That’s unfortunate, I have been following your updates as I wanted to do the same on Unraid.
I only have USB2 on my system, done some googling but I cannot see if it will have a performance impact on the Coral USB card? That’s another reason I wanted to get the USB3 PCI card working.
If you do ever get it working, please put an update on this thread. Thank you.
I certainly will update when/if I get it working. I am going to post in the unraid forums shortly for some help. I definitely can get Unraid to recognize the PCI card, just don’t know how to get the container to recognize it.
thinking about running a low-resource usage linux vm just for frigate. That may help with figuring out the correct way to pass it through
also having some weird issues where it takes a few minutes of the server being on to be able to use the USB device. Not sure what’s going on there.
I just got the USB version working, went from 540 to 160 inference speed, now trying to get it to detect motion. Me jumping about is making the detection frames go up but no motion alert…
I took out the mask setting from the config as I want all the camera image to be scanned, not sure yet if thats the problem.
Bl00dy addictive this is, i need to go to bed, its 4am here, DOH!
nice! 160 inference speed still seems high. I get 10ms when the usb is not detected, jumps to hundreds when motion detected. 7-8ms constant when usb is working.
Here’s my config - only thing I have filtering is the area and score.
Got motion detected on 2 cameras but not on 3rd ( 7 cameras in total but its -1c so too cold and dark to do any more testing) so probably some typo somewhere but too tired now, off to bed
Happy it’s starting to come together. Will update later
Cheers
I’m not sure why the USB isn’t being detected then. I would compare the output of lsusb -t to the link I posted to see if that is the issue. Maybe someone else on here is using that Synology machine. I have also see some issues with USB ports not providing enough power.
thanks for following up
on the synology the lsusb -t does not exist so unable to show more info.
from the lsusb command it looks like 4-1 uses 896mA
in my synology control panel there is one usb shown: USBDevice - Gloval Unichip Corp. VID:1a6e PID: 089a Rev. 1.00. I have not other devices connected so that must me the Coral. Not sure though if this info is of any use
Under my synology external devices tab i have no devices connected but i think that normally you would see external drives here.
I have rebooted the synology various time too after moving the Coral to a different usb for test and no results either.
can it have something to do with r&w rights? or drivers which are not available on the synology?
Did try sudo apt-get install libedgetpu1-std earlier, but apt-get is not recoginised.
uname -a outputs
Linux DS718 4.4.59+ #25426 SMP PREEMPT Wed Jul 8 03:21:29 CST 2020 x86_64 GNU/Linux synology_apollolake_718+
cat /proc/version outputs:
Linux version 4.4.59+ (root@build3) (gcc version 4.9.3 20150311 (prerelease) (crosstool-NG 1.20.0) ) #25426 SMP PREEMPT Wed Jul 8 03:21:29 CST 2020
