My current YAML which is working. It’s all based on what Bruce has done but changed where needed to work with the clever spa.
Once i’ve got all the functions working i’ll get a full package of code together.
- platform: rest
scan_interval: 30
timeout: 20
resource: "https://api.gizwits.com/app/devdata/xxxxxxxxxxxx/latest"
# xxxxxxxxxxxx is the did from the bindings sensor
device_class: timestamp
headers:
Content-Type: application/json
X-Gizwits-Application-Id: 805cc6a3f41b48aeae471e2fcb6ebc73
method: GET
value_template: "{{ value_json.updated_at | timestamp_custom ('%Y-%m-%dT%H:%M:%S+00:00') }}"
json_attributes_path: "$.attr"
json_attributes:
- Heater
- 03
- Undercooling
- Current_temperature
- Filter
- Temperature_setup
- Superheat
- Bubble
- Overtime_filter
- Timing
- Check
- Time_filter
sensors:
hottub_pump_temp:
availability_template: "{{ states('binary_sensor.hottub_online') }}"
friendly_name: "HotTub Water Temperature"
unit_of_measurement: '°C'
value_template: "{{ state_attr('sensor.hottub_status', 'Current_temperature') | int }}"
hottub_water_temp:
value_template: "{{ states('input_number.Temperature_setup') | int }}"
hottub_summary:
friendly_name: "HotTub Status"
value_template: "{% if is_state('binary_sensor.hottub_online','off') %}offline{% elif is_state('sensor.hottub_error','on') %}error{% elif is_state('input_boolean.hottub_scheduled','on') and is_state('switch.hottub_filter','off') %}scheduled{% elif is_state('switch.hottub_power','off') %}off{% elif state_attr('sensor.hottub_status','heat_temp_reach')==1 %}at temperature{% elif is_state('switch.hottub_heat','on') %}heating{% elif is_state('switch.hottub_filter','off') %}on{% elif is_state('switch.hottub_heat','off') %}filtering{% elif is_state('switch.hottub_bubbles','off') %}heating{% else %}bubbling{% endif %}"
- platform: history_stats
name: HotTub Heating This Week
entity_id: sensor.hottub_summary
state: "heating"
type: time
end: "{{ now().replace(hour=0, minute=0, second=0) }}"
duration:
days: 7
rest_command:
hottub_command:
method: POST
headers:
content_type: "application/json"
X-Gizwits-Application-Id: "805cc6a3f41b48aeae471e2fcb6ebc73"
X-Gizwits-User-token: #####your user token#####
url: "https://api.gizwits.com/app/control/ZUnVqKmSwvvgGkVtOFxS9v"
payload: "{{hottub_command}}"
binary_sensor:
sensors:
hottub_online:
friendly_name: "HotTub Online"
value_template: "{{ (now() | as_timestamp - states('sensor.hottub_status') | as_timestamp ) < 2000.0 }}"
switch:
switches:
hottub_heat:
unique_id: Heater
friendly_name: Heater
value_template: "{% if state_attr('sensor.hottub_status', 'Heater') == 1 %}on{% else %}off{% endif %}"
turn_on:
- service: rest_command.hottub_command
data_template:
hottub_command: >
{"attrs": {"Heater": 1} }
- delay: 00:00:05
entity_id: sensor.hottub_status
turn_off:
data_template:
hottub_command: >
{"attrs": {"Heater": 0} }
- delay: 00:00:05
hottub_filter:
unique_id: hottub_filter
friendly_name: Filter
value_template: "{% if state_attr('sensor.hottub_status', 'filter') == 1 %}on{% else %}off{% endif %}"
turn_on:
data_template:
hottub_command: >
{"attrs": {"filter": 1} }
- delay: 00:00:05
turn_off:
data_template:
hottub_command: >
{"attrs": {"filter": 0} }
- delay: 00:00:05
hottub_bubbles:
unique_id: Bubbles
friendly_name: Bubbles
value_template: "{% if state_attr('sensor.hottub_status', 'Bubble') == 1 %}on{% else %}off{% endif %}"
turn_on:
data_template:
hottub_command: >
{"attrs": {"Bubble": 1} }
- delay: 00:00:05
turn_off:
data_template:
hottub_command: >
{"attrs": {"Bubble": 0} }
- delay: 00:00:05
