🔹 Layout-card - Take control of where your cards end up
I’m wondering the same. I have 5+ dashboards that uses the layout-card break and I’d hate to do this global config for each of them if a fix is right around the corner.
I don’t believe the Layout-card is being maintained any longer. 83 open issues at the moment and this fix has been waiting for three weeks.
So looks like I may have to indeed abandon layout-card. What alternatives have you guys been using? Specifically for adding breaks.
I’m looking as well. I strictly only use the grid-layout but haven’t found anything comparable.
Does anyone knows how to change this margin to 0px? I have tried many approaches using styles or card_mod but with no success:
add:
masonry-view-card-margin: "0"
to your theme yaml
I am sorry, first time doing this. Would it be in my card directly (if yes, how) or in my dashboard Raw configuration editor?
You’ll have to create a theme.yaml file to do this.
Install Studio Code Server on you HA instance (if not already present), open your config folder (this is where your configuration.yaml file is), create a new folder called “themes” and within that folder create a file yourthemename.yaml
in that file add the code mentioned by @sebbaT here. Then chose this as the theme for all the dashboards where this is relevant.
max_columns: 3
I’m having problems making things go into columns. I have breaks in
everything is still in a single column
Stupid question from a pretty advanced Home Assistant user:
How do I install this via HACS? I don’t see it listed as Available.
I prefer to use HACS over the manual install to keep updates coming.
Thanks - Jonesie
My dashboard has been evolving, so I decided to standardize my layouts for each page, so I can manage the look and feel, but also make it responsive for my PC, phone and tablet.
I am using the layout card heavily.
My starting dashboard design for the learning curve is from [Madelena] with a few changes for what I want to do. (GitHub - Madelena/hass-config-public: My Dashboards for Home Assistant - Advanced data visualizations, responsive design, a neat maximalist Metro Live Tile layout, and an ultraminimal tablet layout!)
This is my main layout intent
#            RESPONSIVE LAYOUT                  #
#default
margin: 0
#grid-gap: var(--custom-layout-card-padding)
grid-gap: 5px
grid-template-columns: 25px minmax(20%, 1fr) repeat(3, 1fr) 25px
grid-template-rows: 75px repeat(3, fit-content(100%)) 55px
grid-template-areas: |
  ". sidebar header1 header2 header3 ."
  ". sidebar c c c ."
  ". sidebar c c c ."
  ". sidebar c c c ."
  ". sidebar footer1 footer2 footer3 ."
mediaquery:
  #phone
  "(max-width: 800px)":
    grid-gap: 5px
    grid-template-columns: auto
    grid-template-rows: auto auto auto repeat(5, auto)
      "header1"
      "header2"
      "header3"
      "sidebar"
      "c"
      "footer1"
      "footer2"
      "footer3"
  #tablet
  "(max-width: 1200px)":
    grid-gap: 5px
    grid-template-columns: minmax(20%, 1fr) 1fr 0fr
    grid-template-rows: 75px 75px repeat(3, min-content) 55px auto
      "header1 header1"
      "header2 header3 ."
      "sidebar c ."
      "sidebar c ."
      "sidebar c ."
      "sidebar c ."
      "sidebar footer1 ."
      "footer2 footer3 ."
  #tablet
  "(max-width: 1920px)":
    grid-gap: 5px
    grid-template-columns: minmax(20%, 1fr) repeat(3, 1fr) 0fr
      "sidebar header1 header2 header3 ."
      "sidebar c c c ."
      "sidebar c c c ."
      "sidebar c c c ."
      "sidebar footer1 footer2 footer3 ."
This works pretty well when I test with Chrome developers.
I have a question about area c.
I assumed that I can start placing cards in area c, and they will get placed one after the other in the 3 columns in c.
However, I get each card across the width of area c.
#Main Section of the dashboard page
  - type: "custom:layout-card"
    layout_type: "custom:grid-layout"
    view_layout:
      grid-area: c
      # place-self: center auto
    cards:
    # [Column] Current Conditions
    - type: custom:layout-card
      layout_type: custom:grid-layout
      layout: !include layouts/layout-live-tile.yaml
      cards:
        - type: 'custom:button-card'
          template: header_card
          variables:
            name: CURRENT CONDITIONS
            label: Accuweather
            arrow: 'mdi:arrow-top-right'
            action: url
            link: !secret accuweather_url
          view_layout:
            grid-column-start: 1
            grid-column-end: -1
          template:
            - live_tile
            - weather_precipitation
          variables:
            aspect_ratio: 2
          entity: sensor.pirateweather_precip_probability
          view_layout:
            grid-column: span 2
This is what I get:
I added a layout card in area c.
My first question is, do I need to do that or am I missing something that will force cards onto the columns in area c as defined.
layout:
grid-template-columns: 'repeat(auto-fill, [col-start] minmax(356px, 1fr) [col-end])'
grid-column-gap: 32px
margin: -1px
code now is:
    view_layout:
      grid-area: c
    layout: !include layouts/layout-page-columns.yaml
    cards:
      view_layout:
        grid-column-end: -3
had to read up on column-start and -end to make sure it is still responsive.
Now it looks like I want it to look like, but it is not responsive.
with smaller screen, you can see the overlaps.
Any idea what I need to change? This is the most customization I have ever done with grid and layout-cards.
I would like for the behavior to be the following:
As the screen get smaller, the area c content goes from 3 columns to 2, then to 1, so the total dashboard would be going from 4 (including sidebar) to 3 to 2, then ultimately to 1.
If the change is in the area c Layout-card, how do I account for the sidebar? given that mediaquery is on a screen size, not a child area size?
Apologize for the length of the post, trying to understand the structure so I can apply it across multiple areas I will be re-doing.
Hi there. I don’t know hot to make the 3 cards inside my layout card to get aligned to the left and right side so thw 3 cards occupy the same width as the cards on top of them.
Hopefully the image will clarify:
Hi!
woo it’s not easy!
I’m trying to reproduce this layout :
But i’m lost…
@stban1983
CleanShot 2024-11-21 at 19.16.30
    layout:
      grid-template-columns: repeat(3, 1fr)
      grid-template-rows: repeat(3, 1fr)
    cards:
      - type: button
        view_layout:
          grid-column: span 2
          grid-row: span 2
        show_name: true
        show_icon: true
        tap_action:
          action: toggle
        entity: light.kitchen_lights
      - &button
        show_name: true
        show_icon: true
        type: button
        tap_action:
          action: toggle
      - <<: *button
      - <<: *button
      - <<: *button
      - <<: *button
