La Marzocco GS/3 & Linea Mini support
Using v0.13.3 of LaMarzocco integration from zweckj.
Is it possible to set the brewing temperature? The documentation only says steam temperature.
The first number in this table: https://www.home-assistant.io/integrations/lamarzocco/#numbers
Did the update. Only one thing is not working - temperature control for apple homekit. I am able to switch steam but not coffee temperature. Maybe it will work in the next preview.
Apologize if I missed this up thread, but I just purchased a Micra for my vacation home. My HA instance exists at my main home only - can I set up this integration as cloud only? My use case is going to (at least initially) only be presence-based scheduling for when Iā€™m at the home.
(Also, as I think about it, seems like itā€™d be nice to have an Apple Watch complication with the brew temperature shown.)
Yes, but some entities wonā€™t be available. Documentation states which ones.
Hello zweckj. Iā€™ve been using your amazing work for many months and itā€™s been working great. In the last month, I notice that the integration fails to execute commands. I have a couple of esp32 bt proxies that usually works very well. When I reload the integration, it goes back to working fine, which suggests the problem is not the connection with the coffee machine. Iā€™m using the integration shipped with HA.
Let me know if you need any more information. Thanks!
Anything in the debug logs when you execute a command?
Iā€™m not sure if Iā€™m doing something wrong, but I think I have 13.3 downloaded and every time I try to login I get Invalid credentials and the following in the logs:
This error originated from a custom integration.
Logger: custom_components.lamarzocco.config_flow
Source: custom_components/lamarzocco/config_flow.py:53
integration: La Marzocco (documentation, issues)
First occurred: September 20, 2024 at 11:58:23 PM (2 occurrences)
Last logged: 12:03:43 AM
Server rejected login credentials
Did something change with authentication since the last issues in this thread?
Custom integration didnā€™t change for quite some time. I would suggest you try the core (built-in) integration instead.
I couldnā€™t see anything in the logs, I had debug logs enabled. After a week or so, everything is working fine again though. Hopefully it was just a fluke. Thanks!
I am new to HA and just found this integration, from what I can tell, it looks like it does not support the brew by weight functionality of the LM app. But I may have missed something.
I was hoping to be able to set up a dashboard on a device near my coffee brewing area with the ability to display shot timer and select the weight for the Brew by Weight.
Ideally, it would be cool to see a list of the last few shot times as the app loses the recent brew when you do a flush etc.
Happy to dig into this with a bit of guidance from someone in the know.
PS: This is really cool as is, just looking to what might make it perfect.
I should have added I have a Linea Mini (not Linea Mini R)
