Hi I bought the same device as several other here: Amazon.de
Were you ever able to get it working?
And if so would you like to share your settings (EW11 - serial and communication settings) and Home Assistant configuration.yaml
Also is A to + and B to - correct?
I can see something happening under Status page “frames/bytes received” but nothing goes into Home Assistant at the moment.
Hej.
Har precis fått in min LK golvvärme i HA enligt dina instruktioner och det verkar funka.
En fråga, vad gör binary sensor i koden för något? Märker ingen skillnad om den ligger där eller inte. Går det att få till batterinivå på dom termostater som jag har trådlöst?
Mvh Jonny
Hej
Kul att att lösningen kommit till användning igen. Min egen styrning har tickat på i ett par år utan handpåläggning så jag hade nästan glömt bort den.
Binary sensors visar digitala 1/0-parametrar. I detta fall om ventilen är öppen eller stängd.
Jag måste gräva fram dokumentationen från LK om det går att läsa batteri-status någonstans. Har själv trådanslutna termostater så jag har nog aldrig tänkt på saken.
Återkommer…
I got 100%. I will test with bad batteries tomorrow if i can find some,
The status from the binary sensor doesen´t work.
I can´t find what´s wrong.
do you know if i can have the usb dongle and the gateway connected together?
This sounds very much like what I’m interested in. I just realized I might be able to control my LK system from Homey or HA. I know my way around a raspberry pi and controlling things, but modbus is new to me. I was hoping you might give me a head start on finding code and hardware by piggybacking of your setup.
(Ignore that I’m referencing different sensors in the climate entity, I’ve got 10 ics.2 and copy-pasta is no fun from a phone)
I haven’t looked into doing post to the webserver as I tend to just let it roll (for now) - but there is some JavaScript files one can have a look at if you check out the webserver in developer mode in your browser, and I’ve seen a call to a cgi file which I guess one could replicate with a simple curl command
