I had the same problem with pictures showing up. The documentation says to use picture: /local/picture_name.jpg in the known_devices.yaml but I could never get that to work.
The way it works for me is to use the customize area in the configuration.yaml NOT the known_devices.yaml and “entity_picture: /local/picture_name.jpg”. Maybe a documentation change is necessary to prevent more people from getting confused.
It seems there’s a few bugs with the known_devices.yaml. I (out of habit) always restart HA after every change. This does not solve the issue, as others have commented on above. I also noticed that the known_devices.yaml file duplicates a lot of device entries over (I am using the netgear platform for device discovery). So for some reason, it’s not properly reading entries, hence the need for doing it as I indicated above in the customize section with entity_picture
Worked for me, am using AOI installer. Using this to display a plot image on a custom panel. Creating the www then /local/myImage.png + HA restart did the trick.
I’m using hassbian on my raspberrypi2.
I found the python init script (looking for config, mapping of the /local path to ./www) in /srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/frontend/init.py
the www directory path you should create is /home/homeassistant/.homeassistant/www
Just somehow it is expecting the 1 under the hidden directory (same level as your configuration.yaml file) instead of the 1 relative to our home directory.
I’m using the All-in-One installer and this works for me:
Inside of /home/homeassistant/.homeassistant/www/ I have a file mbp.png. By default the www directory does not exist, however, you can simply create it with mkdir www from within the /home/homeassistant/.homeassistant/ directory after executing sudo su homeassistant if connected via ssh as the pi user.
Anyone any idea what the path is on my Synology docker installation? I tried to create a www directory in the homeassistant directory but that apears not to be the right path?
Assuming that you used the official home assistant docker image the path should be whichever folder on your Synology that you have set as /config in the docker gui
So if you have synology set up like this…
/volume1/your/folder : /config
The correct path should be…
/volume1/your/folder/www
Then images can be saved in this folder…
/volume1/your/folder/www/name_of_image.png
Edit: but in homeassistant configuration you would use…
So the installation directory is “/volume1/Shared/docker/homeassistant/”
So I created the www map as follows “/volume1/Shared/docker/homeassistant/www” and put the jpg inside it, but this is not working, what am I doing wrong? I tried a png and a jpg file neighter one of them are showing up.
Finally got it working by creating www directory under /config.
Mine installation is all in one installation (Hassbian). It does not has directory homeassistant/.homeassistant !!
Also it does not recognize Sudo command. Only can use hassio command.
Anyone can let me know if I need to run sudo command to do other installations !!
