I only know about this API reference. Would be great if can find examples on how to utilize all the infos generated from the frigate events.
So far i’m using it to send telegram notifications and to turn on zone lights when alarm is triggered
Asking the pros here. …
I’m using HA to send notifications to the family when there is detection with a link to the recorded clip.
But sometimes you want the notifications to stop for say a 5min period. How would you accomplish the automation?
Edit: Using the PUSHOVER service to get my notifications.
Would you mind sharing your code for this .I want to use my own notify XMPP component not the compagnon
i send my telegrambot a command: /stop 5 (5 = 5 mins or any number to indicate the number of minutes to stop notifications)
telegrambot receives command and turn off notification automation and start the timer helper.
upon timer helper finished event, turn notification automation back on.
Thanks for the tips… But im not using Telegram… Using Pushover for receiving push notifications.
Should have made a note in my question
Here it is… Btw, using Pushover service to send notifications from HA. This is because there is a limit of 300 push every day.
service: notify.pushover
message: >-
{{trigger.payload_json["after"]["label"]}} detekterat i kamera
{{trigger.payload_json["after"]["camera"]}}.
target: Note10
url_title: Play Video
url: >-
https://XXX.ui.nabu.casa/api/frigate/notifications/{{trigger.payload_json["after"]["id"]}}/{{trigger.payload_json["after"]["camera"]}}/clip.mp4
attachment: >-
/config/www/img/frigate/{{trigger.payload_json["after"]["camera"]}}_latest.jpg
Could anybody help to understand what’s the issue?
I am trying to use blakeblackshear/frigate:stable-amd64nvidia
with Nvidia GPU and H265 (also tried with H264) camera stream.
Here’s what I get:
root@max-HP-Z240-SFF-Workstation:/home/max# docker run --rm --name=frigate --gpus all --runtime=nvidia -v /dev/bus /usb:/dev/bus/usb -v /var/frigate:/config:ro -p 5000:5000 -e RTSP_PASSWORD='037-46KE' -e NVIDIA_VISIBLE_DEVICES=al l -e NVIDIA_DRIVER_CAPABILITIES=compute,video,utility blakeblackshear/frigate:stable-amd64nvidia
* Starting nginx nginx
...done.
frigate.app INFO : Creating directory: /media/frigate/recordings
frigate.app INFO : Creating directory: /media/frigate/clips
frigate.app INFO : Creating directory: /tmp/cache
frigate.app WARNING : Camera axis has rtmp enabled, but rtmp is not assigned to an input.
Starting migrations
peewee_migrate INFO : Starting migrations
Migrate "001_create_events_table"
peewee_migrate INFO : Migrate "001_create_events_table"
sql ('CREATE TABLE IF NOT EXISTS "event" ("id" VARCHAR(30) NOT NULL PRIMARY KEY, "label" VARCHAR(20) NOT NULL, "ca mera" VARCHAR(20) NOT NULL, "start_time" DATETIME NOT NULL, "end_time" DATETIME NOT NULL, "top_score" REAL NOT NUL L, "false_positive" INTEGER NOT NULL, "zones" JSON NOT NULL, "thumbnail" TEXT NOT NULL)',)
peewee_migrate INFO : sql ('CREATE TABLE IF NOT EXISTS "event" ("id" VARCHAR(30) NOT NULL PRIMA RY KEY, "label" VARCHAR(20) NOT NULL, "camera" VARCHAR(20) NOT NULL, "start_time" DATETIME NOT NULL, "end_time" DA TETIME NOT NULL, "top_score" REAL NOT NULL, "false_positive" INTEGER NOT NULL, "zones" JSON NOT NULL, "thumbnail" TEXT NOT NULL)',)
sql ('CREATE INDEX IF NOT EXISTS "event_label" ON "event" ("label")',)
peewee_migrate INFO : sql ('CREATE INDEX IF NOT EXISTS "event_label" ON "event" ("label")',)
sql ('CREATE INDEX IF NOT EXISTS "event_camera" ON "event" ("camera")',)
peewee_migrate INFO : sql ('CREATE INDEX IF NOT EXISTS "event_camera" ON "event" ("camera")',)
Done 001_create_events_table
peewee_migrate INFO : Done 001_create_events_table
Migrate "002_add_clip_snapshot"
peewee_migrate INFO : Migrate "002_add_clip_snapshot"
add_column ('event', 'has_clip', <BooleanField: Event.has_clip>)
peewee_migrate INFO : add_column ('event', 'has_clip', <BooleanField: Event.has_clip>)
add_column ('event', 'has_snapshot', <BooleanField: Event.has_snapshot>)
peewee_migrate INFO : add_column ('event', 'has_snapshot', <BooleanField: Event.has_snapshot>)
Done 002_add_clip_snapshot
peewee_migrate INFO : Done 002_add_clip_snapshot
frigate.mqtt INFO : MQTT connected
detector.coral INFO : Starting detection process: 44
frigate.app INFO : Camera processor started for axis: 47
frigate.edgetpu INFO : Attempting to load TPU as usb
Process detector:coral:
frigate.edgetpu INFO : No EdgeTPU detected.
