I have made the changes that is required since the way of integration of webostv has changed. But im getting a config error:
Component error: webostv -
IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE!
Importing the numpy c-extensions failed.
- Try uninstalling and reinstalling numpy.
- If you have already done that, then:
1. Check that you expected to use Python3.7 from "/srv/homeassistant/bin/python3.7",
and that you have no directories in your PATH or PYTHONPATH that can
interfere with the Python and numpy version "1.18.1" you're trying to use.
2. If (1) looks fine, you can open a new issue at
https://github.com/numpy/numpy/issues. Please include details on:
- how you installed Python
- how you installed numpy
- your operating system
- whether or not you have multiple versions of Python installed
- if you built from source, your compiler versions and ideally a build log
- If you're working with a numpy git repository, try `git clean -xdf`
(removes all files not under version control) and rebuild numpy.
Note: this error has many possible causes, so please don't comment on
an existing issue about this - open a new one instead.
Original error was: libf77blas.so.3: cannot open shared object file: No such file or directory
So, how can I uninstall and reinstall Numpy (whatever it is) ?
Thanks to anyone that could help on this.
