This will probably help: https://github.com/blakeblackshear/frigate/discussions/406
Thanks again, I will have look, certainly looks promising
Made the same changes, no luck, still filling the logs up with errors. Frigate is running on a Pi4 kubenertes cluster with node affinity to the node with the USB Coral TPU, not sure if that matters here or not (it does see the TPU when it starts.)
Hello all.
I too wish to get away from Zoneminder. It works ok. But its so clucky to work with and it has so many extra bits you have to code to get working as it should. Not happy with it in its current state. But really canât complain. It is free open source after all.
I have been looking at this for the last few days. And I have been going round the bend. My google fu has failed me.
I have never been able to work well with docker. I am just not a programming type guy. Alas, I am a one of them folks that need to have their hand held for them.
Has anybody seen or know of a âFor Dummyâs installâ copy paste into Ubuntu command line install tutorial?
I am running a 18.04 LTS of Ubuntu as a virtual machine on a UnRAID system. Yes I understand that virtual machines are not the best way. But I am unwilling to put my core UnRAID data at risk. Please donât shoot me for it.
I have already followed the pages from coral.AI website for getting a Edge TPU working on my system.
I get good working results.
peter@aitpuodd:~/coral/pycoral$ python3 examples/classify_image.py --model test_data/mobilenet_v2_1.0_224_inat_bird_quant_edgetpu.tflite --labels test_data/inat_bird_labels.txt --input test_data/parrot.jpg----INFERENCE TIME----
Note: The first inference on Edge TPU is slow because it includes loading the model into Edge TPU memory.
15.2ms
2.7ms
2.7ms
2.7ms
2.9ms
-------RESULTS--------
Ara macao (Scarlet Macaw): 0.75781
So I just need a good easy to copy paste style tutorial for Home Assistant with Frigate. I really do hope somebody can help.
Thanks for taking the time to read.
Oddsodz
Try adding
global_args: -hide_banner -loglevel info
to the ffmpeg section and
logger:
default: debug
to the logger section of your frigate config file. That should cause ffmpeg to show you the exact reason for the errors.
Ok, unless I didnât add them correctly, I redeployed the pod, but not sure Iâm seeing what I expected:
ffmpeg.middle_driveway.clips_record ERROR : [segment @ 0xaaaafaa4d630] Opening '/tmp/cache/middle_driveway-20210218190603.mp4' for writing
ffmpeg.middle_driveway.clips_record ERROR : frame= 563 fps= 26 q=-1.0 size=N/A time=00:00:22.35 bitrate=N/A speed=1.04x
ffmpeg.middle_driveway.clips_record ERROR : frame= 576 fps= 26 q=-1.0 size=N/A time=00:00:22.87 bitrate=N/A speed=1.03x
ffmpeg.middle_driveway.clips_record ERROR : frame= 589 fps= 26 q=-1.0 size=N/A time=00:00:23.39 bitrate=N/A speed=1.03x
ffmpeg.middle_driveway.clips_record ERROR : frame= 601 fps= 26 q=-1.0 size=N/A time=00:00:23.90 bitrate=N/A speed=1.03x
frigate.video INFO : middle_driveway: ffmpeg sent a broken frame. memoryview assignment: lvalue and rvalue have different structures
frigate.video INFO : middle_driveway: ffmpeg process is not running. exiting capture thread...
ffmpeg.middle_driveway.clips_record ERROR : frame= 615 fps= 26 q=-1.0 size=N/A time=00:00:24.44 bitrate=N/A speed=1.03x
ffmpeg.middle_driveway.clips_record ERROR : frame= 628 fps= 26 q=-1.0 size=N/A time=00:00:24.96 bitrate=N/A speed=1.03x
ffmpeg.middle_driveway.clips_record ERROR : frame= 641 fps= 26 q=-1.0 size=N/A time=00:00:25.48 bitrate=N/A speed=1.03x
ffmpeg.middle_driveway.clips_record ERROR : frame= 652 fps= 26 q=-1.0 size=N/A time=00:00:26.06 bitrate=N/A speed=1.03x
ffmpeg.middle_driveway.clips_record ERROR : frame= 669 fps= 26 q=-1.0 size=N/A time=00:00:26.60 bitrate=N/A speed=1.03x
ffmpeg.middle_driveway.clips_record ERROR : frame= 682 fps= 26 q=-1.0 size=N/A time=00:00:27.11 bitrate=N/A speed=1.03x
Thank you!
Did you set up the global_args in the head ffmpeg section of the file, not under a camera or role?
Got distracted by work, good point, let me take a look. Thanks!
Looking like a networking issue maybe?
ffmpeg.middle_driveway.detect ERROR : frame= 185 fps=5.7 q=-1.0 q=-0.0 size= 1313kB time=00:00:36.80 bitrate= 292.3kbits/s dup=1 drop=0 speed=1.14x
ffmpeg.middle_driveway.detect ERROR : [NULL @ 0xaaaada934c20] missing picture in access unit with size 20
ffmpeg.middle_driveway.detect ERROR : [h264 @ 0xaaaadaaf9e10] no frame!
watchdog.middle_driveway INFO : Terminating the existing ffmpeg process...
watchdog.middle_driveway INFO : Waiting for ffmpeg to exit gracefully...