frigate.app INFO : Capture process started for axis: 50
File "/usr/local/lib/python3.8/dist-packages/tflite_runtime/interpreter.py", line 152, in load_delegate
delegate = Delegate(library, options)
File "/usr/local/lib/python3.8/dist-packages/tflite_runtime/interpreter.py", line 111, in __init__
raise ValueError(capture.message)
ValueError
File "/usr/lib/python3.8/multiprocessing/process.py", line 315, in _bootstrap
self.run()
File "/usr/lib/python3.8/multiprocessing/process.py", line 108, in run
self._target(*self._args, **self._kwargs)
File "/opt/frigate/frigate/edgetpu.py", line 124, in run_detector
object_detector = LocalObjectDetector(tf_device=tf_device, num_threads=num_threads)
File "/opt/frigate/frigate/edgetpu.py", line 63, in __init__
edge_tpu_delegate = load_delegate('libedgetpu.so.1.0', device_config)
File "/usr/local/lib/python3.8/dist-packages/tflite_runtime/interpreter.py", line 154, in load_delegate
raise ValueError('Failed to load delegate from {}\n{}'.format(
ValueError: Failed to load delegate from libedgetpu.so.1.0
frigate.watchdog INFO : Detection appears to have stopped. Exiting frigate...
frigate.app INFO : Stopping...
frigate.events INFO : Exiting event cleanup...
frigate.events INFO : Exiting event processor...
frigate.record INFO : Exiting recording maintenance...
frigate.object_processing INFO : Exiting object processor...
frigate.watchdog INFO : Exiting watchdog...
My config.yml
is:
mqtt:
host: 192.168.0.3
user: Max
password: pass
cameras:
axis:
ffmpeg:
input_args:
- -c:v
- hevc_cuvid
inputs:
- path: rtsp://root:[email protected]:554/axis-media/media.amp?streamprofile=frigate
roles:
- detect
width: 1280
height: 720
fps: 10
objects:
track:
- person
- car
- truck
If I omit using - -c:v
I get:
frigate.video INFO : axis: ffmpeg sent a broken frame. memoryview assignment: lvalue and rvalue have different structures
frigate.video INFO : axis: ffmpeg process is not running. exiting capture thread...
ffmpeg.axis.detect ERROR : [NULL @ 0x561dae6deb80] Unable to find a suitable output format for 'hevc_cuvid'
ffmpeg.axis.detect ERROR : hevc_cuvid: Invalid argument
ffmpeg.axis.detect ERROR : [NULL @ 0x558f285c7b80] Unable to find a suitable output format for 'hevc_cuvid'
ffmpeg.axis.detect ERROR : [NULL @ 0x560bd81870c0] Unable to find a suitable output format for 'hevc_cuvid'
ffmpeg.axis.detect ERROR : [NULL @ 0x562bda0efb80] Unable to find a suitable output format for 'hevc_cuvid'
While my ffmpeg -decoders | grep cuvid
returns:
ffmpeg version 4.2.4-1ubuntu0.1 Copyright (c) 2000-2020 the FFmpeg developers
built with gcc 9 (Ubuntu 9.3.0-10ubuntu2)
configuration: --prefix=/usr --extra-version=1ubuntu0.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-nvenc --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
libavutil 56. 31.100 / 56. 31.100
libavcodec 58. 54.100 / 58. 54.100
libavformat 58. 29.100 / 58. 29.100
libavdevice 58. 8.100 / 58. 8.100
libavfilter 7. 57.100 / 7. 57.100
libavresample 4. 0. 0 / 4. 0. 0
libswscale 5. 5.100 / 5. 5.100
libswresample 3. 5.100 / 3. 5.100
libpostproc 55. 5.100 / 55. 5.100
V..... h264_cuvid Nvidia CUVID H264 decoder (codec h264)
V..... hevc_cuvid Nvidia CUVID HEVC decoder (codec hevc)
V..... mjpeg_cuvid Nvidia CUVID MJPEG decoder (codec mjpeg)
V..... mpeg1_cuvid Nvidia CUVID MPEG1VIDEO decoder (codec mpeg1video)
V..... mpeg2_cuvid Nvidia CUVID MPEG2VIDEO decoder (codec mpeg2video)
V..... mpeg4_cuvid Nvidia CUVID MPEG4 decoder (codec mpeg4)
V..... vc1_cuvid Nvidia CUVID VC1 decoder (codec vc1)
V..... vp8_cuvid Nvidia CUVID VP8 decoder (codec vp8)
V..... vp9_cuvid Nvidia CUVID VP9 decoder (codec vp9)
Hi, this is now a very long thread, so pardon if question has been already made.
