so i verified the KWh of the shellyplug and the output of that integral-riemann helper…
defenitvly THAT helper produces wrong values!
I made another Test-Intergral Helper:
Input is Load_power of house (~2000W)
Have a look at the timestamps!
Here is it ok.
But this here stucks at 0.29KWh but the raum_1_import_power sensor gives 1000W
That is wrong.
Diagramm:
can you create a Screenshot from this „helper“ (0 or 1)
and for the same time the „Raum 1 Import energy“
and also the power sensor you use for this (Raum 1 Import power)
Your Last screenshot from „Raum 1 Import energy“
Looks like your trigger for starting is not permanently set to the value = 1
I have tested this again especially for you
It looks plausible to me for the time being
Helper is a numeric one for me, 0 or 1
i just saw that the cost still counts even importing power is off.
Reason was the change from float to boolen…
This is right:
{% if is_state('binary_sensor.importing_power', 'on') %}
{{ states('sensor.shellyplusplugs_c82e18086ea4_switch_0_power')|float(0) |round(0)}}
{% else %}
0
{% endif %}
Could it be that the integral takes some hours to measure correctly?
Now it shows 0.99€ instead of 0.29€ but over night the heaters were off.
Nope
I would just start from scratch
With new sensor names (you can leave the old ones for now)
I would do the € converter later, that shouldn’t be a problem.
Start with the power sensor and diagram, if it fits then the energy sensor, if plausible then the € sensor
€ Sensor as Template Helper
my Energy Sensor is in Wh, so i need also /1000
{{ (states('sensor.wolfram_energy')|float(0) *0.455 /1000) |round(2) }}
Overview to validate Data:
it seems to work now right! I dont know why the KWh stuck yesterday evening…
i also put some utlitymeters for daily,weekly,monthly and yearly on.
So we have a overview of the power and cost for each room.
Is there a possibility to set the values persistent to 0 ?
If i use set state it will be overridenn after a while…
BTW: i want to thank you very much for your help!!!)
