Of course, this is a terrible practice and if the hostname works from inside the network use it. Your connection remains local, connecting to the router and back to HA.
If you connect directly to HA, correct. If you connect using the DuckDNS/whatever hostname then no.
But in this scenario I can’t distinguish internal and external connection. Is there any way to do that?
I mean I don’t want my kids to access home assistant from outside, only when they are at home.
Before https it was easy with two address (internal and external) but I had to leave port open and unencrypted.
Now with https I can only use one address for both internal and external address and therefore unable to restrict control from internal and external IP.
