šŸ”¹ Layout-card - Take control of where your cards end up
yeahā€¦ here is my octoprint layoutā€¦ Lets try to achieve it with stack-in-stack-in-stackā€¦ :slight_smile:
Not saying not possible :slight_smile:
weird, I donā€™t have them anymore, but I also removed the margins for #staging.grid, donā€™t know if you did that too. To make sure the adapted card is loaded, change the info-text thatā€™s displayed in the browser console too, so you can quickly see if it the changed version got loaded.
Thanks Kris!
Removing margin for #staging.grid did the trick!
Iā€™ll recheck later on my home mac/safari, but on my windows laptop scroll bars are gone!
Iā€™m having a lot of issues with the margins (clipping on top, scrollbars due to margin left and right, etc). I saw that there are some PRs open to fix these. Do you have a time @thomasloven when can we expect to see these merged? :smiley:
Iā€™m currently trying to use the layout card to create a sidebar on my frontend. Iā€™ve however run into a snag. There are margins between the cards that I would like to get rid of. Best explained with a screenshot where Iā€™ve already identified the culprit thanks to the developer tools of my browser:
Unticking that CSS property does get rid of the margins (in orange in the screenshot), however Iā€™ve not been able to figure out what code would need to go where in order to remove those margins.
My basic config (reduced it so itā€™s readable):
title: Dev
- title: Dev
  icon: 'mdi:github'
  panel: true
  badges: []
  path: dev
  cards:
    - type: 'custom:layout-card'
      layout: grid
      gridrows: auto
      gridcols: 23% 77%
      gridgap: 0px
      gridplace: stretch
      cards:
        - !include frontend/sidebar_dev.yaml
        - type: 'custom:config-template-card'
          gridrow: 1 / 1
          gridcol: 2 / 2
          entities:
          card:
            type: 'custom:swipe-card'
            parameters:
              effect: 'cube'
              cubeEffect:
                shadow: false
                slideShadows: false
            cards:
              - !include frontend/dev_rez.yaml
              - !include frontend/dev_1er.yaml
Iā€™ve also tried many different combinations combined with a mod-card in which I then configure the above layout-card, but no dice.
As far as my understanding of CSS goes, the correct properties should be inserted somewhere here and not within the included yaml files. Should I be wrong, Iā€™ll gladly post their content as well.
Thanks for any help!
The answer from here:
        style:
          layout-card$: |
            .grid > * {
              margin: 0px !important;
Hi Thomas,
Many thanks for your great Lovelace contributions :slight_smile:
I try to setup a grid layout with Ā« custom:button-card Ā» and Ā« custom:layout-card Ā». In other word, I would like to achieve a configuration like this HTML table layout (colspan / rowspan)
<table>
	<tr>
		<th colspan="2" rowspan="2">Date/Clock</th>
		<td>btn1</td>
		<td>btn2</td>
	</tr>
	<tr>
		<td>btn3</td>
		<td>btn4</td>
	</tr>
		<tr>
		<td>btn5</td>
		<td>btn6</td>
		<td>btn7</td>
		<td>btn8</td>
	</tr>
</table>
Is there a way to do it without nesting components under other Ā« entitiy Ā» types (to limit indent level)?
Many thanks in advance for advises.
for the moment the best arrangement I was able to do is : a mix of ā€œvertical-stackā€ and ā€œhorizontal-stackā€ā€¦ I finally donā€™t try to use any more ā€œlayout-cardā€ because it was resizing blank button-card (color_type: blank), then i was losing proportion between button5 and button8 if button6/7 are blank!
My solution :
type: vertical-stack
cards:
  - type: horizontal-stack
    cards:
      - type: 'custom:button-card'
        icon: 'mdi:clock'
        style: 'ha-card { height: 100%; }'
      - type: vertical-stack
        cards:
            cards:
                icon: 'mdi:numeric-1-box-outline'
                icon: 'mdi:numeric-2-box-outline'
            cards:
                icon: 'mdi:numeric-3-box-outline'
                icon: 'mdi:numeric-4-box-outline'
    cards:
        icon: 'mdi:numeric-5-box-outline'
        icon: 'mdi:numeric-6-box-outline'
        icon: 'mdi:numeric-7-box-outline'
        icon: 'mdi:numeric-8-box-outline'
Hello i want to try using this layout-card but i canā€™t seem to get a simple 2 card horizontal layout.
Screenshot
Code:
  - id: 8
    icon: mdi:washing-machine
    cards:
        layout: horizontal
        cards:
#              Housekeeping - Laundry Status Card               #
        - type: entities
          style: |
            ha-card {
              --ha-card-background: rgba(150, 150, 150, 0.2);
              --primary-text-color: white;
              --secondary-text-color: var(--primary-text-color);
              --paper-item-icon-color: white
              --width: 200%
          entities:
            - type: 'custom:text-divider-row'
              text: Laundry
            - type: 'custom:stack-in-card'
              cards:
                  entity: sensor.washing_machine_status
                  style:
                    - font-size: 14px
                - type: entities
                  entities:
                  - entity: sensor.washing_machine_status
                  - entity: binary_sensor.washing_machine_door
                - type: conditional
                  conditions:
                      state : "In use"
                  card:
                    type: entities
                    entities:
                      - entity: sensor.washing_machine_remaining_time
                        name: Time remaining
                        icon: 'mdi-clock'
                      - entity: sensor.washing_machine_finish_time
                      - entity: sensor.washing_machine_progress
                      - entity: sensor.washing_machine_energy_consumption
                      - entity: sensor.washing_machine_water_consumption
        - type: entities
          style: |
            ha-card {
              --width: 200%
          entities:
              text: Laundry
              cards:
                  style:
                    - font-size: 14px
                - type: entities
                  entities:
                - type: conditional
                  conditions:
                      state : "In use"
                  card:
                    type: entities
                    entities:
                        icon: 'mdi-clock'
try to force number of columns
        layout: horizontal
        column_num: 3
        cards:
I am using the layout-card, auto-entities, and button-card together and overall is working well. However, as you can see from the card definition below, my title for the ā€œcardā€ is defined in the horizontal-stack. This is the only way Iā€™ve been able to get a title to appear for the card. The problem is that the title still appears when the list of entities provided by auto-entities is empty. How can I get a title for this that only appears when I have entities?
