There activate the logger. What I notice is that when I switch from HA esphome detects the change in the variable. So with this I realize that the problem is HA and not esphome. Because when I restart HA, the variables remain with the default value, which is 28, and not with the last one that I modified. So I don’t know if when I restart HA I would have to ask esphome what the values of the variables are or if it works in another way.
It occurs to me that perhaps instead of cobbling together a thermostat using scripts, you could implement an actual heater thermostat in ESPHome and expose it to Home Assistant as that rather than as relays.
climate:
- platform: bang_bang
icon: "mdi:fishbowl"
sensor: temp
default_target_temperature_low: 27.5 °C
default_target_temperature_high: 28.5 °C
visual:
min_temperature: 20 °C
max_temperature: 30 °C
temperature_step: 0.1 °C
heat_action:
- switch.turn_on: relay_2
- switch.turn_on: relay_3
idle_action:
- switch.turn_off: relay_2
- switch.turn_off: relay_3
@Pablo_Gustavo_Fiscel If I understand correctly, it’s the reboot of the esphome node. The number resets to the default but that does not match the global value stored. Add this to the esphome:
section of your config file.
esphome:
on_boot:
priority: -100
then:
- number.set:
value: !lambda 'return id(temp_max);'
- number.set:
value: !lambda 'return id(temp_min);'
@simondotau The problem with the thermostat is meeting the condition that it is, below/above the set point for 5 min before turning the heater on/off.
Would you know how fast the bang-bang thermostat kicks in? Is it instant or is there a delay?
The point is that a climate component is fit for purpose and gives you the right interface in Home Assistant. With bang_bang the actions are instantaneous, but if arbitrary delay is a requirement you can implement that as scripts in a similar way to how others have proposed.
I’m confused why you’d want the heater to run for an arbitrary five minutes after reaching the target instead of just setting the target slightly higher. You really ought to check your requirements because I’m quite sure a delay isn’t necessary. Just set your temperatures and allow hysteresis to do its thing.
If your temperature probe is noisy/unreliable, use filters to exclude spurious data.
The Thermostat Climate Controller — ESPHome has hysteresis and is probably better for this.
Thermostat supports combination heating-cooling systems but requires hysteresis to be hard-coded.
Bang_bang supports dynamically adjustable hysteresis points but only supports either heating or cooling. Given that the requirement is to control a heating element, it is more suited to this task.
it was already discussed
That doesn’t matter. So long as the sensor is measuring the correct thing, it doesn’t matter if heat is injected into the water directly or from a distance. If anything, this would be reasonable justification for turning the heating off early rather than after a delay. It’s certainly not reasonable justification for adding more unnecessary delays to the thermostat operational cycle.
uff. I have a lot to read and to change. I think that implementing a climate is what best suits what I need and the code is smaller and more verbose. Thanks for the answers
If you wanted to maintain the temperature between 28.3 and 28.5, you should also activate the cooler and turn off the heater there, right? Because at low temperature it turns on the heater but then it is not turning it off. Now change the code and leave it like this but when I put a thermostat in UI, the maximum and minimum values are 0.5 between them. I don’t know if what I’m doing is right.
climate:
- platform: thermostat
sensor: temp
default_target_temperature_low: 28.3 °C
min_cooling_off_time: 300s
min_cooling_run_time: 300s
min_heating_off_time: 300s
min_heating_run_time: 300s
min_idle_time: 30s
heat_deadband: 0.2
cool_action:
heat_action:
idle_action:
Thermostat is more complicated to implement than bang_bang and its advantages are minimal if you don’t actually need the cooling integrated. You can have a second, separate bang_bang climate entity to automate your cooling fan.
If you do stick with thermostat, your off_time and run_time settings should be much shorter (e.g. 5s) as you are not operating a gas furnace or similar which has mechanical issues with short cycling. You’re using electric resistive heating, so short cycling is desirable. Allow hysteresis to do its thing.
