No, I use the Supervised version of HA so never got round to it.
I did MANY MANY years ago have a proxy running as back then it was the only way to get Lightwave running, I may if I get time look back and see if I can run-up another Pi (unless you have a better suggestion)
I could send a version of the proxyless code over, if you want to try it.
You have to install manually in the custom_components folder.
It works on my live system, but am seeing issues in my development version due to a race condition.
So no idea how well it will perform (until I find time to fix the race condition).
Yes that would be helpful, am not sure what you mean by race condition but I would be happy to provide feed back on my system performance (8Gb RPi 4). I may need some basic guidance on installation
Here is the code I am using for proxy-less operation in my live environment…
There is a known issue - you may see error messages in your logs when trying to turn switches on/off or change a TRV setting. However 99% of the time the operation will have worked - the error is incorrect. I am working on a resolution.
Once resolved I’ll make a PR into the main HA integration.
Thats Great, all working including the errant TRV, and yes I get the error as described in the logs.
A couple of questions.
the actual sensor (sensor.room_heating) what is this ? I assumed it was battery percentage but it seems odd as I get readings from 93 to 142%.
If this is not the battery sensor is there a possibility of adding it ?
That’s good news. I’ll post here when I fix the error messages (not high on my priority if I am honest - a rainy day job).
The sensor is a guess at the battery level, based on the voltage reading. I occasionally see 110%, but never as high as 142. It’s not a great measure but does give the ability to detect when they may need changing. I have an automation that pops an alert when less than 30%
@Hunterdiver I think I have fixed the error messages.
If you download the latest version form my temporary repo and give it a try, I’d be most grateful.
I may have found an issue. It appears to conflict with the Lightwave Energy Monitor from HACS, I noted that it had (Monitor) stopped reporting, and a quick look showed it stopped around the same time I installed your test files.
I removed your files from Custom Components and the Monitor started reporting again.
I replaced your files and the monitor stopped working …
I don’t use the energy monitor, but I can see there being a conflict if it also listens for UDP requests. Both are likely to use the same TCP PORT to listen on.
The monitor guys will probably need to make a change to set the socket option to reuse the port.
Do you which GIT repo their code uses, we can raise an issue and suggest a fix.
I have changed the file as suggested, I tried inserting the Middle line and restarted this did not work.
I then copied all 3 lines over the existing 2 (just in case) but it still did not work.
If this does not work, then we have a fundamental problem that the two cannot work together.
They both try to get the broadcast network data on the same port used by the Lightwave hub.
I don’t know enough about Python threading, but had hoped the SO_REUSEPORT option would allow both to get the data - but your tests suggest not.
I thank you for all your help, and guess I’ll have to wait for folks wiser than I to see if a solution can be found, For now the TRV info is more useful than the monitor :).
If I can be of any help in the future (for anything) please feel free to give me a shout …
