hi can you controll two desks with one esp32? i see a way to modifying the ID for the other components except the idasen_desk_controller component
i’m afraid, a lot of users (including me) are facing issues with the ble_client in ESPHome connecting to idasen’s controller. it just connects, but does not pair. the desk keeps blinking even after connecting and then the esphome logs show it got disconnected and then cannot connect as the desk goes out of pairing mode. this situation stays the same irrespective of whether wifi is enabled or not.
using a nodemcu esp32s board (ai thinker).
@j5lien please help whenever you get back from vacation
UPDATE: finally got it work by using github://j5lien/[email protected]
Excellent find. Just for completeness can you post your working config?
sure this is my full working config. bluetooth_callback does not work. if enabled, this component will go into an infinite loop when trying to move the desk to a set position because it is not receiving any BLE notifications from the desk about its height. so just set it to off and then the component will get height from the same service characteristic which is used to change the height.
esphome:
platform: ESP32
board: esp32cam
logger:
# Enable Home Assistant API
api:
password: ""
ota:
password: ""
wifi:
ssid: "foobar"
password: "barfoo"
external_components:
- source: github://j5lien/[email protected]
idasen_desk_controller:
# Desk controller bluetooth mac address
# Required
mac_address: "C2:6F:1C:B7:D0:F9"
# Use bluetooth callback to update sensors and cover entities
# Deactivate this option when data are not correctly updated when using the cover entity
# Optionnal (default true)
bluetooth_callback: false
cover:
- platform: idasen_desk_controller
desk_height:
# Height in cm
# Millimeter precision
accuracy_decimals: 1
binary_sensor:
# Desk bluetooth connection
name: "Desk Connection"
type: CONNECTION
# Desk moving status
type: MOVING
Thanks @j5lien for writing this integration. I did a few issues like other trying to get ESPHome to talk to the Linak controller but after a few hours (days). I was able to get the integration working perfectly with Home Assistant.
My Steps:
I know some people have had issues with different versions of ESP32, I purchased mine off Amazon (https://www.amazon.com.au/gp/product/B097DCN76N/) and seems to work perfectly.
I had lots of issues with paring the desk using “esp32_ble_tracker” component. So, I switched to the older version which uses the BLE Arduino library. I found the mac address of the desk using an android application “BLE Scanner” and paired the desk to the ESP32. Once the pairing process was complete and I could control the desk. I switched to the latest version that uses esp32_ble_tracker and the connection has been rock steady.
Code for paring:
esphome:
platform: ESP32
board: esp32dev
libraries:
- "ESP32 BLE Arduino"
# Enable logging
logger:
wifi:
ssid: !secret IoT_ssid
password: !secret IoT_password
# Enable fallback hotspot (for captive portal) in case wifi connection fails
ap:
ssid: "ESPHome $friendly_name"
password: !secret ap_password
api:
password: !secret api_ota_Password
ota:
mac_address: "00:00:00:00:00:00"
desk_height:
binary_sensor:
type: CONNECTION
type: MOVING
cover:
Once paring is complete and the desk responds to ESP Home/Home Assistant, update the code to the latest version:
esphome:
platform: ESP32
board: esp32dev
substitutions:
friendly_name: Sam Idasen Desk
# Enable logging
logger:
wifi:
ap:
api:
ota:
esp32_ble_tracker:
globals:
# To store the Desk Connection Status
- id: ble_client_connected
type: bool
initial_value: 'false'
ble_client:
- mac_address: "00:00:00:00:00:00"
on_connect:
then:
# Update the Desk Connection Status
- lambda: |-
id(ble_client_connected) = true;
- delay: 5s
# Update desk height and speed sensors after bluetooth is connected
- lambda: |-
id(desk_height).update();
id(desk_speed).update();
on_disconnect:
