jono
(Jono)
1
Now that themes are now possible in Home Assistant, is it possible to load different themes by activating scripts?
I’m thinking along the lines of below, but not sure how to do it ‘properly’
script:
theme_graphite:
- service: homeassistant.set_theme
entity_id: theme.graphite
PtP
(Mike)
2
@jono
I am using it in an automation so you might be able to use it in a script.
- alias: Set Theme
platform: homeassistant
event: start
service: frontend.set_theme
jono
(Jono)
3
Yes, I’ll be able to create a script from this.
Thanks a lot!
