use the formatting as James86 used a few posts above
Thanks a lot,
Works like a charm, I believe that could be quite usefull for everyone that would like to skip IP Router device and have some kind of server that support IP Tunneling.
Simple and clean IP Tunneling to IP Routing!
Thanks a lot!
HI, i ran into this stupid error. I’m not able to change the configuration anymore. Doesn’t matter which config (YAML oder within the UI). Removing the add-on / resetting to default does not help.
Any ideas?
The changing the param on network part is ok.
I can not change the config part. It doesn’t matter which value i change.
you have not specified a USB device from the device dropdown and the HAOS validator thus is complaining, because it can’t find a device entry with the name “”. So just pick your USB interface in the device dropdown and the validation error should be gone
