only place I see it aside from input_boolean.yaml is in binary_sensor and in Scripts.yaml. In both of those files, the trouble script is defined as âinput_boolean.system_readyâ as defined in the GitHub instructions. -
Based on the above analysis, Should I try to rename every instance of this entity_id to input_boolean_system_ready? Or is there another place issue that Iâm missing?
I remember reading in an above post someone else struggling with the reset issue, but it was more of a bug as my memory serves. I will go back to that post and reread, but is there something else in a previous post that i may have missed that can clue me in?
Again, thanks for all the help! Iâm new to HA and it will take me a minute to understand how the file structure and code works. Iâve never been a great coder and it definitely takes me a bit of time to understand whatâs going on.
Here are a couple more observations:
- When setting a code to slot 1 which has a previous code set from the lockâs keypad, I get the following messages in the zwave log:
a) Received user code report from node 2 for user code 1 (Not Available).
Note: I donât get this message when conducting the same operation on an unused slot (Slot 9 in my case)
b) Received User Code Report from node 2 for User Code 1 (Occupied)
c) Node0002, Notification: ValuseChanged
Note: my lock is Node 2.
I think the issue is that the lock is refusing to accept an external code because that slot has a code input in it already which was set at the lock itself. Iâm wondering if a factory reset on the lock will fix this. I will try that in the next couple days and report back. For now, I want to get the rest of the system working and I canât lock my family out of the house. I donât trust my HA and coding skills enough to make that leap.
EDIT: I found a post above that talks about one of my issues. Codes programed using the keypad will not show up in HA. You have to remove those codes on the lock and reprogram them in HA. I will do a factory reset on my lock in the next couple days and confirm this.
EDIT: I again pored through my code and searched this topic. I think my issue is the same as crzykidd.
@crzykidd I updated the project with several things related to that problem you had with the missing input_boolean that prevented the automations from firing. If you are getting lots of notifications upon booting HA, you will want to add the entitites and code I put in README.MD
I added all this and it works great. I even added: binary_sensor.system_ready to the badges for the lock page. The only issue is the docs on the name as referenced in the post above
Iâm had the same System_Ready configuration error and I canât get the code to randomize when disabled. Can you tell me what your fix was? I donât see the resolution in your posts above. Was it just the name change of System_Ready in binary_sensors? When I made this change, my check config got the green check, but it did not fix my disable code issue.
EDIT 3:
After a couple more days of troubleshooting, I deleted all the optional code and started again. I may have found an error in how I input the code the first time. When attempting to create the automation
Zwave_loaded_Start_System, the event type doesnât auto populate like the other automatons did. I think when I ran into this issue before, I manually entered them using the editor. Is this normal behavior? Is something missing from my configuration that would prevent this form auto-populating? I donât remember creating any other zwave references like we do for the homeassistant start-up automation⌠Can anyone point me in the right direction?
You are 100% correct. This is mandantory code to make the Lock Manager communicate with the lock. Everything up to this point was focusing on creating the interface. The âOptional Codeâ appears to focuses on translating the GUI to zwave messages and setting the correct conditions on startup. I didnât see any log traffic until I implemented the optional code.
I recommend that the GitHub directions be modified so that it doesnât indicate that this code is âoptionalâ⌠To a novice like myself, it sends the wrong message.
Thatâs not really the point. This code is used to prevent Automations from firing when Home Assistant is first loading. Without it you will get all sorts of notifications that are reporting states instead of events. I called it âOptionalâ because when Iâm restarting HA a dozen times an hour I get annoyed with the constant notification sounds.
Now that I think about it, 90% of my development is to fix a problem that annoys me.
Ok folks, Iâm back. Sorry for the long hiatus. No, the virus didnât get me.
Anyone care to update me on anything that might need my attention? The last problem I remembered was an issue with the setup script not working for some people. However one of you smart folks debugged it and discovered that gawk wasnât installed for those people. I updated the README to reflect this.
I havenât made any changes to the package, but if you have any improvements or fixes you think I should add, throw them at me. Iâm glad to see that there are several forks!
@FutureTense - I have a quick question about the way you show that a code is loaded or not. I believe you turn on/off an input boolean after a code is added/removed, right? Iâm finding that occasionally that codes fail to load due to zwave issues. I will say that most of the time when that happens it when Iâm adding and deleting codes quickly when Iâm testing things. I was thinking that it would be cool to really get a true update from zwave to know that the code really loaded. Maybe the new openzwave 1.6 will have a bit more reporting capabilities.
Are you referring to the Status field where it says Connected/Disconnected?
