Hi mate, here’s my yaml config. Sub your local key, ID and IP address
The kettle switch is a switch, the temp is a sensor.
Thanks.
Interesting, mine is only showing id:5, which is what I got in the config flow too.
Don’t seem to have id 1, or any other ID to then control the switch.
What happens when you configure as I shared? If you have the exact same kettle (they may be shipping variations at any point in time), then 1 should work for the on/off switch.
Done your way and the config flow.
If I do in yaml, just get errors in the log saying that it is trying to get an ID that does not exist.
Hi Sean, when you add it the first time there is a tick box about adding an extra sensor but it is a double negative question, extra to misread it.
Simple solution is to run the process of adding the device again in local tuya (don’t delete the one you have) this time round it will provide you the next sensor.
Can be a while between the days I check in on this forum but I will check over the next few days to see if you have sorted this or need a extra hand.
Also the other thing I have found it that if you had the standard Tuya, I had issue is a device was in this plugin even if the plugin was disabled so delete this plugin if not required.
Thanks Myle, I connected support and they were super helpful and sent me a replacement, once the replacement came I open up this unit to see what the issue was and tracked it down to this, thought I’ll see if I could get the replacement this part and have this in the garage. It’s so funny as I reuse it today to test a possibly fault I found and couldn’t remember how bad it was, like a dog whistle:). Might try epoxy on it to enclose the sound, nothing lost as it is only for parts.
Cool bro good u getting a new one
Thanks John (from another kiwi).
I have done this already and this is why I was so confused in the first place getting it working, I literally only get id “5” show up in the list.
If i run through it again, as thought perhaps that was the temp (and it is) the switch would appear second, it does not. I can’t even manually enter “1” as the id or leave it blank. Just throws errors about id already being added (correct) and can’t leave it blank.
I do have the Tuya integration on there, I also did try removing it and re-running the whole thing, but same result.
Think it is worth resetting the kettle? If I do, any ideas if it then changes the device key?
Hi Sean, over the last few days I’ve been tracking down another bug in the Kettles firmware and yesterday I went to re-add it back to Tuya local. I can confirm I’m now seeing the same issue as you (only id5). if I manually add the config of the kettle to the configuration file it will add id1, but the state is Unavailable. I’ve tried different browsers, redownloaded Tuya local and tried that as well. At the moment I’m not having much luck.
I’m wonders if something ahs changed in Tuya IoT environment??
Resetting the kettle doesn’t appear to alter the device key but resetting to factory settings in Tuya IoT does reset the local key.
For reference this is what I have in Tuya
localtuya:
Update: I now have it back but don’t know which of these work
I changed a few things and when I rechecked I noticed the kettle was back, I’m unsure which of these helped
All weird stuff but both kettle sensors are back and I deleted the native Tuya Integration
This is the exact issue I am having, after a couple of goes, I managed to get a DPS index of 102.
Not sure what this was, but thought it may have been the switch, but apparently not, since after adding that index, I am getting a bunch of log entries saying the DPS doesn’t exist.
My config if I do it in yaml is the same.
Will give these a go, thanks! Glad to know at this point its not just me.
Ok, just given that stuff a go and at first the switch didn’t work, just showed unavailable, but it now appears to be working!
I think what it maybe is too many connections. As I’ve logged out on my phone, then connected using the Tuya integration (again), but that always hits the rate limit when first adding. Now that the phone is logged out, the rate limit must be down enough that local works.
That is just my best guess at this stage, but its working ![]()
Great to hear I thought it could be the phone as well hence why I reset it. But as you say you have it working.
I also saw another DP of 102 which just returned the work current temp, didn’t use it.
Yer it didnt re-appear on re-adding it, but as you’ve said its the work current temp, it will only appear when it’s boiling, which makes sense as I turned the kettle on in a hope to get it to add.
Will ignore it, rather not have all those log entries.
Thanks so much for your help on this one ![]()
I had the same problem and found that DPS 1 gets accessible (and the switch becomes available) after I used the app to turn on the switch. This seems to survive a restart of HA when the restart is done via Server Controls.