Which hardware should I buy to connect to a NUC in order to detect person in a room (ideally I need this for 3 cameras in 3 rooms)?
can you share your code for this? currently, i’m using just a static button that has the option to mute for X minutes, but it’d be cool to make it configurable!
I don’t think your question has to do with the topic of this thread but here goes: Create a timer and add a condition to your automation to not send a notification when the timer is still running — unless you want more logic to apply this constraints on an individual basis. Start the timer in the same automation after sending the notification.
Did anybody manage to run Frigate with Nvidia GPU acceleration?
i would recomend intel i7 any NUC with price 450usd+
if used as VM,then GPU passthrough is neccesary
just integrated GPU passthrough, through proxmox. Works perfectly
I got my GPU available from within ‘frigate container’, no need to passthrough. Is there possibility to utilize Nvidia GPU for object detection / video decoding in Frigate?
How to realize?
Trying to get starting with Frigate under HassOS (VM)… frigate.yml as follows:
mqtt:
host: 192.168.20.4
user: xxxx
password: xxxxx
cameras:
nw_eaves:
ffmpeg:
inputs:
- path: rtsp://192.168.20.2:7447/xxxxxxxxx_x
roles:
- detect
- rtmp
width: 1920
height: 1080
fps: 15
However, on startup I get this in the logs:
...done.
Starting migrations
There is nothing to migrate
peewee_migrate INFO : There is nothing to migrate
detector.coral INFO : Starting detection process: 30
frigate.app INFO : Camera processor started for back: 32
frigate.app INFO : Capture process started for back: 34
ValueError
self.run()
frigate.stats INFO : Exiting watchdog...
peewee.sqliteq INFO : writer received shutdown request, exiting.
root INFO : Waiting for detection process to exit gracefully...
/usr/lib/python3.8/multiprocessing/resource_tracker.py:216: UserWarning: resource_tracker: There appear to be 109 leaked shared_memory objects to clean up at shutdown
warnings.warn('resource_tracker: There appear to be %d '
I’m running HassOS in a Virtualbox VM under Ubuntu Mate 20.04.2 on a repurposed desktop (i5-7500, 16GB RAM). Any thoughts?
you must define detector as mentioned in docs:
I cant figure out what process fps means, can someone explain? Usually 0 is displayed for my cameras, but sometimes a specific camera shows fps.
I figured it out, so I answer my own question. It will show process fps when detection is enabled.
Perfect… sorted!
Added the hwaccel_args
options for my CPU:
cameras:
back:
ffmpeg:
hwaccel_args:
- -hwaccel
- vaapi
- -hwaccel_device
- /dev/dri/renderD128
- -hwaccel_output_format
- yuv420p
inputs:
- path: rtsp://192.168.20.2:7447/xxxx_x
roles:
- detect
- rtmp
width: 1920
height: 1080
fps: 15
…and broke it again:
frigate.video INFO : back: ffmpeg sent a broken frame. memoryview assignment: lvalue and rvalue have different structures
frigate.video INFO : back: ffmpeg process is not running. exiting capture thread...
ffmpeg.back.detect ERROR : [AVHWDeviceContext @ 0x55ab0c2f5d80] No VA display found for device /dev/dri/renderD128.
ffmpeg.back.detect ERROR : Device creation failed: -22.
ffmpeg.back.detect ERROR : [h264 @ 0x55ab0c12cf80] No device available for decoder: device type vaapi needed for codec h264.
ffmpeg.back.detect ERROR : Device setup failed for decoder on input stream #0:1 : Invalid argument
Sorry for the neediness!
