List of valid "unit_of_measurement" options?
This does not seem to be true for long term statistic see problem reported here
To historize the states of my Venstar thermostat attribute: hvac_action
what unit_of_measurement should be used for different text strings like idle, cooling, etc.?
So far, with this configuration:
HVAction
when I pull it up in history it’s trying to trend a numerical value.
To clarify, the variable is acquiring the data:
HVACTION1
But the history is either not being stored or retrieved properly:
HVACTION2
Is unit of measure the problem, or something else?
Ideally, the trend would show up like the weather forecast:
HAWF
if you add a unit of measurement, it attempts to graph it. So don’t add a unit of measurement.
That’s it, THANK YOU!!!
HVACTION3
i have a similar issue. i have no uom but i still see a line graph. any thoughts?
that’s the only thing that causes it unless something changed recently.
Would state_class: being present perhaps cause this behaviour too?
It could. To be honest, I haven’t been paying attention to those details lately.
This doesn’t make sense. Does it mean that Home Assistant only supports dollars, euros and cents as currency unit of measurements? What about the rest of the world?
And if you want graphs, but there simply isn’t a unit of measurement for the data (ratio’s, dimensionless numbers, …), you can add a blank unit of measurement:
unit_of_measurement: “”
this answer does not seem to be valid anymore with 2023-05 they “assume” a numeric value and cast it to decimal, what causes an exception, what causes the sensor to dispaly “unknown”.
There seems to have been a breaking change
Not sure what you’re talking about. The solution is still valid as is the information in this post. If your value is numeric, add a unit_of_measurement and the information will be graphed.
Since 2023.5.0, several people have reported that their Template Sensors now indicate unknown (as opposed to previous versions). It appears that the rules for how unit_of_measurement is handled have become more strict. Given that Template Sensors are no longer behaving like they did in the past, it’s effectively an undocumented breaking change.
Another user believes this may be the PR responsible for the new behavior (tagged as a ‘Code quality improvement’) :
Right, but that doesn’t change the solution to this thread, which is what I’m referring to. If you put a unit_of_measurement on a sensor, it will turn it into a graph. The original question was “what do I place on a voltage sensor” and the answer was “v”. None of that has changed…
Also, if you output None instead of 'unkonwn' or 'unavailable' in your template sensors, then you’ll avoid this strictness. That’s the proper way to set a sensor to unknown or unavailable. The other option is to use availability templates (which sets None under the hood).
We ended up finding a series of issues in Beta with this change. Properly created template sensors would be unaffected. When you explicitly set a numeric sensor to a string state, you’ll get this error.
I’m not disputing the Solution, just pointing out that 2023.5.0 does appear to handle unit_of_measurement differently from previous versions. It wasn’t documented in the Release Notes so CybDis has reason to speculate “There seems to have been a breaking change”.
Perhaps the Release Notes should have said something like:
In previous versions, unit_of_measurement allowed for non-numeric values (even though it should not have) but that loophole has been closed. Only numeric values are permitted.
Hi all, this seems like the right place to ask a follow-up question to this
Usecase: I have made a scale for my watersoftener with loadcells, a HX711 amplifier, an ESP32 running Tasmota. It’s integration creates these 3 values in HA:
While the weight is fine as it has a UOM (kg), I’d like to be able to graph the two others, WeightRaw and AbsRaw. Editing the entity in HA does not allow me to add a UOM, thus its reported as a history:
TLDR; short of creating a derived template sensor off this one, is there a way to add a missing UOM to a sensor from an integration, or does this have to be done by the integration, in this case Tasmota?
you can add a uom via customize.yaml
Perfect! That did the trick
For reference, I added the below to my customize.yaml, reloaded the Location & Customizations in Dev.Options, restarted the Tasmota integration, and now there’s this guy named Bob claiming he’s a relative :slight_smile:
sensor.garage_controller_ne_hx711_weightraw:
  unit_of_measurement: "raw"
sensor.garage_controller_ne_hx711_absraw:
I don’t know how to keep my UoM “Entitäten” because the sensor rendered “unknown” once updated to HA Core 2023.5.
Any chance to restore that former behavior?
Usually I don’t care, it’s just because InfluxDB can not connect the dots anymore (UoM changed from “Entitäten” to “” (nothing)) as the very first emergency task because of this undocumented breaking change (… few words of frustration here…) was to simply remove the UoM:
