2020-10-02T00:44:17.167448513Z On connect called
2020-10-02T00:44:17.713861765Z ffprobe -v panic -show_error -show_streams -of json "REDACTED"
2020-10-02T00:44:17.714765480Z Starting detection process: 59
2020-10-02T00:44:19.022457622Z {'streams': [{'index': 0, 'codec_name': 'aac', 'codec_long_name': 'AAC (Advanced Audio Coding)', 'profile': 'LC', 'codec_type': 'audio', 'codec_time_base': '1/48000', 'codec_tag_string': '[0][0][0][0]', 'codec_tag': '0x0000', 'sample_fmt': 'fltp', 'sample_rate': '48000', 'channels': 1, 'channel_layout': 'mono', 'bits_per_sample': 0, 'r_frame_rate': '0/0', 'avg_frame_rate': '0/0', 'time_base': '1/48000', 'start_pts': 0, 'start_time': '0.000000', 'disposition': {'default': 0, 'dub': 0, 'original': 0, 'comment': 0, 'lyrics': 0, 'karaoke': 0, 'forced': 0, 'hearing_impaired': 0, 'visual_impaired': 0, 'clean_effects': 0, 'attached_pic': 0, 'timed_thumbnails': 0}}, {'index': 1, 'codec_name': 'h264', 'codec_long_name': 'H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10', 'profile': 'Main', 'codec_type': 'video', 'codec_time_base': '1/50', 'codec_tag_string': '[0][0][0][0]', 'codec_tag': '0x0000', 'width': 1920, 'height': 1080, 'coded_width': 1920, 'coded_height': 1080, 'has_b_frames': 0, 'sample_aspect_ratio': '1:1', 'display_aspect_ratio': '16:9', 'pix_fmt': 'yuvj420p', 'level': 41, 'color_range': 'pc', 'color_space': 'bt709', 'color_transfer': 'bt709', 'color_primaries': 'bt709', 'chroma_location': 'left', 'field_order': 'progressive', 'refs': 1, 'is_avc': 'false', 'nal_length_size': '0', 'r_frame_rate': '25/1', 'avg_frame_rate': '25/1', 'time_base': '1/90000', 'start_pts': 28800, 'start_time': '0.320000', 'bits_per_raw_sample': '8', 'disposition': {'default': 0, 'dub': 0, 'original': 0, 'comment': 0, 'lyrics': 0, 'karaoke': 0, 'forced': 0, 'hearing_impaired': 0, 'visual_impaired': 0, 'clean_effects': 0, 'attached_pic': 0, 'timed_thumbnails': 0}}]}
2020-10-02T00:44:19.023294887Z Creating ffmpeg process...
2020-10-02T00:44:19.023315923Z ffmpeg -hide_banner -loglevel panic -avoid_negative_ts make_zero -fflags nobuffer -flags low_delay -strict experimental -fflags +genpts+discardcorrupt -vsync drop -rtsp_transport tcp -stimeout 5000000 -use_wallclock_as_timestamps 1 -i REDACTED -f rawvideo -pix_fmt rgb24 pipe:
2020-10-02T00:44:19.029884474Z ffprobe -v panic -show_error -show_streams -of json "REDACTED"
2020-10-02T00:44:20.393214222Z {'streams': [{'index': 0, 'codec_name': 'aac', 'codec_long_name': 'AAC (Advanced Audio Coding)', 'profile': 'LC', 'codec_type': 'audio', 'codec_time_base': '1/48000', 'codec_tag_string': '[0][0][0][0]', 'codec_tag': '0x0000', 'sample_fmt': 'fltp', 'sample_rate': '48000', 'channels': 1, 'channel_layout': 'mono', 'bits_per_sample': 0, 'r_frame_rate': '0/0', 'avg_frame_rate': '0/0', 'time_base': '1/48000', 'start_pts': 0, 'start_time': '0.000000', 'disposition': {'default': 0, 'dub': 0, 'original': 0, 'comment': 0, 'lyrics': 0, 'karaoke': 0, 'forced': 0, 