2021-08-19 18:03:33 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration zeroconf which has not been tested by Home
Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-08-19 18:03:39 ERROR (SyncWorker_1) [homeassistant.util.package] Unable to install package zeroconf==0.36.0: ERROR: Cannot install zeroconf==0.36.0 because these package versions have conflicting dependencies.
ERROR: ResolutionImpossible: for help visit https://pip.pypa.io/en/latest/user_guide/#fixing-conflicting-dependencies
2021-08-19 18:03:39 ERROR (MainThread) [homeassistant.setup] Setup failed for zeroconf: Requirements for zeroconf not found: ['zeroconf==0.36.0'].
2021-08-19 18:03:40 ERROR (SyncWorker_1) [homeassistant.util.package] Unable to install package zeroconf==0.36.0: ERROR: Cannot install zeroconf==0.36.0 because these package versions have conflicting dependencies.
2021-08-19 18:03:40 ERROR (MainThread) [homeassistant.setup] Setup failed for esphome: Requirements for zeroconf not found: ['zeroconf==0.36.0'].
Ahh, interesting…
I did that and now i do not get the error message anymore.
But now I am back to the start with the very exact error message as in my first post even with the custom component.
WARNING (MainThread) [zeroconf] Error with socket 27 (('192.168.1.29', 5353))):[Errno 101] Network unreachable
File "/usr/local/lib/python3.9/asyncio/selector_events.py", line 1056, in sendto
self._sock.sendto(data, addr)
OSError: [Errno 101] Network unreachable
I have default_config: in my config.yaml and seeing no other zeroconf errors showing in the logs.
supervisor-2021.09.6
core-2021.09.7
Supervised install.
I had thought it might be related to the intro of os-agent but that is just a guess.
Any clues?
Had these too and they originally appeared to come from the HP Printer HACS integration for Home Assistant (as disabling it allowed me to start HA without zeroconf errors) but it since appears to have cleared itself, not really sure how or why…
I’ve as several update of the Eufy Security HACS integration since, so not sure if related.
