Lightify and Scenes... Just want warm white
I also struggled with this and solved it.
for non-rgb colors using the white light, you must be in “color_mode: color_temp” instead of “hs”
 supported_color_modes:
      - color_temp
      - hs
The rest of it was pretty straight forward.
I set the light in the scene UI and then just modified the YAML to change color_mode.
My full scene YAML:
light.eb4734acebb254704b5hab:
      min_mireds: 153
      max_mireds: 370
      - color_temp
      - hs
      brightness: 255
      hs_color:
      - 0
      - 0
      xy_color:
      - 0.323
      - 0.329
      color_temp: 370
      friendly_name: LAMPTAN jarton Bulb CCT+RGB 11w
      supported_features: 19
      state: 'on'
also, remember to reload YAML configuration for scenes, after you’ve made changes /config/server_control
Tried to get scenes working for ages. This worked wonderfully.