After tuya-convert failed to even see this kettle I’m looking to open it up and flash it. Any tips on getting it open? I don’t want to break it. I’ve removed the screws underneath but it is still quite secure.
Does that kettle have any wifi chip? When replacing my original Kogan Smart kettle a few months ago, I found that they had several models of kettle called ‘smart’ which weren’t networkable. I think they justify the name because they’ve got temperature control…
Edit: although I see from your photo that it is from the ‘SmarterHome’ range, so it should be the real deal! Good luck getting it open.
I’ve made some progress, kettle base is open. As well asas removing the three screws underneath the front section, you have to pry the tabs outwards through the rectangle holes. I held some force on the stainless steel section so that they wouldn’t clip back in as I moved to the next clip.
Hey @sparkydave
That WR1 chip i think could be a realtek one and not able to flash.
WR1 Module-Documentation-Tuya Developer
Yeah, I have an ESP 12-F here I will try in place of it. Hopefully it works
Hi everyone, I just bought a Kogan Smart Kettle, and I’m trying to get Tasmota running on it. I wouold prefer ESPHome since I’m more familiar with it, but I’ll go with Tasmota since people have already shared a template for it.
I initially just wanted to get it working in Home Assistant through the Tuya integration, using the cloud Tuya Smart app. I added the device, but then it didn’t show up as a supported device. I ran this tuyaha discovery script with my credentials: tuyaha/debug_discovery.py at 41848be7f429191bd650d34a282379cbd3c6f610 · PaulAnnekov/tuyaha · GitHub
Got devices
{ 'header': {'code': 'SUCCESS', 'payloadVersion': 1},
'payload': {'devices': [], 'scenes': []}}
So it looks like Tuya’s home assistant integration doesn’t support these smart kettles.
Next, I tried to flash it OTA using tuya-convert, but I got the dreaded “firmware is too new” error:
Your device's firmware is too new.
Tuya patched the PSK vulnerability that we use to establish a connection.
You might still be able to flash this device over serial.
I think that’s my fault since I allowed it to connect to WiFi and update to the latest firmware. I’m a bit nervous about hacking kitchen appliances with custom firmware, since it involves high temperatures and voltages, so I would have preferred to get something working the safe way (in Tuya Smart.)
I’ve previously been able to flash a TYWE3S chip over serial using a Raspberry Pi. This was for a Brilliant Smart WiFi Powerboard 20691/05 where the firmware was also too new.
So I managed to pop open the case and get access to the TYWE3S chip:
Unfortunately this time I had some problems with my soldering iron and I struggled to solder on the jumper wires. I also had some unsuccessful attempts with using blutack, tape, etc. Hopefully I haven’t damaged the chip during my attempts. But I’ve got a better soldering iron being delivered early next week, plus some flux, and things to keep the tip clean. So I’ll give it another shot.
I just have some questions about Tasmota and how this works. Does anyone know if the buttons and display will still work after I flash the custom firmware? I’m worried that these are controlled by the original firmware that was running on the ESP8266 chip. I.e. Flashing Tasmota will delete the original firmware, and then there won’t be any code that knows about the buttons and display.
What is the “TuyaMCU module”, and how do the TuyaMCU 11,1 and TuyaSend4 102,0 commands work (e.g. for the Keepwarm function)? Is there a separate microcontroller somewhere that manages the display and buttons and handles all of the boiling / Keepwarm logic? (Is this a separate “MCU” chip?)
Thanks for your help!
EDIT: I think this explains it! MCU Low-Code Development | Tuya Smart
So we can update the “Cloud Module Firmware” to Tasmota, while the custom MCU firmware stays the same and continues managing the kettle functions (including the display and buttons.)
I suppose I will just need to figure out how to “ground the nreset line” to turn off the MCU while I’m flashing the TYWE3S. Does anyone know how to do that for this kettle?
EDIT 2: I just saw this message: Kogan Smart Kettle - #40 by rabbit-aaron
That sounds like a great idea to desolder the 4 pins and separate the two boards. I will do that.
