Yepp, reading the new documentation. That should more or less easily fix your issue. I can tell from own experience.
Not seeing the new Layout tab when I edit, as it is shown in the quick start video so not sure what is wrong
Also where is the location to add the url you mentioned?
Configuration > Lovelace Dashboards > Resources
Still not there after adding v2 url and restarting
HACS also says I have one resource not loaded and it is the layout-card and I have to add back the url: /hacsfiles/lovelace-layout-card/layout-card.js
Try Home Assistant 21.3 or later.
I have latest 2021.3.4, doesnāt make any sense on my PC the layout is fine, on any tablet the panel mode is being ignored. Maybe it just doesnāt work on the Home Assistant android app?
Or maybe column_width: 100%
doesnāt work anymore on latest version?
Sorry, iām using yaml mode and there are no issues wth HACS.
It doesnāt, thatās also why itās left out in the ReadMe as an available option. column_width
is not an option anymore. Not sure what youāre trying to achieve, perhaps the same as I used to have (full width 1 column).
See my post:
The explanation of Thomas:
And the solution by dmatik.
Change percentage to 100% for your use case.
Did you even read the instructions? Or do you just think of them as a nice, little side project for thomasloven
. I mean, why should he have a family life if he can write instructions that are not read?
Iām sorry, but what youāre doing here is trying to get someone to do your stuff. READ the instructions, all you want to know (and asking) is written in there. And I can tell for sure, because I had the exact same problem with my tablet, but it solved itself after reading the instructions and changing my settings accordingly. And no, I wonāt tell you how itās done, because Iām not willing to give this behaviour any kind of support. Nevermind, why botherā¦read it or leave itā¦
If you have questions, that are not answered in the (not very long) instructions, I and others are more than willing to help.
Sure did but no mention of that on the main page in github.
What Iām trying to do is simple, I need one card that takes the whole page width (the page is in panel mode) and then I have lots of cards inside it.
Tried this but still not using 100% of the width:
layout_type: grid
layout_options:
grid-template-columns: 100%
grid-template-rows: auto
And what did this gridcols: auto 100px
change into now? Getting closer to fixing it
At the end I figured out how to do it. As you did in your example, I used a Vertical Stack behind the secondary grid layout and It worked perfectly.
Thanks!
I would like to justify the layout-grid on the left but I donāt see how to do it.
I can see the property to do it but I donāt know how to put it in the yaml
Help me please
Try upgrading to 2.2.0
I updated to 2.2.1 but I donāt see how to justify left
That should stretch the grid to the edges, then you can add an empty column to the right to space it out.
And there is no 2.2.1
Hi, i just updated to the newest version, but now my view for my vacuum is kinda broken.
I tried to show you what i mean. The picture shows the view after the update and on the lower right the boxes show how it should look like/how it was before the update.
I already tried to edit the code, but the only thing i was able to fix (at least i hope so) was the outer grid.
type: vertical-stack
cards:
- type: 'custom:button-card'
color: auto
styles:
card:
- height: 5px
tap_action:
action: navigate
navigation_path: /lovelace-tablet/home
- type: 'custom:layout-card'
layout_type: grid
layout_options:
grid-template-columns: 400px 250px auto
cards:
- type: 'custom:xiaomi-vacuum-map-card'
card_mod:
style: |
ha-card {
background: none;
box-shadow: none;
height: 81%
entity: vacuum.wall_e
map_camera: camera.wall_e_camera
camera_calibration: true
language: de
debug: false
layout_type: vertical
cards:
layout_type: horizontal
layout_options:
max_cols: 2
cards:
- type: vertical-stack
cards:
- type: button
tap_action:
action: toggle
entity: script.vacuum_esszimmer
icon: 'mdi:table-chair'
show_name: false
card_mod:
style: |
ha-card {
background: none;
box-shadow: none;
width: 100%
- type: button
tap_action:
action: toggle
entity: script.vacuum_flur
icon: 'mdi:door'
show_name: false
card_mod:
style: |
ha-card {
background: none;
box-shadow: none;
width: 100%
- type: button
tap_action:
action: toggle
entity: script.vacuum_kueche
icon: 'mdi:stove'
show_name: false
card_mod:
style: |
ha-card {
background: none;
box-shadow: none;
width: 100%
view_layout:
column: 1
cards:
- type: button
tap_action:
action: toggle
entity: script.vacuum_schlafzimmer
icon: 'mdi:bed'
show_name: false
card_mod:
style: |
ha-card {
background: none;
box-shadow: none;
width: 100%
- type: button
tap_action:
action: toggle
entity: script.vacuum_speisekammer
icon: 'mdi:food'
show_name: false
card_mod:
style: |
ha-card {
background: none;
box-shadow: none;
width: 100%
- type: button
tap_action:
action: toggle
entity: script.vacuum_wohnzimmer
icon: 'mdi:sofa'
show_name: false
card_mod:
style: |
ha-card {
background: none;
box-shadow: none;
width: 100%
view_layout:
column: 2
view_layout:
column: 1
- type: button
tap_action:
action: toggle
entity: script.wall_e_entlehren
icon: 'mdi:trash-can'
show_name: false
card_mod:
style: |
ha-card {
background: none;
box-shadow: none;
width: 100%
view_layout:
column: 1
What am i missing?
What you need to do to make it span 100% is follow the Quick Start steps.
Do not select Panel mode.
Select Grid instead of Masonry.
Open up the view properties again and go to the āLayoutā tab.
Enter the size of the column and rows you would like:
grid-template-columns: 10% 10% 10% 10% 10% 10% 10% 10% 10% 10%
grid-template-rows: 10% 10% 10% 10% 10% 10% 10% 10% 10% 10%
Then press the Add Card button and select the card you would like.
Make any adjustments using the GUI and then press the Show Code Editor.
Add the placement.
Either of these will work.
view_layout:
grid-column: 1 / 3
grid-row: 7 / 9
or
view_layout:
grid-column-start: 1
grid-column-end: 3
grid-row-start: 7
grid-row-end: 9
Here is an example:
type: gauge
entity: sensor.openweathermap_temperature
min: 0
max: 100
view_layout:
grid-column: 1 / 3
grid-row: 7 / 9
You can also change/add things by clicking on the 3 vertical dots in the upper right hand corner and selecting Edit Dashboard and then Raw Configuration Editor.
Hope this helps.
FROM 2.2.0 THE CARD OPTION layout
IS CALLED view_layout
This was done to avoid collisions with parameters for other popular custom cards, and done in collaboration with their developers and the frontend dev team.
I updated your example code @Amishman. Hope you donāt mind.
@Ferador The horizontal layout will by default try to give each column at least 300 px of width. Play around with the width
option, or try a grid layout for your red and green box.
