Hi, I will write under this thread as I have a similar issue.
I am just starting my adventure with HA and I am building my first module based on Wemos D1 mini V4 and LD2410. After configuring everything I get all readings as ‘unknown’. I have ‘read the whole Internet’ and tried everything I found without any success. I have tested it on two different D1 minis and two different LD2410 and it is the same.
I would be greatful for any help as I am running out of ideas.
I am using a LD2410C with UART directly go to usb port by a ch340 adapter, no ESP. It worked fine for 2-3 days then the state got stuck. A bluetooth connection and re-init device could make it work again. I tried to add a restart cmd each 10 mins but it didnt help.
I had the same issue with two LD2410B. I’ve setup them using ESPHome on an ESP8266 connected to TX and RX (TX -RX, RX - TX). They both worked great for a week or less. Then, Still Energy and Still Target stopped working on Home Assistant, it’s always as zero. I feel that the other data is also bogus.
I’ve connected to the module using the app, tried restarting the module but it didn’t work. Can you explain how do you restart the radar like you said, please?
Ok, I found out what I was doing wrong. Basically, the default settings from ESPHome page for LD2410 didn’t work for me, this is my settings for the sensor now:
I didn’t even realize this before, setting max_still_distance to only 0.75m will make the sensor detect still distance only on the first gate. According to the app, when I’m sitting in front of the sensor, the energy is being picked from gate 2, so that was my problem and why the sensor wasn’t detecting still energy anymore for me.
When I first uploaded ESPHome, I had the sensor disconnected. So it was operating on factory defaults initially, and it was working nicely. After a time, I think ESPHome setup the sensor with the “wrong” configuration and then it stopped working.
In case you are wondering, I’m setting the threshold to 100 on higher gates because I don’t want detection on those distances.
And to answer my own question, if you want to factory reset the sensor, using the app. You can set your Android device language to English, so the app will load in English instead of Chinese. When you connect to the sensor, click More (更多) and then Initialize (恢复出厂) on the top right.