    title: Unlocked Doors
    cards:
      - type: 'custom:auto-entities'
        show_empty: false
        card:
          column_num: 2
        filter:
          include:
            - domain: lock
              options:
                layout: vertical
                tap_action:
                  action: toggle
          exclude:
            - state: locked
coming to you with my very first (close to successful) attempt at a layout config:
# buttons_alerts_layout.yaml
type: custom:layout-card
#layout: horizontal
#min_height: <min_height>
#min_columns: <min_columns>
#max_columns: <max_columns>
column_num: 4
#column_width: <column_width>
#max_width: <max_width>
#min_width: <min_width>
#sidebar_column: <sidebar_column>
#flex_grow: <flex_grow>
#gridcols: <grid_cols>
#gridrows: <grid_rows>
#gridgap: <grid_gap>
#gridplace: <grid_place>
#justify_content: start
rtl: ltr
#card_options:
#    <card_options>
cards:
  - type: conditional
    conditions:
 etc etc etc
and card config:
type: conditional
conditions:
  - entity: sensor.count_alerts_notifying
    state_not: '0'
card:
  cards:
    - !include /config/lovelace/includes/include_button_marquee_alerts.yaml
    - !include /config/lovelace/buttons/buttons_alerts_layout.yaml
needed the rtl: ltr because it would otherwise show the cards from r to l using the default (none) setting.
all in all this seems ok, with 2 gripes: the space between the scrolling button with the alerts, and the 2 live buttons is too small, and the space at the bottom of the 2 live buttons to the next card is too large.
Thought I would have to use some of the justify_content options but I cant seem to influence the position. Would anyone of you know where to begin?
this even spacing between buttons is what I am after:
thanks for having a look!
edit
seems this not yet merged PR takes care of the issue: https://github.com/thomasloven/lovelace-layout-card/pull/97/files
set it to margin-top: -4px; though which fits my needs better:
edit
hmmm, guess the main question is how to have the cards fill from left to rightā€¦
update
well fiddling with the margins hasnt got the same effect on all devices. As far as I have noticed especially the iOS app now goes beyond the expected card space when using the adapted margin-left. When using the daytime theme, I do notice some heavy shadowing I cant explain according to my own cards stylings. I fear that is what is causing the margins to be so complex/confusing to set.
Hiā€¦,
Could you please to show me your config settings? This exactly what I wantā€¦:pray:
Do you mean the layout-card configuration, or the UI elements ? Regarding the later, those are all (heavily-modded) button cards.
Have a look at the official doc, itā€™s very well detailed. Once youā€™ve setup your css grid correctly, you can move on with the fancy stuff to make things look good.
Iā€™ve moved on from this type of interface because nowadays, most of my setup is automated and I donā€™t need the web interface that much. But this was a pretty fun jouney, you should enjoy yours too :slight_smile: !
I mean card configuration.
When I resize the screen, cards position rearranged. So all cards on the dashboard always appear complete, not truncated. This is what I want.
Right, in that case, you need a mix of :
Using an include statement & a teamplate, you can create kinda reponsive UIs without having to duplicate your code :
- type: custom:state-switch
    entity: mediaquery
    states:
      "(min-width: {{ _global.breakpoint_desktop }})": !include
        - ../03_layouts/layout_plants.yaml
        - colNum: 7
          alignment: "left"
          plantSensors: {{ plantSensors }}
          plantDevices: {{ plantDevices }}
      "(min-width: {{ _global.breakpoint_tablet }})": !include
        - colNum: 5
          alignment: "center"
      "(min-width: {{ _global.breakpoint_mobile }})": !include
        - colNum: 3
          alignment: "center"
      "all": !include
        - colNum: 1
          alignment: "center"
Iā€™m relying on globals & jinja variables to keep everything short. You donā€™t need to do that.
Great, is this your config code to make itā€™s work?
I was read lovelace-gen repository but still confusing how to use that.
Yes, this is my config used to achieved the result you mentionned.
As I said, itā€™s not the easiest nor the most optimal method, but it was entertaining and I guess the outcome looked kinda nice. I suggest you keep reading the doc, and experiment on your side. Thomas Lovenā€™s documentation are very detailed and resourceful, youā€™ll get where you want in the end.
Ok. Thank you for suggestion.
Are you use that ...{{ _global.breakpoint_desktop }}... instead of specific px at min-width section?
is there the possibility to anchor the alignment of the card to the bottom of the page regardless of the height of the page?
Schermata 2021-02-08 alle 13.19.39
is it possible to eliminate this margin?