ffmpeg.middle_driveway.detect ERROR : frame= 187 fps=4.9 q=-1.0 q=-0.0 size= 1315kB time=00:00:37.20 bitrate= 289.5kbits/s dup=1 drop=0 speed=0.981x
ffmpeg.middle_driveway.detect ERROR : frame= 187 fps=4.3 q=-1.0 q=-0.0 size= 1315kB time=00:00:37.20 bitrate= 289.5kbits/s dup=1 drop=0 speed=0.864x
ffmpeg.middle_driveway.detect ERROR : frame= 187 fps=3.9 q=-1.0 q=-0.0 size= 1315kB time=00:00:37.40 bitrate= 288.0kbits/s dup=1 drop=0 speed=0.777x
ffmpeg.middle_driveway.detect ERROR : Error while decoding stream #0:0: Invalid data found when processing input
ffmpeg.middle_driveway.detect ERROR : frame= 187 fps=3.5 q=-1.0 q=-0.0 size= 1315kB time=00:00:37.40 bitrate= 288.0kbits/s dup=1 drop=0 speed=0.702x
ffmpeg.middle_driveway.detect ERROR : frame= 187 fps=3.2 q=-1.0 q=-0.0 size= 1315kB time=00:00:37.40 bitrate= 288.0kbits/s dup=1 drop=0 speed=0.64x
ffmpeg.middle_driveway.detect ERROR : frame= 187 fps=2.9 q=-1.0 q=-0.0 size= 1315kB time=00:00:37.40 bitrate= 288.0kbits/s dup=1 drop=0 speed=0.589x
ffmpeg.middle_driveway.detect ERROR : [flv @ 0xaaaada943560] Failed to update header with correct duration.
ffmpeg.middle_driveway.detect ERROR : [flv @ 0xaaaada943560] Failed to update header with correct filesize.
ffmpeg.middle_driveway.detect ERROR : frame= 187 fps=2.9 q=-1.0 Lq=-0.0 size= 1315kB time=00:00:37.40 bitrate= 288.0kbits/s dup=1 drop=0 speed=0.589x
ffmpeg.middle_driveway.detect ERROR : video:93876kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
Try swapping your width height values in your config for that camera
Same issue, just redeployed with it swapped:
ffmpeg.middle_driveway.detect ERROR : frame= 152 fps=5.9 q=-1.0 q=-0.0 size= 1150kB time=00:00:30.20 bitrate= 311.9kbits/s speed=1.17x
ffmpeg.middle_driveway.detect ERROR : [NULL @ 0xaaab0b599c20] missing picture in access unit with size 20
ffmpeg.middle_driveway.detect ERROR : [h264 @ 0xaaab0b6c3000] no frame!
ffmpeg.middle_driveway.detect ERROR : frame= 154 fps=4.9 q=-1.0 q=-0.0 size= 1152kB time=00:00:30.60 bitrate= 308.4kbits/s speed=0.977x
ffmpeg.middle_driveway.detect ERROR : frame= 154 fps=4.2 q=-1.0 q=-0.0 size= 1152kB time=00:00:30.60 bitrate= 308.4kbits/s speed=0.84x
ffmpeg.middle_driveway.detect ERROR : frame= 154 fps=3.7 q=-1.0 q=-0.0 size= 1152kB time=00:00:30.60 bitrate= 308.4kbits/s speed=0.736x
ffmpeg.middle_driveway.detect ERROR : frame= 154 fps=3.3 q=-1.0 q=-0.0 size= 1152kB time=00:00:30.60 bitrate= 308.4kbits/s speed=0.655x
ffmpeg.middle_driveway.detect ERROR : frame= 154 fps=3.0 q=-1.0 q=-0.0 size= 1152kB time=00:00:30.60 bitrate= 308.4kbits/s speed=0.591x
ffmpeg.middle_driveway.detect ERROR : frame= 154 fps=2.7 q=-1.0 q=-0.0 size= 1152kB time=00:00:30.60 bitrate= 308.4kbits/s speed=0.538x
ffmpeg.middle_driveway.detect ERROR : [flv @ 0xaaab0b5a8560] Failed to update header with correct duration.
ffmpeg.middle_driveway.detect ERROR : [flv @ 0xaaab0b5a8560] Failed to update header with correct filesize.
ffmpeg.middle_driveway.detect ERROR : frame= 154 fps=2.7 q=-1.0 Lq=-0.0 size= 1152kB time=00:00:30.60 bitrate= 308.4kbits/s speed=0.538x
ffmpeg.middle_driveway.detect ERROR : video:76884kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
Iâve tried reading back over your comments. I canât see that you tried the same URL in VLC and checked media codec information to confirm
1 the stream url works
2 the actual w & h for that stream
I will check it out, I can stream in vlc, but havenât checked codec info. Thank you for the help!
Think itâs in Tools > Media Info >codec tab
Maybe networking. Or something with kubernetes? Itâs receiving a couple hundred frames before it dies, it seems.
So I am starting to wonder⌠So when I initially set this up, I had this isolated to itâs own switch only connected to my DVR running bluecherry as didnât want anything having access to the camera except the DVR. I later added routing on that box to allow the rest of the network access to it only, but starting to wonder if thatâs not working properly. Now that I know what I am seeing is not normal, let me see about moving that off there and to itâs own segment off my firewall instead. Thank you guys for all the help and ideas, Iâll report whatever I find.
@hawkeye217 @konradwalsh Thank you guys for the help today, it was a networking issue. Something on the Linux box wasnât routing properly obviously, as even though looked like it was working. I moved the CCTV lan over to my firewall and set up the routing through there, and no more errors. Sorry to waste your time today.
Any instructions on enabling hardware acceleration?
Get an error No device available for decoder: device type vaapi needed for
Question for people using Frigate add-on HassOS on Raspberry Pi 4 and Coral USB. Whatâs the average detection fps you get?
