Seems in your config snippet above you have:
width: 1280
height: 720
My Wyze cams (V2) are
width: 1920
height: 1080
Are you sure you have the correct settings?
width: 1280
height: 720
width: 1920
height: 1080
Loving the new UI in 0.8.2. Also not sure if a new feature or not (as I just started using it this week), but discovered the dark mode option on the upper right I had thought it was a setting in the configuration so suspect Iw as looking in the wrong placeā¦
Downloaded the new release. Getting some āblinkingā when I hover over certain items in the UI. Like in the Road Mask and Zone Creator, the Add/Remove buttons appear/disappear when I move the mouse over them.
Also when I hover over the āToggle Detect/Clips/Snapshotā in the main UI, the camera images blink when moving the mouse of those items. Using Chrome btw.
Dark mode was always available, but it was set to āautoā, so it depended on your system setting
@biggen1684 Iām not able to reproduce this. Can you please file an issue on GitHub with as much information as possible (browser, system, etc) as well as a screen recording or something?
Got it! that explains why on my work Mac in dark mode it showed up with dark mode, and on my regular desktop running Ubuntu, while in Dark mode Iād see light mode as doesnāt really carry across to Chrome for the mode type. Thanks!
New release dont show up hereā¦ How to force an upodate? Remove and reinstall?
The addon has not been published yet; only the Docker images are available.
Ahhhā¦ okā¦ Will wait thenā¦
Love now that snapshots can be configured for zones only now! That is a great feature! I was able to reduce masking quite a bit but I do still get multiple snapshot āeventsā from the same car/person driving/walking through the zone occasionally. Not often but sometimes a slow walker seems to create more than one āeventā. I guess I need to up the max_disappeared
value further a bit for my setup to tweak it just a bit.
Great job though!
@blakeblackshear might be worth adding a small note on the HA integration installation instructions that the MQTT server HA is connected to must be the same as the one Frigate is connected to for the sensors to work. Iāve been wondering why mine were showing as unavailable then I remembered I connected Frigate to a local MQTT db running on the same instance instead of my main one which my HA is connected to.
funny
how should it work if itās not the HA MQTT server
There are plenty of integrations which donāt use mqtt to update entities?
Hello
I install Home assistant in RP4 can I use this component for face recognition in RP4 ?
soounds interesting I have a OPENALPR docker container running but not sure how to use it and ho to integrate it properly int o home assistant . any ideas heere?
I have a similar issue with the camera at the front of my house. It kept picking up the parked cars in the street as a car was parking on our drive. I set a motion mask to cover the street which has fixed that and defined two zones on the drive and path. I also keep getting false positives of our car as a new object regularly. Iām not sure whatās triggering it, as the frequency seems to be way over the default max_disappeared of 25. Iām going to try increasing it in any case but any other suggestions would be much welcomed.
This is the frequency Iām looking at:
front | car | 72.66% | drive | 22/02/2021 | 09:16:42 | 09:16:52 |
front | car | 82.03% | drive | 22/02/2021 | 09:16:41 | 09:16:52 |
front | car | 70.70% | drive | 22/02/2021 | 09:09:12 | 09:09:23 |
front | car | 84.38% | drive | 22/02/2021 | 09:09:11 | 09:09:23 |
front | car | 84.38% | drive | 22/02/2021 | 09:08:46 | 09:08:54 |
front | car | 79.49% | drive | 22/02/2021 | 09:08:30 | 09:08:46 |
front | car | 84.38% | drive | 22/02/2021 | 09:08:22 | 09:08:43 |
front | car | 84.38% | drive | 22/02/2021 | 08:44:46 | 08:44:59 |
front | car | 75.39% | drive | 22/02/2021 | 08:28:12 | 08:28:19 |
front | car | 76.95% | drive | 22/02/2021 | 08:06:27 | 08:06:39 |
front | car | 82.42% | drive | 22/02/2021 | 07:53:12 | 07:53:21 |
front | car | 84.38% | drive | 22/02/2021 | 07:20:18 | 07:20:31 |
front | car | 84.38% | drive | 22/02/2021 | 07:09:56 | 07:10:04 |
front | car | 81.25% | drive | 22/02/2021 | 07:09:42 | 07:09:51 |
front | car | 80.66% | drive | 22/02/2021 | 07:09:10 | 07:09:17 |
front | car | 83.20% | drive | 22/02/2021 | 07:04:55 | 07:05:03 |
front | car | 84.38% | drive | 22/02/2021 | 07:03:31 | 07:03:40 |
front | car | 84.38% | drive | 22/02/2021 | 06:56:40 | 06:56:56 |
front | car | 72.66% | drive | 22/02/2021 | 06:53:21 | 06:53:32 |
front | car | 74.61% | drive | 22/02/2021 | 06:51:10 | 06:51:20 |
front | car | 76.95% | drive | 22/02/2021 | 06:45:38 | 06:45:45 |
front | car | 79.30% | drive | 22/02/2021 | 06:44:22 | 06:44:33 |
front | car | 79.69% | drive | 22/02/2021 | 06:42:29 | 06:42:38 |
