Lambda Filter out bogus values during dawn
Is the character ( " ) or ( ’ ) missing in the script? I tried it now and it’s ok.
Linking .pioenvs/growatt-modbus/firmware.elf
RAM:   [====      ]  42.9% (used 35168 bytes from 81920 bytes)
Flash: [=====     ]  45.1% (used 470897 bytes from 1044464 bytes)
Building .pioenvs/growatt-modbus/firmware.bin
esp8266_copy_factory_bin([".pioenvs/growatt-modbus/firmware.bin"], [".pioenvs/growatt-modbus/firmware.elf"])
======================== [SUCCESS] Took 130.31 seconds ========================
INFO Successfully compiled program.
This is ok with me
esphome:
  platform: ESP8266
  board: d1_mini
substitutions:
  esp_name: Growattmodbus
   #Shift sunrise on minutes
  shift_sunrise: '10'
wifi:
  ssid: "SSID"
  password: !secret wifi_key
  use_address: 192.168.6.42
  domain: !secret domain
  ap:
    ssid: "${esp_name} fb Hotspot"
    password: !secret Fallback_Hotspot
captive_portal:
logger:
api:
ota:
time:
  - platform: homeassistant
sun:
  latitude: !secret latitude_data
  longitude: !secret longitude_data
uart:
  - id: uart1
    baud_rate: 9600
    tx_pin: D1
    rx_pin: D2
modbus:
  uart_id: uart1
web_server:
  port: 80
  - platform: wifi_signal
    name: "${esp_name} - ESP WiFi Signal"
    update_interval: 60s
  - platform: uptime
    name: "${esp_name} - ESP Uptime"
    icon: mdi:clock-outline
  - platform: growatt_solar
    update_interval: 3s
    protocol_version: RTU2
    inverter_status:
      name: "${esp_name} - Status Code"
    phase_a:
      voltage:
          name: "${esp_name} - AC Voltage"
      current:
          name: "${esp_name} - AC Current"
      active_power:
          name: "${esp_name} - AC Power"
          filters:
            - filter_out: NaN
    pv1:
      voltage:
          name: "${esp_name} - PV1 Voltage"
      current:
          name: "${esp_name} - PV1 Current"
      active_power:
          name: "${esp_name} - PV1 Power"
    pv2:
      voltage:
          name: "${esp_name} - PV2 Voltage"
      current:
          name: "${esp_name} - PV2 Current"
      active_power:
          name: "${esp_name} - PV2 Power"
    active_power:
      state_class: "measurement"
      name: "${esp_name} - Output Power"
      filters:
       - lambda: |-
           if (x <= 5500 && x >= 0) return x;
           else return 0;
    pv_active_power:
      name: "${esp_name} - Input Power"
    frequency:
      name: "${esp_name} - Grid Frequency"
    energy_production_day:
      name: "${esp_name} - Today Gen"
      filters:
        lambda: |-
          auto sunrise = id(sun_sun).sunrise(-0.833); //Get sunrise time
          auto time = id(homeassistant_time).now(); //Get aktual time
          if (!sunrise.has_value() and !time.is_valid()) //Validation sunrise and time data
            return 0 ;
          //1439 == 23:59 and 23:59 reset data to 0
          if((sunrise.value().hour * 60 + sunrise.value().minute + ${shift_sunrise}) < (time.hour*60+time.minute) && (time.hour*60+time.minute) < 1439) {
            return x;
          else return 0;
    total_energy_production:
      name: "${esp_name} - Total Gen"
      accuracy_decimals: 1
    inverter_module_temp:
      name: "${esp_name} - Temperature"
switch:
  - platform: restart
    name: "${esp_name} - ESP Restart"
text_sensor:
  - platform: wifi_info
    ip_address:
      name: "${esp_name} IP Address"
    ssid:
      name: "${esp_name} Connected SSID"
    bssid:
      name: "${esp_name} Connected BSSID"
    mac_address:
      name: "${esp_name} Mac Wifi Address"
  - platform: version
    name: "${esp_name} - ESPHome Version"
It compiles… now let’s see tomorrow morning :slight_smile:
I think today it worked. I keep watching it and report back.
Additionally I have 2 questions.
  1. Now when “the lambda” is in the is “no value”, can it send out 0 during tha time?
  2. during power loss/esp power down/esp unavailability the output in HA goes back to “no value” effective 0. How can I overcome that?
      filters:
        lambda: |-
          if(sunrise.has_value() && time.is_valid()){
              if(String(id(todaygen).state) == "nan") return 0;
              else return x;
            else return 0;
          else return 0;
2,
I´m not sure, but it will doesn´t work probably.
