EDIT / UPDATE:
The wonderful people on discord, notably @firstof9 and @freshcoast helped me. The solution ended up being to switch to the mqtt version of the addon, which allowed me to force a re-interview.
Original
My old install of HA was quite crufty, and am doing a reinstall. It was using the older built-in zwave code. and now I’m on the official zwavejs addon, on a newly upgraded 2021.04 HA (as of a few hours ago).
I have a ZSE40 Zooz 4-in-1 that connected up ok to the new zwave-js addon. But it’s missing the motion sensor! The luminance / humidity / temp all read fine as far as I can tell.
My addon log does have:
2021-04-07T23:23:10.759Z CNTRLR [Node 009] treating BasicCC::Set as a report
Is there a way to force a re-interview of the device?
How else should I debug this? I’m stuck.
From the network dump, the node appears to have some motion sensor, so I’m not sure why it’s not showing up as an entity:
"nodeId": 9,
"index": 0,
"installerIcon": 3079,
"userIcon": 3079,
"status": 1,
"ready": true,
"isListening": false,
"isRouting": true,
"isSecure": false,
"manufacturerId": 634,
"productId": 8449,
"productType": 8225,
"firmwareVersion": "32.2",
"zwavePlusVersion": 1,
"deviceConfig": {
"filename": "/usr/src/node_modules/@zwave-js/config/config/devices/0x027a/zse40.json",
"manufacturer": "Zooz",
"label": "ZSE40",
"description": "4-in-1 Sensor",
"devices": [
"productId": 8449
"firmwareVersion": {
"min": "0.0",
"max": "255.255"
"paramInformation": {
"_map": {}
"label": "ZSE40",
"neighbors": [
2,
3,
5
"interviewAttempts": 0,
"interviewStage": 6,
"endpoints": [
"nodeId": 9,
"index": 0,
"userIcon": 3079,
"deviceClass": {
"basic": {
"key": 4,
"label": "Routing Slave"
"generic": {
"key": 7,
"label": "Notification Sensor"
"specific": {
"key": 17,
"label": "UNKNOWN (0x11)"
"mandatorySupportedCCs": [],
"mandatoryControlledCCs": []
"values": [
"endpoint": 0,
"commandClass": 49,
"commandClassName": "Multilevel Sensor",
"property": "Air temperature",
"propertyName": "Air temperature",
"ccVersion": 7,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Air temperature",
"ccSpecific": {
"sensorType": 1,
"scale": 1
"unit": "\u00b0F"
"value": 71.01
"endpoint": 0,
"commandClass": 49,
"property": "Illuminance",
"propertyName": "Illuminance",
"ccVersion": 7,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Illuminance",
"ccSpecific": {
"sensorType": 3,
"scale": 0
"unit": "%"
"value": 100
"endpoint": 0,
"commandClass": 49,
"property": "Humidity",
"propertyName": "Humidity",
"ccVersion": 7,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Humidity",
"ccSpecific": {
"sensorType": 5,
"scale": 0
"unit": "%"
"value": 29.88
"endpoint": 0,
"commandClass": 112,
"commandClassName": "Configuration",
"property": 1,
"propertyName": "Temperature Scale",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"label": "Temperature Scale",
"default": 0,
"min": 0,
"max": 1,
"states": {
"0": "Celsius",
"1": "Fahrenheit"
"valueSize": 1,
"format": 0,
"allowManualEntry": false,
"isFromConfig": true
"value": 1
"endpoint": 0,
"property": 2,
"propertyName": "Temperature offset",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"description": "temperature change to be reported",
"label": "Temperature offset",
"default": 1,
"min": 0,
"max": 50,
"valueSize": 1,
"format": 0,
"allowManualEntry": true,
"value": 10
"endpoint": 0,
"property": 3,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"description": "Configure Relative Humidity",
"default": 10,
"min": 1,
"max": 50,
"unit": "percent",
"valueSize": 1,
"format": 0,
"value": 10
"endpoint": 0,
"property": 4,
"propertyName": "Light Sensor",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"label": "Light Sensor",
"default": 10,
"min": 1,
"max": 50,
"unit": "percent",
"valueSize": 1,
"format": 0,
"value": 10
"endpoint": 0,
"property": 5,
"propertyName": "Trigger Interval",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"description": "Set the trigger interval for motion sensor re-activation.",
"label": "Trigger Interval",
"default": 3,
"min": 1,
"max": 255,
"unit": "minutes",
"valueSize": 1,
"format": 1,
"value": 15
"endpoint": 0,
"property": 6,
"propertyName": "Motion Sensor Sensitivity",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"description": "Adjust sensitivity of the motion sensor.",
"label": "Motion Sensor Sensitivity",
"default": 4,
"min": 1,
"max": 7,
"states": {
"1": "highest",
"2": "higher",
