WAF is going down significantly. Any help on the horizon? Otherwise I need look into this appdaemon thing. Learning a full new tool and programming language just to have blinds go up and down seems a pitty.
There is a ticket already for the KNX component already
UPDATE:
Heureka, I got a tip from one of the xnkx developers and created a workaround.
add to your knx:
section these lines to get the knx event fired to the hA event bus:
knx:
fire_event: true
fire_event_filter:
- "1/3/1-6" # Rolladen Ergeschoss Lang/Kurz Objekte
- "2/3/1-6" # Rolladen Obergeschoss Lang/Kurz Objekte
create the following automation
- alias: "fake position arbeiten down"
platform: event
event_type: knx_event
event_data:
address: '1/3/2'
data: 1
- service: knx.send
address: '1/3/7'
payload:
- 255
platform: event
event_data:
address: '1/3/2'
data: 0
- service: knx.send
address: '1/3/7'
payload:
- 0
I will see if I work on an appdaemon python script to do this more intelligent and derive the positions in between as well. I will keep you posted.
There is a follow up discussion going on here for a better solution which also creates positions between 0 and 100%.
