Lights off when I leave home
No, do not get an error message, I will add the code of my sonoff.
switch:
  - platform: mqtt
    command_topic: "cmnd/keukenkastje/power"
    state_topic: "stat/keukenkastje/POWER"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
Does this switch work if you trigger it manually?
Yes, I can manually switch the lamp on or off.
And your switch ā€˜keukenkastjeā€™ is included in the group switches ?
Guys, the name of the automation is invalid, it has a space in it.
People,
It works! I was unable to respond because I was new and had reached my response limit
This is the code:
automation 19:
  - alias: 'Rule 2 - Away Mode'
      platform: state
      entity_id: group.telefoon
      to: 'not_home'
      service: switch.turn_off
      entity_id: group.all_switches
But now I want the code that causes the lights to come on again when we get home, is only active between sunset and 11:30 PM. I tried everything but keep getting error messages.
Could you please your non-working code and the errors?
Try this:
automation 19:
    - platform: state
      to: 'not_home'
    condition:
    - condition: sun
      after: sunset
    - condition: time
      before: "23:30:00"
    - service: switch.turn_off
You do not believe it but I put ā€˜conditionā€™ between you and suddenly no more error messages, very strange!
This is de code voor coming home:
automation 20:
      platform: state
      to: 'home'
    condition:
    - condition: sun
      after: sunset
    - condition: time
      before: "23:30:00"
      service: switch.turn_on
      entity_id: switch.staandelamptv, switch.staandelampbank, switch.keukenkastje, switch.eettafellamp
I donā€™t know what you mean with ā€œI put ā€˜conditionā€™ between youā€¦ā€ but Iā€™m glad it works now :slight_smile:
My thanks are very big, now on to the next problem haha, but Iā€™ll make a new topic for that!
I believe he was speaking about his first code didnā€™t have any conditions just trigger and action