You have set the default cooling and heating to be extremely close. I don’t know anything about fish but it seems unlikely that 0.2 degrees is the difference between freezing them and and boiling them. Plus it’s a ridiculous setting if you’re then going to force your heater to be on for an arbitrary five minutes.
Your cool action needs to switch off the heater, the heat action needs to switch off the cooler, and the idle action needs to switch off both.
Perfect. Thanks Friend. I am going to leave the firmware configured as a thermostat since it is more verbose.
Hello friends. I have a problem with the sensor. Unfortunately climate is what I was looking for but it didn’t always work. At times the temperature exceeded the limit and did not cut or did not turn on. I decided to go back to the old code that worked and the same thing is happening to me. Please. Someone help me to see what the problem is. I would really appreciate a little more help. Thank you
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
level: VERBOSE
# Enable Home Assistant API
api:
ota:
password: "0664f60f6c5f7f8fe07e26bf0b9e1eac"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "meteo_ap"
captive_portal:
esp32_ble_tracker:
dallas:
- pin: GPIO23
globals:
- id: temp_max
type: float
restore_value: yes
initial_value: '28.5'
- id: temp_min
type: float
restore_value: yes
initial_value: '28.3'
number:
name: "Set max temp"
optimistic: true
min_value: 28.0
max_value: 29.0
step: 0.1
on_value:
- globals.set:
value: !lambda 'return id(temp_max_set).state;'
name: "Set min temp"
optimistic: true
min_value: 28.0
max_value: 29.0
step: 0.1
on_value:
- globals.set:
value: !lambda 'return id(temp_min_set).state;'
binary_sensor:
lambda: |-
if (id(temp).state >= id(temp_max)) {
return true;
} else {
return false;
on_state:
if:
condition:
for:
time: 5min
condition:
binary_sensor.is_on: maxs
then:
lambda: |-
if (id(temp).state <= id(temp_min)) {
return true;
} else {
return false;
on_state:
if:
condition:
for:
time: 5min
condition:
binary_sensor.is_on: mins
then:
#climate:
# - platform: thermostat
# name: "Termostato acuario"
# sensor: temp
# default_target_temperature_low: 28.3 °C
# default_target_temperature_high: 28.5 °C
# min_cooling_off_time: 90s
# min_cooling_run_time: 90s
# min_heating_off_time: 90s
# min_heating_run_time: 90s
# min_idle_time: 30s
# heat_deadband: 0.2
# cool_action:
# - switch.turn_off: relay_2
# - switch.turn_off: relay_3
# heat_action:
# - switch.turn_on: relay_2
# - switch.turn_on: relay_3
# idle_action:
- platform: dallas
address: 0x630516b54fc2ff28
name: "Temperatura acuario_principal"
filters:
- offset: 1.0
- platform: dht
pin: GPIO33
temperature:
humidity:
update_interval: 60s
- platform: pvvx_mithermometer
mac_address: "A4:C1:38:7B:D2:35"
temperature:
name: "Temperatura cuarto principal"
accuracy_decimals: 1
humidity:
name: "Humedad cuarto principal"
accuracy_decimals: 0
battery_level:
name: "Nivel de Bateria cuarto principal"
switch:
- platform: gpio
pin: GPIO27
inverted: true
restore_mode: ALWAYS_OFF
- platform: gpio
pin: GPIO26
inverted: true
- platform: gpio
pin: GPIO25
inverted: true
- platform: gpio
pin: GPIO5
inverted: true
- platform: gpio
pin: GPIO18
inverted: true
- platform: gpio
pin: GPIO19
inverted: true
- platform: gpio
pin: GPIO21
inverted: true
- platform: gpio
pin: GPIO22
inverted: true
the condition is fulfilled but it does not turn off the relays
Could it be an identification problem? It doesn’t make sense.
Has it been fulfilled for 5 minutes?
This worked fine like this. But I programmed it with a climate because the code was more verbose. The problem is that the climate did not always work and that is why I decided to go back to the initial code that with those 5 minutes worked well.
remove the 5 minute condition. It worked once so I’m going to wait a while to see how it goes
