Frigate working fine in a docker on my Dell R710, thank you very much but unfortunately that thing eats electric!
So I have tried the exact same set up on a older smaller pc to run 24/7, a HP Proliant nl36.
but I am having a major issue!
AMD Athlon™ II Neo N36L Dual-Core @ 1300 MHz
Unraid set up
Home Assistant VM
Trying either Docker or Home Assistant addon, I am getting the message below,
The NL36 is old and I found this thread that I ‘think’ is related but could do with some help please
Fatal Python error: Illegal instruction · Issue #695 · blakeblackshear/frigate · GitHub but I don’t think its been implemented in frigate yet, if it is this issue, anyway round it please?
I do have a PCI and also a USB coral plugged in and i have tried setting detectors as coral, PCI and USB
I have also tried removing the hardware config input arguments.
Any suggestions appreciated please?
* Starting nginx nginx
...done.
Current thread 0x00007f11fdbc6740 (most recent call first):
File "<frozen importlib._bootstrap>", line 219 in _call_with_frames_removed
File "<frozen importlib._bootstrap_external>", line 1101 in create_module
File "<frozen importlib._bootstrap>", line 556 in module_from_spec
File "<frozen importlib._bootstrap>", line 657 in _load_unlocked
File "<frozen importlib._bootstrap>", line 975 in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 991 in _find_and_load
File "<frozen importlib._bootstrap>", line 1042 in _handle_fromlist
File "/usr/local/lib/python3.8/dist-packages/tflite_runtime/interpreter.py", line 36 in <module>
File "<frozen importlib._bootstrap_external>", line 783 in exec_module
File "<frozen importlib._bootstrap>", line 671 in _load_unlocked
File "/opt/frigate/frigate/edgetpu.py", line 15 in <module>
File "/opt/frigate/frigate/app.py", line 19 in <module>
File "/opt/frigate/frigate/__main__.py", line 7 in <module>
File "/usr/lib/python3.8/runpy.py", line 87 in _run_code
File "/usr/lib/python3.8/runpy.py", line 194 in _run_module_as_main
