I have 38 input_booleans and I’m a newbie; I will surely wind up with many more. Mostly I use them to create cards that open and close on a click, so I can have menus and fast navigation. I initially created them using UI helpers, but I want a few on initially and prefer semantic names, so I moved them to configuration.yaml. Is there a way to create a yaml file that lists all my input_booleans and is read by configuration.yaml, to declutter configuration.yaml, along the lines of scripts.yaml?
I realize HA would like us to use the UI helpers, but it doesn’t handle copying existing input_booleans, or on by default, AFAIK.
Create a new file containing all of your existing Input Boolean configurations. Let’s assume the new file’s name is input_booleans.yaml. Ensure input_boolean: is not included on the first line (or anywhere else) in that file.
In your configuration.yaml file remove all Input Boolean configurations and change it to this:
input_boolean: !include input_booleans.yaml
Go to Developer Tools > YAML and run Check Configuration. If it passes, restart Home Assistant.
After it starts, go to Developer Tools > States and confirm all your Input Booleans are present.
Please consider marking my post above with the Solution tag. It will automatically place a check-mark next to the topic’s title which signals to other users that this topic has been resolved. This helps users find answers to similar questions.
