My apologies Blake. Seems the options were not saved. Now I get a different error (which I will pursue on my own - at least for a little while):
[rtsp @ 0x5573e24ab9c0] Could not find codec parameters for stream 0 (Video: none, none): unknown codec
Consider increasing the value for the ‘analyzeduration’ and ‘probesize’ options
Input #0, rtsp, from ‘rtsp://192.168.0.13:8554/unicast’:
Metadata:
title : LIVE555 Streaming Media v2017.10.28
comment : LIVE555 Streaming Media v2017.10.28
Duration: 00:00:20.00, start: 1604263938.917900, bitrate: N/A
Stream #0:0: Video: none, none, 90k tbr, 90k tbn, 90k tbc
Stream mapping:
Stream #0:0 -> #0:0 (? (?) -> rawvideo (native))
Decoder (codec none) not found for input stream #0:0
birdcam: ffmpeg sent a broken frame. something is wrong.
birdcam: ffmpeg process is not running. exiting capture thread…
I’m getting overlapping video clips that are almost duplicates of each other. It seems to be a situation when there is motion that is coming in and out of view or multiple people walking into view. I’m assuming “motion detected” would have to false before another clip is recorded but maybe I have some corner case here.
Thank you for the suggestion. My cams was behind an NVR and I tought I was not able to get the substring but in reality I could.
Now everything run smoothly. BUT the substream dosen’t have the good resolution (4:3 where the stream is 16:9).
How to resize the substream in the options ? Do you have an example ?
I haven’t tried it in the E Key slot yet, I had a surgery done on my arm so it could be a while.
Did you install the Gasket DKMS module? Do you see /dev/apex_0? I don’t know how to install that module in hassos but it must be possible. I don’t run it on hassos or even with Docker at all, I use a VM.
@rpress@bdherouville
I was initially under the impression the Docker container contained all the drivers.
But I was reading that link late last night and realised I don’t have an apex_0 listed.
I will try and install the driver at the container level first, as it will be a little difficult to install at the host level I think.
I fear that you will need to install the driver at least on the host. Because without that wou won’t be able to present /dev/apex_0 to the docker container.
If the host does not have access to /dev/apex_0 it won’t be able to give Docker acess to it.
I am having issues getting frigate running on my system. I’ve tried both the HA addon in Supervisor as well as installing as a standalone docker container.
When I run in docker, the container starts, but after only a second it ends. There is nothing in the log but I do see “Stopped with exit code 132”. My Googling about exit code 132 hasn’t returned anything fruitful.
When I try to run the HA addon through Supervisor I get the error:
Fontconfig error: Cannot load default config file
File “detect_objects.py”, line 441, in
“<“module”>”
main()
File “detect_objects.py”, line 202, in
main
ffmpeg_output_args = ["-r",
str(config.get(‘fps’))] +
ffmpeg_output_args
TypeError: can only concatenate list (not
“NoneType”) to list
My rtsp url does work successfully in VLC.
Any insight would be greatly appreciated.
web_port: 5000
tensorflow_device: usb
mqtt:
host: MQTT_IP
topic_prefix: frigate
user: user
password: password
# Global configuration for saving clips
save_clips:
# Maximum length of time to retain video during long events.
# If an object is being tracked for longer than this amount of time, the cache
# will begin to expire and the resulting clip will be the last x seconds of the event.
max_seconds: 300
# Default ffmpeg args. Optional and can be overwritten per camera.
# Should work with most RTSP cameras that send h264 video
# Built from the properties below with:
# "ffmpeg" + global_args + input_args + "-i" + input + output_args
# ffmpeg:
# global_args:
# - -hide_banner
# - -loglevel
# - panic
# hwaccel_args: []
# input_args:
# - -avoid_negative_ts
# - make_zero
# - -fflags
# - nobuffer
# - -flags
# - low_delay
# - -strict
# - experimental
# - -fflags
# - +genpts+discardcorrupt
# - -vsync
# - drop
# - -rtsp_transport
# - tcp
# - -stimeout
# - '5000000'
# - -use_wallclock_as_timestamps
# - '1'
# output_args:
# - -f
# - rawvideo
# - -pix_fmt
# - rgb24
objects:
track:
- person
- car
- truck
filters:
person:
min_area: 5000
max_area: 100000
min_score: 0.5
threshold: 0.85
cameras:
porch:
ffmpeg:
input: rtsp://user:password@CAMERA_IP:554/cam/realmonitor?channel=1&subtype=1
height: 480
width: 640
fps: 5
take_frame: 1
best_image_timeout: 60
save_clips:
enabled: true
# Number of seconds before the event to include in the clips
pre_capture: 30
# Objects to save clips for. Defaults to all tracked object types.
objects:
- person
# Configuration for the snapshots in the debug view and mqtt
snapshots:
show_timestamp: True
draw_zones: False
objects:
track:
- person
filters:
person:
min_area: 5000
max_area: 100000
min_score: 0.5
threshold: 0.5
Can you double check that this is the config you used with the addon when you got the error message? I know that error message, but your config doesn’t have the problem that usually causes it.
I am using HA core in a docker container. I have mapped the clips directory successfully to the media dir in HA. How can i see the files using the media browser? is there a card or something that i need to setup, so it shows in lovelace? can you share how you add that media window? thanks
So far I’m impressed by Frigate, simple to use and really powerful. But I’m stuck on a problem to use the hw accelerator. I’m on a NUC i3 10th gen, so according to the docs I need to set the LIBVA_DRIVER_NAME env variable but I’m using the hassio addon. How do I do this? Or should I switch to Portainer and handle is myself?
I might be able to find a way to auto-detect it in a future version. Honestly, I didn’t see that big of an improvement in CPU usage with that driver. It will require more research to see if it can be improved.
I meant performance over not using hardware acceleration at all, not in comparison to the other driver. It only saved me ~20% over no hardware acceleration.
@blakeblackshear, really thankful for this add-on. Already ordered a coral!
Same motivations as yours with nest-like capabilities. I’ve also trained a raccoon detection model on IP camera night vision footage on TensorFlow, which works. I’ll need to convert it to TensorFlow lite to integrate here.
Got the add-on up and running with 1 CPU detector and 1 IP camera and debug stream works great. I see the detection in MQTT.
