LCD Display with MQTT and Home-Assistant notifies
Hum… I tried but nothing works…
Hmm still no logs from u
The only error is the one before:
Error running command: sh /config/shell_scripts/test.sh , return code: 2
I search about this one but I find nothing.
Thank you for your help !!
Sorry but u still didn’t give me output of manually starting this script outside hass
What happens if u browse into the directory shell_scripts and run ‘sh test.sh’?
Thank you, I don’t understood what you mean…
It works now with the log it displayed !! The only thing which don’t work is I wish integrate a state of sensor:
curl -k http://192.168.1.xxx/control?cmd=lcd,2,1,fini%20a{{ states.sensor.10_minutes_fin.state }}
And the log is: curl: (6) Could not resolve host: states.sensor.10_minutes_fin.state
Sensor state must be called inside Hass … I still don’t understanding what u are doing and where u r excecuting your scripts.you might want to talk German? If this is easier for you :wink:
In fact the “test.sh” was only an example to solve my problem!
It’s a french an I add “%20” instead of a space, because it stops the display! :wink:
What do you mean with: “Sensor state must be called inside Hass”
I’m really sorry with all my questions…
No %20 is the ASCII code for space …u need this to add a space on your display…sorry but i can’t help you out if you even don’t have the basics of Hass / Linux
Your description where and how u call your script is still not clarified… So I can’t help you a port mate but I need exact information about what u are trying to achieve and how u proceed in detail
please share your instruction
Would appreciate that as well, how did you connect the display to ESP8266 ? What kind of LCD display did you use ?
it’s ICS display… i’ll post an example if u lie guys
