Ledstrip in my cupboard - what do I need?
You could try Motes, they’ll fit the bill!
One Pi (a Zero W makes a lot of sense) plus a Mote host will let you individually control all the leds on up to 4 separate strips.
I’ve seven different lighting installs with them, and can control them all through Hass.
I’ve put up a how to guide, though I’ve a much better way in the pipeline.
In the meantime if you do get them, the guide and code bits will certainly let you play with them!
Couldn’t be without mine :slight_smile:
If you want to add another Pi power supply to the mote host itself, they’re so bright they can hardly be looked at.
