Please see the wiki.
you need to add this to your configuration.yaml and restart:
packages: !include_dir_named packages/
So has anyone else had issues with the code slots flooding the zwave network?
I have not, are you using zwave
or ozw
I believe zwave - iâve originally set up zwave network a few years ago, so using HA i believe that means zwave, even though the log is called OZW_log.txt.
I was able to get proper connectivity. The app showed 3 codes which were configured on the device and i experimented with a 4th. had 6 codes setup total, for future use-cases.
Upon home assistant restart the zwave network would never start. I could see in OZW log that it appeared to start properly, no errors, but then i could see that my door lock node was constantly flooding with resets on 5th and 6th codes. I also saw traffic for the 4 already set, too.
I completely removed lock-manager and all related files, restarted HA and zwave came up properly. I plan to retry and configure lock-manager again from scratch but wanted to check and make sure there wasnt a known issue in something i had done. I posted log snippets a few posts up, not sure if that is any help in debugging, though.
zwave
has issues with clearing codes, I want to say this is going to be an automation/script bug.
Likely related to this issue on github.
You can stop the script from freaking out the lock by turning off allow_automations
from dev-tools->States
yes, this is what i did originally. though with that off i figured the integration loses its usability. thanks for that info, though, ill follow that isue and see what else i can find
ah, also answered another issue i had in that thread about zwave startup not triggering automation binary
so if allow_automations is disabled, the integration becomes fairly neutered, correct? I suppose it can still be set to notify and manually disable/enable codes?
That is correct, it should only stop the automations that sync the codes.
One last thing, I seem to not be able to get notifications. I created the âfrontdoor_manual_notificationâ script, but it is not getting triggered. I dont really see how notifications are generated, honestly. any help there would be appreciated. Here is what i created:
frontdoor_manual_notify:
alias: frontdoor_manual_notify
sequence:
- service: notify.notify
title: '{{ title }}'
message: '{{ message }}'
mode: parallel
max: 10
You are missing the script frontdoor_manual_notify
which the package is expecting. Wherever you keep your scripts, add the following:
manual_notify:
sequence:
- condition: template
value_template: >-
{% set title_len = title|length %}
{% set message_len = message|length %}
{% if (title_len != 0 or message_len != 0) %}
true
{% else %}
false
{% endif %}
- service: notify.mikes_devices
data_template:
title: "{{title}}"
message: "{{message}}"
mode: parallel
sequence:
- service: script.manual_notify
data_template:
title: "{{ title }}"
message: "{{ message }}"
As you can see, frontdoor_manual_notify
calls manual_notify
. Each lock integration expects its own notification script. So you add one for each integration you use, and in turn just have it call the manual script. Notice the notify.mikes_devices
call? This is where you call whatever notification service you setup for your system.
As @FutureTense noted youâre missing a script, this is intentionally left out for you to create, we have an example in the wiki that you can use as a framework for a more complex notification.
Youâll need to adjust the notification parameters per the notification system youâre using. Not all use title
or message
they could be named something else, youâd have to check the integration.
from the Wiki it states this
Missing Sensors
If you are not seeing your User Code
, Access Control
, Alarm Type
, or Alarm Level
, please note in ozw
they are disabled by default as the preferred method is to use the Home Security
sensor. Enabling these sensors does not break anything and allows the automations to accurately process the lock information.
I am missing the sensors it just says to enable them but how? Sorry if its a dumb question its a Schlage connect lock with default zwave integrationâŚ
Your alarm_level and alarm_type sensors are right there, did you rename the entities?
Donât I need the set user code entities for this to work? I tried the lock code manager selecting the alarm type and alarm level in the integration but it doesnât seem to work.
Are you missing entities or missing the sensors? These are two widely different things.
If you are getting âmissing entitiesâ errors: Follow the wiki section
If you are missing alarm_type or alarm_level sensors: This section in the wiki
No Iâm not receiving any missing entities errors. The locks Lovelace card looks like it should and has all the entities created by your code. I just thought maybe my lock itself was missing entities but if alarm type and level are all I need thatâs probably not my problem. It just says connecting never connects and the user code pin shows as unavailable. I canât seem to get it to function.