"3": "high",
"4": "normal",
"5": "low",
"6": "lower",
"7": "lowest"
"valueSize": 1,
"format": 0,
"value": 3
"endpoint": 0,
"property": 7,
"propertyName": "LED indicator mode",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"label": "LED indicator mode",
"default": 3,
"min": 1,
"max": 4,
"states": {
"1": "Off",
"2": "Pulsing Temperature, Flashing Motion",
"3": "Flashing Temperature and Motion",
"4": "No Temperature, Flashing Motion"
"valueSize": 1,
"format": 0,
"value": 4
"endpoint": 0,
"commandClass": 113,
"commandClassName": "Notification",
"property": "Home Security",
"propertyKey": "Motion sensor status",
"propertyName": "Home Security",
"propertyKeyName": "Motion sensor status",
"ccVersion": 4,
"metadata": {
"type": "any",
"readable": true,
"writeable": true
"value": 0
"endpoint": 0,
"commandClass": 114,
"commandClassName": "Manufacturer Specific",
"property": "manufacturerId",
"propertyName": "manufacturerId",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Manufacturer ID",
"min": 0,
"max": 65535
"value": 634
"endpoint": 0,
"property": "productType",
"propertyName": "productType",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Product type",
"min": 0,
"max": 65535
"value": 8225
"endpoint": 0,
"property": "productId",
"propertyName": "productId",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Product ID",
"min": 0,
"max": 65535
"value": 8449
"endpoint": 0,
"commandClass": 128,
"commandClassName": "Battery",
"property": "level",
"propertyName": "level",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Battery level",
"min": 0,
"max": 100,
"unit": "%"
"value": 100
"endpoint": 0,
"property": "isLow",
"propertyName": "isLow",
"ccVersion": 1,
"metadata": {
"type": "boolean",
"readable": true,
"writeable": false,
"label": "Low battery level"
"value": false
"endpoint": 0,
"commandClass": 132,
"commandClassName": "Wake Up",
"property": "wakeUpInterval",
"propertyName": "wakeUpInterval",
"ccVersion": 1,
"metadata": {
"type": "number",
"default": 43200,
"readable": false,
"writeable": true,
"label": "Wake Up interval",
"min": 600,
"max": 604800,
"steps": 600
"value": 43200
"endpoint": 0,
"property": "controllerNodeId",
"propertyName": "controllerNodeId",
"ccVersion": 1,
"metadata": {
"type": "any",
"readable": true,
"writeable": false,
"label": "Node ID of the controller"
"value": 1
"endpoint": 0,
"commandClass": 134,
"commandClassName": "Version",
"property": "libraryType",
"propertyName": "libraryType",
"ccVersion": 2,
"metadata": {
"type": "any",
"readable": true,
"writeable": false,
"label": "Library type"
"value": 3
"endpoint": 0,
"property": "protocolVersion",
"propertyName": "protocolVersion",
"ccVersion": 2,
"metadata": {
"type": "any",
"readable": true,
"writeable": false,
"label": "Z-Wave protocol version"
"value": "4.54"
"endpoint": 0,
"property": "firmwareVersions",
"propertyName": "firmwareVersions",
"ccVersion": 2,
"metadata": {
"type": "any",
"readable": true,
"writeable": false,
"label": "Z-Wave chip firmware versions"
"value": [
"32.2"
"endpoint": 0,
"property": "hardwareVersion",
"propertyName": "hardwareVersion",
"ccVersion": 2,
"metadata": {
"type": "any",
"readable": true,
"writeable": false,
"label": "Z-Wave chip hardware version"
"isFrequentListening": false,
"maxDataRate": 100000,
"supportedDataRates": [
40000,
100000
"protocolVersion": 3,
"supportsBeaming": true,
"supportsSecurity": false,
"nodeType": 1,
"zwavePlusNodeType": 0,
"zwavePlusRoleType": 6,
"deviceClass": {
"basic": {
"key": 4,
"generic": {
"key": 7,
"specific": {
"key": 17,
"commandClasses": [
"id": 49,
"name": "Multilevel Sensor",
"version": 7,
"isSecure": false
"id": 89,
"name": "Association Group Information",
"version": 1,
"isSecure": false
"id": 90,
"name": "Device Reset Locally",
"version": 1,
"isSecure": false
"id": 94,
"name": "Z-Wave Plus Info",
"version": 2,
"isSecure": false
"id": 112,
"name": "Configuration",
"version": 1,
"isSecure": false
"id": 113,
"name": "Notification",
"version": 4,
"isSecure": false
"id": 114,
"name": "Manufacturer Specific",
"version": 2,
"isSecure": false
"id": 122,
"name": "Firmware Update Meta Data",
"version": 2,
"isSecure": false
"id": 128,
"name": "Battery",
"version": 1,
"isSecure": false
"id": 132,
"name": "Wake Up",
"version": 1,
"isSecure": false
"id": 133,
"name": "Association",
"version": 2,
"isSecure": false
"id": 134,
"name": "Version",
"version": 2,
"isSecure": false
