Hi guys,
I have make a intern script into te wiser, with a new object. Set the new object dpt into 13 and it works
Thanks for you help every one
Hi, I have the same setup as you.
iEM3155 → Wiser → HA.
I would like to know if you could help me get the data from iEM3155 (modbus) out on knx and into HA?
I have tried to get Voltage A-N sent out to a group address but it seems that Wiser sends the value in Hex but it must be in decimal? data type 14.4
Hi !
If you want to decode a DPT 14 payload to a sensor value, use type: 4byte_float
in your configuration.
