Not sure what you mean protection mode? Are you talking about privileged mode?
Not by default, try removing -an from your output args. If that doesn’t work, replace -an with -codec:a aac
The latter worked in my case.
Thank you “-codec:a aac” worked a treat
Hi there,
Other people seem to have got this to work on older CPUs: https://github.com/blakeblackshear/frigate-hass-addons/pull/12
So it should be possible to get Frigate working without swapping hardware.
Where do you put the output_args?
All I get is:
* Starting nginx nginx
...done.
Error parsing config: expected a dictionary for dictionary value @ data['ffmpeg']['output_args']
You can place under an individual camera, but I wanted all cameras, so put it here:
ffmpeg:
hwaccel_args:
- -hwaccel
- vaapi
- -hwaccel_device
- /dev/dri/renderD128
output_args:
clips: -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c copy -codec:a aac
So simple… Thanks!
You could possibly achieve that with best_image_timeout. So something like:
Nextone:
ffmpeg:
inputs:
- path: rtsp://xxx:[email protected]:2554/axis-media/media.amp
roles:
- detect
width: 1920
height: 1080
fps: 5
best_image_timeout: 5
The default value is 60.
The easiest way to keep all images is to assign a clips role to the camera, unless your use case prevents that.
Did you solve this?
Did you got it working?
Nope, unfortunately not.
Hi
Firstly thank you! Frigate is awesome and i can’t wait to see what it becomes with Further development. I’m looking at Migrating away from BlueIris because of the great homeassistant integration.
I’m just struggling with one issue.
I want to use my sub-stream for 24/7 recording and my Main stream for recording clips which works great. However when i click on the feed in HomeAssistant I’d also like to see the main stream and not the low res sub-stream. Is there a way to do this?
My config looks like this
cameras:
frontyard:
ffmpeg:
inputs:
- path: rtsp://admin:@[email protected]:554//h264Preview_01_sub
roles:
- detect
- record
- path: rtsp://admin:@[email protected]:554//h265Preview_01_main
roles:
- clips
- rtmp
Thanks again!
Good day gents,
anyone can suggest recommended ffmpeg settings to improve the latency with homeassistant?
basically I get a presence notification/picture about 10 seconds before I can see the object in the homeassistant camera view.
Thank you
Hi all,
I have a question about Frigate on a Odroid N2+ with a Coral USB TPU
My CPU load is relative high :
I can even reach 90 ~ 95%
My suspicion is that the ordoid N2+ does not do ffmpeg on hardware causing this? Is that true and can I do something about this?
One other thing, object recognition is awesome! But only with daylight, when it’s getting dark it is not working anymore, 2 camera are Ubiquiti G3 and G3 flex, I also have a EZViz C3W, but that doesn’t work either… it works better with Unifi Protect, but I want HA to detect
It’s complicated but there’s also this (still need to try the latter myself).
Hi all, fairly new frigate user here! First of all thanks for the awesome project! Unfortunately I have some troubles setting it up properly. Setup is working fine, I have / had it running as a hassio addon and in a separate docker container (Raspberry Pi and Macbook), but I can’t seem to get a stable stream to detect objects / view my camera images. I read a lot of posts and guides but none seem to answer my specific question.
- Camera: Reolink E1 Pro (it has an rtsp stream, but apparently no rtmp, as far as I can tell).
- Hardware: Raspberry Pi 3b - Docker Version or Macbook Pro (late 2013). Both not the most powerful HW
First problem: I cannot get an stable substream to detect object. It is either all green screen (while using some input_arguments) or it is flickering / has artefacts. Stream size is 640x360px, 7fps, 192kbit/s
Seconds Problem: Using the main stream to detect images, I think both of my hardware options are not powerful enough. Frigate only works with 0,2 to 1,3 fps (displayed in frontend).
What are my options here? Is this only a hardware problem and more powerful hardware, e.g. Raspberry Pi 4 and Coral TPU will solve this? Or is this related to the Camera Hardware (esp. the Substream Problem), or do I need to tune the ffmpeg stream with input_arguments?
so lowering the timeout for best_image produces more images… Will try that tomorrow and report back.
Regarding your suggestion about the “clips”: I have multiple cameras, some show areas with heavy pedestrian trafic. If I am forced to watch all clips (not really happy with the post_capture und pre_capture), the evaluation of all cameras takes up way more time! Checking all pictures is way faster. But thanks for the tip!
As i said, be back tomorrow with more about best_image_timeout…
Thank you.
Cheers
Chris
Interesting, that makes sense. I’m not 100% certain that reducing the best_image timeout will work. I just checked the documentation and it says the following:
# Optional: timeout for highest scoring image before allowing it
# to be replaced by a newer image. (default: shown below)
best_image_timeout: 60
Another thing to play with could be max_disappeared in the detector settings:
# Optional: Number of frames without a detection before frigate considers an object to be gone. (default: 5x the frame rate)
max_disappeared: 25
Lowering it drastically would perhaps create a lot of unique events and snapshots per target as Frigate bounces above and below the detection threshold - which itself could be adjusted to achieve the desired effect.
I’ve just been playing with Node-RED as another possible solution, and it did indeed save several snapshots when I walked around in front of the camera. Not sure how elegant this solution is as I’ve never really used Node-RED, but I’d expect it to save loads of snapshots in a high traffic area.
thank you very much for your response.
Im trying the the FFMPEG cameras with the Live555 RTSP proxy and testing
for webrtx i just cant get the card to work. keeps saying “Custom element doesn’t exist: webrtc-camera”
I’m running frigate on a dedicate docker container,
I’m wondering if it could be possible to display MQTT frigate/stats as entities card
anyone already explored it?
Regards
Dario
