@nickrout sounds like you are saying the toggle is happening at wifi connect. That’d make sense as when flashing the device it does restart and would need to connect wifi.
You did give me an idea that I could use onboot to narrow down the point the light is turning on.
Has anyone noticed with this switch that if it is ON and you click ON it will go off. If I continue to click ON the switch toggles ON to OFF to ON. It appears that the MCU just toggles whether it gets an ON or OFF.
Hello I have tried to flash using the above diagram. My device does not seem to go into boot mode. I have IO0 sharing the ground pin from my FTDI232 serial to usb. Was there an indicator when you flashed it?
Does anyone know how this should be configured (Tasmota 8.2.0)? Using the standard Tuya MCU module selection, I can integrate with HA and hear the switch flip when clicking the HA button (led doesn’t change). When I push in the physical button on the device, I get no change in HA to reflect the button press.
