Since HA 101.x, I have a weird problem with my Hue lights (1 bridge only, ca. 20 bulbs and lightstrips). I have an automation that kicks in every 10 minutes and adjusts the brightness and color temp during the day - it’s my own circadian light implementation.
This automation loops through all of my lights and applies a light.turn_on
to every light that is currently switched on. Everything was fine until I upgraded to HA 101. Since this upgrade I have lots of errors in my log like these:
2019-11-26 21:10:20 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 564, in async_request_call
await coro
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/hue/light.py", line 439, in async_turn_on
await self.light.set_state(**command)
File "/srv/homeassistant/lib/python3.7/site-packages/aiohue/lights.py", line 117, in set_state
json=data)
File "/srv/homeassistant/lib/python3.7/site-packages/aiohue/bridge.py", line 62, in request
'Invalid content type: {}'.format(res.content_type))
await coro
json=data)
File "/srv/homeassistant/lib/python3.7/site-packages/aiohue/bridge.py", line 69, in request
) from None
aiohue.errors.RequestError: Error requesting data from 192.168.1.33: [Errno 104] Connection reset by peer
Using trial-and-error, I found out that the light.turn_on
service stops working as soon as it is called with more than 7 entities in entity_id
. That’s also the reason why the errors only occur sporadically, i. e. every time 8 or more lights are switched on.
Can anybody confirm this behaviour? What has changed with HA 101?
Thanks in advance & best regards,
cicero22
