LEGO DUPLO train control with esphome
@JWL98, @anthonyangel, @vrutkovs, @arehsan, @Lumpusz
Very cool that you guys figured this out, amazing.
I am trying to wrap my head around this, but still a bit puzzled:
How do you guys know what values to enter for:
  • ble_clients mac_address and id
  • service_uuid
  • characteristic_uuid
  • the value of the bytes to write
thanks up front for the help,
Br,
Raymond
service_uuid and characteristic_uuid are hardcoded values LEGO uses in the train to identify data. These will not change. Same for bytes to write - this is the protocol we should follow.
MAC address and ID can be detected using ESP32 Bluetooth Low Energy Scanner — ESPHome
Thank you very much for your response.
Makes things a lot clearer.
Do you know any esphome yaml files to use to get that data?
Do I need to push any buttons on the Lego hub to activate communication?
Can the values to send be found in the official Lego api docks?
Sorry for all the questions :grin:
Trying to fully understand.
I have never used BLE with HA or esphome.
Best regards,
Thanks upfront,
Raymond
You may want to start with ESPHome Tutorial at Getting Started with ESPHome and Home Assistant — ESPHome first
I don’t think Lego hub is needed, at least I don’t have one
I don’t know tbf, quite possibly these are extracted from the docs indeed
I am a bit puzzled :slight_smile:
How are you connecting this all to Lego if you don’t have a hub?
With a hub I mean: Lego part 88009
thanks again
br
Raymond
ESPHome runs on a microcontroller which has BT, so it can connect to the train directly
Thanks I got that part :smiley:
I was talking about the ā€˜Lego-side’
You still need a hub as linked above in the Lego train, or am i misunderstanding things?
Br
Hi, I am trying to figure out a way to use this to turn an esp32 in a remote controller for that lego train… how do you generate the payload bits? is there a tutorial, because I simply don’t get it… how do you determine which value to use? I read the Lego Wireless Protocol docs on git but I think I am missing something… e.g to get that motor running… i figured out I need the section 3.27 Output Command 0x81 - Motor Sub Commands. I also figured out that I have to convert the PWM duty cycle to hex… but what is with the rest of the command values, where do I get them from?
thanks upfront
Hi, @JWL98,
Congrats, the project is awesome!!
How do you learn the bluetooth codes of the buttons that you replicate later to send to the train?
Thanks,
Miguel
