I see! Thanks.
It should probably be spelled out in the documentation.
I see! Thanks.
There’s an “Edit” link in the top right corner.
So, is there any options to use night mode in script for automation…
My current script:
Open LED light
- id: ‘31’
alias: Open LED light (dark + 1h)
platform: sun
event: sunset
offset: “01:00:00”
service: light.turn_on
brightness: 1
rgb_color: [255, 255, 255]
entity_id:
- light.Zunaj
Thank you for your answer…
I was thinking, that instead of brightness that I use Effect: night, which is the night mode…
Right, that’s the way to do it.
But how to use it? If I write Effect: nightmode I got error…
Just effect: night
should work.
And in this case brightness is not important? In other words, instead of brightness I write effect?
Example which is working 100%:
Prižgi LED luč: ZUNAJ
- id: ‘32’
alias: ZUNAJ - prižgi LED (tema + 2h)
platform: sun
event: sunset
offset: “02:00:00”
effect: night
entity_id:
- light.Zunaj
In case of effect usage there is no need for:
brightness: 1
Thanks for the reminder. I inserted a section describing night
effect.