then:
- lambda: |-
id(ble_client_connected) = false;
ble_client_id: idasen_desk
only_up_down_command: false
cover:
# Desk Height Sensor
- platform: ble_client
name: 'Sam Desk Height'
service_uuid: '99fa0020-338a-1024-8a49-009c0215f78a'
characteristic_uuid: '99fa0021-338a-1024-8a49-009c0215f78a'
icon: 'mdi:arrow-up-down'
unit_of_measurement: 'cm'
update_interval: never
notify: true
filters:
- offset: 0.33
lambda: |-
uint16_t raw_height = ((uint16_t)x[1] << 8) | x[0];
unsigned short height_mm = raw_height / 10;
return (float) height_mm / 10;
# Desk Speed Sensor
name: 'Sam Desk Speed'
icon: 'mdi:speedometer'
unit_of_measurement: 'cm/min' # I'm not sure this unit is correct
accuracy_decimals: 0
notify: true
lambda: |-
uint16_t raw_speed = ((uint16_t)x[3] << 8) | x[2];
return raw_speed / 100;
binary_sensor:
# Desk Bluetooth Connection Status
name: 'Sam Desk Connection'
lambda: 'return id(ble_client_connected);'
# Desk Moving Status
name: 'Sam Desk Moving'
lambda: 'return id(desk_speed).state > 0;'
Thanks so much to @j5lien for his library and esphome compatibility!
Finally! This work around made my project finally working!
I transformed this old 70s alarm clock, to my preset, controller idasen desk.
Thanks a bunch Sam. Your method worked for me as well! However, when I update ESPHome (Docker) to the latest version, my desk is in an infinite loop and I cannot control it anymore. However, when I stay at 2021.10.0 no problems at all, but I can’t see the desk height or desk speed… Are you having the same problems?
Hi Justin,
I am not having any issues with mine. Seems to work well and very responsive.
Regards,
Sam
Since my message to you, I’ve downgraded to 2021.10.0 and upgraded back again to the latest tag. Everything’s running buttery smooth now, I can see the heights and I even mapped a W2049 Ikea controller to the desk via ControllerX. This feels so next level instead of relying on an app (oh the irony with HA) or the desk controller itself.
When i try loading it i get error [15:06:17][W][idasen_desk_controller:104]: Error reading char at handle 26, status=5 and i dont know why, it seems to be an authentication error
i tried using 1.2.0 but i get the error “idasen_desk_controller is not a correct platform” and “This component requred ble client”
In case anyone is looking for a solution NOT using an ESP32 device, but rather a good old bluetooth dongle, I’ve built this https://github.com/maxime1992/linak-2-mqtt which let me integrate with HA and the linak desk card. All the info should be written in the README
I have tried the below configurations and the desk has stopped moving up (only down).
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
api:
ota:
password: "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Idasen Fallback Hotspot"
password: "ym47kfFy6eEl"
esp32_ble_tracker:
ble_client:
- mac_address: "D9:B7:84:82:99:0F"
cover:
Full logs are published here https://github.com/j5lien/esphome-idasen-desk-controller/issues/43
Appreciate your help!
sorted by going all the way down
i tried setting this up and got the error Error reading char at handle 26, status=5
Can you please help? Error reading char at handle 26, status=5 · Issue #42 · j5lien/esphome-idasen-desk-controller · GitHub
probably your desk is stuck and need to be reset.
Unplug, wait some seconds, plug again and set all down, than all up.
More info here: My Standing Desk Only Goes Down: How-To Reset Your Desk - YouTube
I’m having a problem with my Linak tv lift (which is basically a desk) I followed the installation but I can’t get the lift to move. In the log i see [10:33:58][D][idasen_desk_controller:217]: Update Desk - Move from 100 to 0
a lot, but it just doesn’t move! Can anybody here help me?
The full log is: INFO Reading configuration /config/esphome/tv-lift.yaml...INFO Starting log ou - Pastebin.com
Can these integration be updated using new Bluetooth integration since 2022.8?