front | car | 72.66% | drive | 22/02/2021 | 06:40:51 | 06:40:57 |
front | car | 79.30% | drive | 22/02/2021 | 06:31:11 | 06:31:19 |
front | car | 74.02% | drive | 22/02/2021 | 06:23:28 | 06:23:35 |
front | car | 82.42% | drive | 22/02/2021 | 06:20:28 | 06:20:36 |
front | car | 71.09% | drive | 22/02/2021 | 06:17:36 | 06:17:44 |
front | car | 74.61% | drive | 22/02/2021 | 06:01:29 | 06:01:34 |
front | car | 72.66% | drive | 22/02/2021 | 05:34:48 | 05:35:01 |
front | car | 75.39% | drive | 22/02/2021 | 05:29:30 | 05:29:38 |
front | car | 76.17% | drive | 22/02/2021 | 05:27:02 | 05:27:14 |
front | car | 71.48% | drive | 22/02/2021 | 05:25:28 | 05:25:34 |
front | car | 75.78% | drive | 22/02/2021 | 05:21:19 | 05:21:25 |
front | car | 75.39% | drive | 22/02/2021 | 05:17:39 | 05:17:47 |
front | car | 74.22% | drive | 22/02/2021 | 05:14:27 | 05:14:36 |
front | car | 75.39% | drive | 22/02/2021 | 05:12:52 | 05:12:59 |
front | car | 81.25% | drive | 22/02/2021 | 05:01:13 | 05:01:21 |
front | car | 78.91% | drive | 22/02/2021 | 04:58:03 | 04:58:08 |
front | car | 70.51% | drive | 22/02/2021 | 04:49:52 | 04:50:02 |
front | car | 78.91% | drive | 22/02/2021 | 04:48:15 | 04:48:21 |
front | car | 78.13% | drive | 22/02/2021 | 04:39:21 | 04:39:31 |
front | car | 78.91% | drive | 22/02/2021 | 04:32:08 | 04:32:15 |
I noticed some corruption on the stream, could that be the cause? I probably need to look at fixing the corruption but itās odd as the camera is hard wired and Iām using a low res stream for the detection.
You need to setup an object mask as well which prevents any object you define from being detected from within the object mask. Motion masks only prevent Frigate from triggering on motion from within the motion mask. However, once motion has been triggered elsewhere (e.g. outside the motion mask), objects everywhere in the scene (including the motion mask) are now fair game. If you also have identical motion/object masks, that tells frigate to not only ignore any motion in the motion mask, but also ignore objects in the object mask as well.
So in your example, you need a car
object mask covering that grey car (or the whole space) if itās always parked in that spot and you donāt want it to ever be detected. That will tell Frigate to ignore any object of car
that is within the mask. It will only ignore car
and still trigger for any other object (Frigate defaults to person
if you donāt specifically tell it to look for certain objects).
Here is a snippet of my config excluding zones.
motion:
mask:
- 2688,0,2688,196,0,318,0,0
- 0,1520,2519,1520,1970,715,0,713
And this:
objects:
filters:
car:
mask:
person:
mask:
You can see how I use identical motion/object masks because I donāt want frigate to act on motion in any of those masked area AND I donā want it to detect any car/person objects in those masks areas either.
I canāt help with HA integration with OpenALPR as I donāt use HA with it. I exclusively use HA just for Frigate notifications and thatās it.
Head over to ipcamtalk.com if you are interested in LPR setup and advice. We are pretty active over there. There is a dedicated subforum just for it.
Ah ok thanks for the tip! Iāve checked and Iām not getting any object detection in the motion mask area though? Thatās the blacked out area at the top.
I do want to detect the grey car and any car on the drive as Iād like to know if the car moves. The problem is the car isnāt moving and it keeps detecting it as a new object every 2 - 8 minutes.
Iāll try the object mask and see if that improves things.
As I understand it, motion kicks off Frigate ādetection processesā and then any object
you have set in your config will get tracked even if its not moving. So even if that car in your driveway isnāt moving, Frigate will detect it when Frigate sees movement elsewhere in the frame. Maybe those bushes are blowing on the left or someone walks on the sidewalk on the right. Whatever Frigate is keying in on motion, that motion event is making Frigate start its detection and you must have car
set as one of your tracked objects so Frigate is tracking that even though it isnāt moving.
The only way to prevent that is to use an object mask
set for car
and that will ignore that grey car.
This is likely happening for various reasons - birds moving over the cars, sun/lighting changes, etc. Anything that causes Frigate to see motion in that area will cause objects to be redetected (even if theyāve been determined as āstationaryā previously and had detection automatically turned off after a set period - on 0.8.2 and later). You may be able to adjust your motion:
settings to be less sensitive ( see https://blakeblackshear.github.io/frigate/configuration/advanced) to prevent this, but there is no foolproof way to see if only the car moves.
