Puh, now you create ideas
From a development POV I would love to do the ultimate configuration option, but based on the complexity of its range of settings and my experience with half educated users this may create unnecessary headache and should be IMHO, if, a subbutton aka Advanced Settings.
But should we really be able do disable mDNS? From my technical point of view more and more “smart” and not so smart devices will support it, Apple pushed it not just into home network but also into enterprise networks, and as it can co-exist I do not see an advantage when it is disabled - except maybe some less noisy network.
I know that the RFC meanwhile reserved .local for mDSN, Apple for example integrated in a way that it does not interfere with a mydomain.local additionally in place. The key is to respect the name server(s) for each zone and one of them can be the mydomain.local.
You may disable the possibility to set a XYZ.local domain but from my POV this is not needed, because in that solution they do not interfere and co-exist. And the interface does not prevent me from adding a wrong IP address, some certain idiocracy/liberty may be left on the user’s shoulders. In this case I can imagine that either a good quick start manual for settings with DHCP, own DNS and own domain can resolve many issues. I am up for that docu work as well.
Regarding your clarification. I understand that the FB is not involved in mDNS, and neither should be the local domain. I read through the possible configuration options of core DNS and found often in examples and sites about coreDNS the way of answering a specific zone with a forward to certain DNS servers, which I then adapted. Also, I addressed that in many configurations people do not run a TLS enabled server at home, but a simple bind or dnsmasq on their routers, NAS or small hypervisor, but I already thought about the button under the Domain Name: Enable DoH or DoT and Hostname
Yes, the authority for .local is mDNS, which does not exclude possible authority of mydomain.local to another NS, each subdomain can have its own name server(s).
Regarding possible solutions in case of (mis-)configurations. Improper DNS setting ruin pretty much everything, that’s clear. What could go wrong? Assuming we have the new “domain name” option under supervisor - system - network:
- User enters .local as domain, system says .local is not allowed because of mDNS
- User enters domain.local but his domain is called mydomain.local and therefore his DNS server refuses to answer for example esp-kitchen.domain.com and all other internal requests will end in NXDOMAIN and the log will contain
172.30.32.1:57044 - 24079 “A IN espkitchen.domain.local. udp 38 false 512” NXDOMAIN qr,aa,rd 52 0.011588231s
and obviously many other NXDOMAIN…
- user enters his correct mydomain.local and DNS queries to his domain are served as well as mDNS.
A handy reset network settings button could be helpful. Resetting to DHCP or a new manual address and just restoring the original config, applying the newly entered settings and rewriting the domain (if applicable) into corefile… hm, is there some way of loading files for zone info, but a quick google did not bring too much on split config or load additional configs - it would be nice to not touch the corefile at all but load the zone forwarder additionally if needed. I will try to find a way for that or do you know?
What do you think, leaving everything as it is, just adding DNS forward for the domain set to the NS set?
And yes, I would PR that, I just need help connecting the supervisor UI to the config files…
And I maybe would ask extensively the users if they want it that way, I am experienced in heterogenous networks but I may miss a certain constellation that is very well in use and it could be taken care of.
