Below is a simple Node Red flow to purge and repack the database.
It uses a BigTimer as scheduler. This does nothing other than kick off the flow at regular intervals, so you can replace it with your scheduler of choice. This example runs at 1am on Sunday, and purges the db with a retention period of 7 days (keep the latest 7 days of data).
On completion it sends a notification to HA to visualize the background process. Remove the respective nodes if this becomes annoying after a while.
[{"id":"1cf76219.6c9a4e","type":"api-call-service","z":"7f52f4e2.25e814","name":"Purge (7 days)","server":"112d9be2.b9d714","version":1,"debugenabled":false,"service_domain":"recorder","service":"purge","entityId":"","data":"{\"keep_days\": \"7\"}","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":420,"y":860,"wires":[["86d6a0f2.8c265","b0f83d37.f6525"]]},{"id":"86d6a0f2.8c265","type":"debug","z":"7f52f4e2.25e814","name":"PURGE","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":580,"y":820,"wires":[]},{"id":"63595202.9b5c4c","type":"inject","z":"7f52f4e2.25e814","name":"Do Purge & Repack","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":170,"y":820,"wires":[["1cf76219.6c9a4e"]]},{"id":"b4e17d86.5d4e1","type":"api-call-service","z":"7f52f4e2.25e814","name":"Purge - Repack","server":"112d9be2.b9d714","version":1,"debugenabled":false,"service_domain":"recorder","service":"purge","entityId":"","data":"{\"repack\": \"true\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":760,"y":860,"wires":[["98a6e148.976c7"]]},{"id":"b0f83d37.f6525","type":"delay","z":"7f52f4e2.25e814","name":"","pauseType":"delay","timeout":"10","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":600,"y":920,"wires":[["b4e17d86.5d4e1"]]},{"id":"fd694d23.a8465","type":"comment","z":"7f52f4e2.25e814","name":"Purge and Repack HA database","info":"- Use a BigTimer as scheduler\n- Scheduled to purge at 1am on Sunday\n- Set to purge 7 days data\n- Set Longitude and Latitude for your location!\n- Sends notification to HA on completion\n","x":150,"y":740,"wires":[]},{"id":"3e60b9e.d348d46","type":"bigtimer","z":"7f52f4e2.25e814","outtopic":"","outpayload1":"on","outpayload2":"","name":"HA Purge - Sun 01:00","comment":"","lat":"52.3676","lon":"4.9041","starttime":"60","endtime":"75","starttime2":"0","endtime2":"0","startoff":"0","endoff":"0","startoff2":"0","endoff2":"0","offs":0,"outtext1":"","outtext2":"","timeout":1440,"sun":true,"mon":false,"tue":false,"wed":false,"thu":false,"fri":false,"sat":false,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"day1":0,"month1":0,"day2":0,"month2":0,"day3":0,"month3":0,"day4":0,"month4":0,"day5":0,"month5":0,"day6":0,"month6":0,"day7":0,"month7":0,"day8":0,"month8":0,"day9":0,"month9":0,"day10":0,"month10":0,"day11":0,"month11":0,"day12":0,"month12":0,"d1":0,"w1":0,"d2":0,"w2":0,"d3":0,"w3":0,"d4":0,"w4":0,"d5":0,"w5":0,"d6":0,"w6":0,"xday1":0,"xmonth1":0,"xday2":0,"xmonth2":0,"xday3":0,"xmonth3":0,"xday4":0,"xmonth4":0,"xday5":0,"xmonth5":0,"xday6":0,"xmonth6":0,"xd1":0,"xw1":0,"xd2":0,"xw2":0,"xd3":0,"xw3":0,"xd4":0,"xw4":0,"xd5":0,"xw5":0,"xd6":0,"xw6":0,"suspend":false,"random":false,"randon1":false,"randoff1":false,"randon2":false,"randoff2":false,"repeat":false,"atstart":false,"odd":false,"even":false,"x":160,"y":880,"wires":[["1cf76219.6c9a4e"],[],[]]},{"id":"98a6e148.976c7","type":"function","z":"7f52f4e2.25e814","name":"Prep Notification","func":"var runtime = new Date().toLocaleString();\nvar finalmsg = msg.payload.domain + \".\" + msg.payload.service + \"\\n\\n\" + runtime + \"\\nPurged \" + msg.payload.data.keep_days + \" days data.\" \n\nvar newpayload = {\n \"data\":\n {\n \"message\": `${finalmsg}`,\n \"title\": \"HA Database Purge\"\n }\n}\n\nmsg.payload = newpayload\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","x":940,"y":920,"wires":[["a3fde5e3.c7ad88"]]},{"id":"a3fde5e3.c7ad88","type":"api-call-service","z":"7f52f4e2.25e814","name":"Notify HA (Persistant)","server":"112d9be2.b9d714","version":1,"debugenabled":false,"service_domain":"notify","service":"persistent_notification","entityId":"","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1100,"y":860,"wires":[[]]},{"id":"112d9be2.b9d714","type":"server","name":"Home Assistant","legacy":false,"addon":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