'hearing_impaired': 0, 'visual_impaired': 0, 'clean_effects': 0, 'attached_pic': 0, 'timed_thumbnails': 0}}, {'index': 1, 'codec_name': 'h264', 'codec_long_name': 'H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10', 'profile': 'Main', 'codec_type': 'video', 'codec_time_base': '1/50', 'codec_tag_string': '[0][0][0][0]', 'codec_tag': '0x0000', 'width': 1920, 'height': 1080, 'coded_width': 1920, 'coded_height': 1080, 'has_b_frames': 0, 'sample_aspect_ratio': '1:1', 'display_aspect_ratio': '16:9', 'pix_fmt': 'yuvj420p', 'level': 41, 'color_range': 'pc', 'color_space': 'bt709', 'color_transfer': 'bt709', 'color_primaries': 'bt709', 'chroma_location': 'left', 'field_order': 'progressive', 'refs': 1, 'is_avc': 'false', 'nal_length_size': '0', 'r_frame_rate': '25/1', 'avg_frame_rate': '25/1', 'time_base': '1/90000', 'start_pts': 32400, 'start_time': '0.360000', 'bits_per_raw_sample': '8', 'disposition': {'default': 0, 'dub': 0, 'original': 0, 'comment': 0, 'lyrics': 0, 'karaoke': 0, 'forced': 0, 'hearing_impaired': 0, 'visual_impaired': 0, 'clean_effects': 0, 'attached_pic': 0, 'timed_thumbnails': 0}}]}
2020-10-02T00:44:20.393649058Z Creating ffmpeg process...
2020-10-02T00:44:20.393667376Z ffmpeg -hide_banner -loglevel panic -avoid_negative_ts make_zero -fflags nobuffer -flags low_delay -strict experimental -fflags +genpts+discardcorrupt -vsync drop -rtsp_transport tcp -stimeout 5000000 -use_wallclock_as_timestamps 1 -i REDACTED -f rawvideo -pix_fmt rgb24 pipe:
2020-10-02T00:44:20.401481590Z Camera_process started for backgrill: 88
2020-10-02T00:44:20.402888983Z Starting process for backgrill: 88
2020-10-02T00:44:20.403656081Z Camera_process started for masterbedroom: 89
2020-10-02T00:44:20.405438214Z Starting process for masterbedroom: 89
2020-10-02T00:44:20.420085789Z * Serving Flask app "detect_objects" (lazy loading)
2020-10-02T00:44:20.420127512Z * Environment: production
2020-10-02T00:44:20.420134010Z WARNING: This is a development server. Do not use it in a production deployment.
2020-10-02T00:44:20.420139940Z Use a production WSGI server instead.
2020-10-02T00:44:20.420150079Z * Debug mode: off
2020-10-02T01:02:31.320828225Z Detection appears to be stuck. Restarting detection process
2020-10-02T01:02:31.320937366Z Waiting for detection process to exit gracefully...
2020-10-02T01:02:31.342082889Z Starting detection process: 404
{"backgrill":{"camera_fps":25.0,"detection_fps":5.3,"ffmpeg_pid":67,"frame_info":{"detect":1601606214.372725,"process":1601606214.372725,"read":1601606214.372725},"pid":88,"process_fps":25.0,"read_start":1601606214.378684,"skipped_fps":0.0},"coral":{"detection_start":0.0,"fps":5.3,"inference_speed":30.03,"pid":404},"masterbedroom":{"camera_fps":25.0,"detection_fps":0.0,"ffmpeg_pid":86,"frame_info":{"detect":1601606214.362849,"process":1601606214.362849,"read":1601606214.399484},"pid":89,"process_fps":25.0,"read_start":1601606214.369432,"skipped_fps":0.0},"plasma_store_rc":null}
