Are you using SSD or SD-card?
SSD will make a huge diff when saving images/files…
Question:
Im thinking about creating a new instance of HA and move Frigate to that PC and use HA remote integration …
Will it work with snapshots and nabucasa?
It will be a 10x speed improvement for inference AND it will eliminate all the CPU usage spikes for object detection. Inference speeds of 130ms can’t add more than 130ms to the notification delay except that it often requires multiple runs of object detection to narrow in on the object in question. This may cause skipping of frames and make it take longer to confirm the object is not a false positive.
Updates are posted to the mqtt topic as better images are found in subsequent frames. Take a look at the event type field to limit it to the initial detection or the end of the detection. Also, see the blueprint posted recently.
That lines up to my 17-19ms with a single USB Coral on a Pi4. Pre-ordered the PoE+ Hat (switch is already PoE+ complaint) so I can run a pair + a USB NVMe hopefully.
I use a SSD.
So maybe the delay comes from skipped frames. The coral should bring a improvement right?
Sorry but I am not that good with mqtt. I understand that there is a event which is only fired once, but how can I change the automation to that?
I think the problem is, that your example automation is replaced when the automation is fired multiple times. Introduction | Home Assistant Companion Docs
The other notification is a critical notification, so it isn’t replaceable. Will test it tomorrow.
Then I still need a workaround for critical notifications. Maybe clearing the old notification before sending the new.
I’m already running the pi4 8gb with the poe hat and coral usb, it works. I’m also using a data ssd. I will be curious to know if poe will be suitable to run another usb coral…
Btw, my main pain is that the pi4 can’t manage the hw accell for the h.264 when the resolution is higher then 1080p (thank you to @mr6880 to spot on that)
So, if you want to use hw acc and keep low cpu usage you have to work with 1080p, if you want to use higher resolution you will increase cpu usage
- H.265 (4kp60 decode), H264 (1080p60 decode, 1080p30 encode)
@blakeblackshear,any chance to have the h.265 decode support?
Regards
If ffmpeg supports it, so does frigate. It’s possible I may have to compile ffmpeg with another flag, but that’s the benefit of using ffmpeg for intake. It already supports almost every known source of image data.
I would take a look at this blueprint.
You can add another condition to look at the event type like this to only send a single notification when the event ends:
- alias: kamera_hof_benachrichtigung
description: >-
Benachrichtigung wenn eine Person in der Einfahrt erkannt wird.
platform: mqtt
topic: frigate/events
- "{{ trigger.payload_json['after']['label'] == 'person' }}"
- "{{ 'einfahrt' in trigger.payload_json['after']['entered_zones'] }}"
- "{{ trigger.payload_json['type'] == 'end' }}"
- service: notify.mobile_app_suedpack_iphone
data_template:
message: "A {{trigger.payload_json['after']['label']}} has entered the yard."
image: "https://l0s78v5e5n18jvi2khsnff0axlg80pnf.ui.nabu.casa/api/frigate/notifications/{{trigger.payload_json['after']['id']}}/thumbnail.jpg"
tag: "{{trigger.payload_json['after']['id']}}"
data_template:
message: 'Es wurde Bewegung im Hof registriert um {{now().strftime("%H:%M %d-%m-%y")}} '
content-type: jpeg
push:
badge: 0
sound:
critical: 1
volume: 1.0
category: camera
entity_id: camera.garten_kamera_hof
Thank you, searched for the blueprint here. Never thought looking kn the blueprint section. I will give this a try !
Something similar?
https://trac.ffmpeg.org/wiki/Encode/H.265
# Getting ffmpeg with libx265 support
ffmpeg needs to be built with the `--enable-gpl` `--enable-libx265` configuration flags and requires `x265` to be installed on your system.
It’s already in there: frigate/Dockerfile.ffmpeg.amd64 at 09a4d6d030fec2f9e2d3e8be1fcb5560cd66414d · blakeblackshear/frigate · GitHub
RC2 of Hassos now support coral m.2?
Cool, what should be the hwaccel_args i need to add to use it?
Hi all,
There has been couple of other posts regarding hardware acceleration problems with Raspberry Pi.
I have also facing same issues. When I have the hardware acceleration configuration in frigate yml file, I will get the green screen and also plenty of different errors. If I will delete the hardware acceleration config, I will not get any errors and stream is working.
Does anybody have advice?
What I have checked:
Stream settings in camera and Frigate
Protection mode is disabled in Frigate Add-On
My setup:
Raspberry Pi 4 (4GB)
Home Assistant OS 5.13 (64-bit)
Frigate Add-on 1.13
Error logs from Frigate Add-on:
frigate.video INFO : frontyard: ffmpeg process is not running. exiting capture thread...
ffmpeg.frontyard.detect ERROR : [h264_v4l2m2m @ 0x5590337990] Could not find a valid device
ffmpeg.frontyard.detect ERROR : [h264_v4l2m2m @ 0x5590337990] can't configure decoder
ffmpeg.frontyard.detect ERROR : Error while opening decoder for input stream #0:0 : Operation not permitted
frigate.video INFO : frontyard: ffmpeg sent a broken frame. memoryview assignment: lvalue and rvalue have
Frigate camera configuration:
cameras:
frontyard:
ffmpeg:
hwaccel_args:
- -c:v
- h264_v4l2m2m
inputs:
- path: rtsp://username:[email protected]:XXXX/unicast
roles:
- detect
- clips
- rtmp
width: 1280
height: 720
fps: 5
objects:
track:
- person
- car
- dog
- motorcycle
- bicycle
- cat
snapshots:
enabled: true
timestamp: true
bounding_box: true
retain:
default: 5
clips:
enabled: true
retain:
default: 5
Exact, i report the same thing, i have try a lot of thing but nothing work for me.
Work only when i remove the hardware acceleration but the CPU is consumming a lot.
My setup:
Debian buster 10
Docker Home Assistant
Frigate Add-on 1.13
Good to know that I’m not the only one.
Now I started to think about this sentence from the Frigate documentation page:
Raspberry Pi 3/4 (64-bit OS) NOTICE : If you are using the addon, ensure you turn off
Protection mode
for hardware acceleration.
I have always thought that this is the same thing as turn off protection mode in the add-on.
But is it the same thing?
Correct. I upgrade to rc3 on a NUC 8 yesterday and no problems so far.
I run HassOS in a Virtualbox VM but not Frigate in it’s own with a Wyze cam, so I’m not sure if this applies to you or not but I have no issues. What is your config? I would start with no HW accel and see if that works. The VM can add some unnecessary layers for accessing some of the underlying hardware, though I do use these on my 6th gen i3:
hwaccel_args:
- -hwaccel
- qsv
- -qsv_device
- qsv
One thing I’ve noticed over the past (almost) year is that the Wyze RTSP might be the culprit - it’s terribly unstable at times, causing the lvalue and rvalue issue to pop. Meanwhile, I’ve tested other means of capturing the video through TinyCam and streaming the mjpeg stream and TinyCam–>Blue Iris–>Frigate. Those two work much better, but require more overhead. I wish TinyCam could restream RTSP instead of mjpeg since it uses the Wyze credentials to pull the video, maybe one day.
The RTSP firmware works for the most part directly with Frigate, but admittedly there were a couple of times it may have skipped frames and didn’t catch what it was supposed to. While the Wyze are nice and cheap, the RTSP firmware can be tough to work with at times.
I need some help…
When taking the latest picture from MQTT (frigate//car/snapshot) I always get bounding boxes ,timestamp and croped…
How do I disable them in snapshots from MQTT?
But when I view the same event in media browser the image is clear from bbox, crop and timestamp.
Modify these parameters.
