It is worth checking the UI integrations first as the update might have imported your kodi integration already.
Either way delete the kodi integration yaml and restart. Then add the kodi integration back using the UI or edit the one that is already there to remove any _2 from entity ids.
Of course something else has happened but… what ?
Didn’t do anything else than deleting the kodi configuration yaml…
And as I’m running homeassistant on a docker (NAS), I’m… lost !
Thanks to all who contributed to this remote. I read through the posts multiple times to wrap my head around it, and eventually just started copying and pasting things, often incorrectly, until I was able to have 3 working remotes for my 3 Kodi installs. I toyed with the idea of implementing a selection box as suggested by @myle above, but for now I’ve basically just copied and pasted @tom_l’s code 3 times.
My Kodi instances are named “basement,” “bedroom,” and “firetv.” My configuration.yaml has this for scripts: script: !include scripts.yaml
I copied @tom_l’s code as edited by @GooseGoose to include the new kodi calls. I essentially pasted it 3 times into Notepad++. Then I used search and replace “lounge” to “basement” on the first set, as well as “media_player.kodi” to “media_player.kodi_basement” for the first set. The second and third sets were similar.
Then I pasted all 3 sets of script code into my previously empty scripts.yaml file. No need to have “script:” at the top as this is already accomplished in configuration.yaml. After saving and then Configuration > Server Controls > Reload Scripts, I showed numerous scripts available for the various Kodi instances.
I used HACS to install the button-card and hui-element mentioned above, and then restarted HA.
In my Lovelace Media dashboard, I opened the raw editor and pasted @tom_l’s button templates above. I copied @tom_l’s lovelace text into Notepad++ and created three versions, one for each Kodi instance. Then I created 3 entities cards, used the code editor, and pasted in the code for each one. I also added three media player cards. After some fiddling with the up/down buttons in the card editor, I was able to line it up so that each media player had its corresponding remote below it.
First of all thank you to everyone that helped on this as it is a great addition to an already great program.
Having gotten this to work I now am trying to make a couple of minor changes and was hoping someone here maybe could point me in the right direction as what I have tried didn’t work as intended.
I use Kodi as my main source of live TV and as such use the EPG (TV Guide) often. It would therefore be nice to have a button dedicated to that on the remote. I’m not sure what the right call is but tried EPGNow and SendText with “e” as the parameter but neither worked. Anyone else by chance implemented this?
Currently “smallforward” and “bigforward” skips 30 sec and 10 min respectively. I would like to fix the skip to match the label (10 and 30 sec) Is there preset values for the other skip intervals? I tried sending ‘Seconds = 10’ in the value tag but it didn’t work .
Locations of the advancedsettings.xml file (you may have to create it) can be found in the table lower down on this page if Kodi is not installed on Windows: https://kodi.wiki/view/HOW-TO:Modify_time_seeking
I just created the advancedsettings.xml file with this inside:
<advancedsettings>
<video>
<timeseekforward>10</timeseekforward> <!-- Time to seek forward in seconds when doing a short seek. Defaults to 30. -->
<timeseekbackward>-10</timeseekbackward> <!-- Time to seek backward in seconds when doing a short seek. Defaults to -10. -->
<timeseekforwardbig>30</timeseekforwardbig> <!-- Time to seek forward in seconds when doing a long seek. Defaults to 600 (30 minutes). -->
<timeseekbackwardbig>-30</timeseekbackwardbig> <!-- Time to seek forward in seconds when doing a long seek. Defaults to -600 (10 minutes). -->
</video>
</advancedsettings>
And after a restart of Kodi it works perfectly. +10, -10, +30, and -30 second skips.
Thank you for responding.
I now get why my changes to the skipstep under player settings in Kodi had no effect as it was an advanced setting.
Do you have a list of the commands that can be used via scripts?
On my physical remote I used right and left to skip the steps under player settings and it was nice to keep and as of now it doesn’t seem to work via the script.
I have also unsuccessful tried to call sendtext with the value e to get the EPG guide showing up but that doesn’t work.
Any links you might have to the commands would be greatly appreciated.
