OK!
I installed Frigate on a Dell Optiplex 9020m with a Coral A+E M2 card in the wifi slot,
as @tinglis1 said he had tried. The Dell is running Linux Mint 20.1 sfce and Frigate is running in Docker.
I connected 1 RSTP camera (Foscam FI9804W) to frigate. The camera is also still connected to MotionEye running on Home Assistant on a “Blue”. Frigate is connected to a 320x280 stream and MotionEye is connected to a 1280x720 stream. Disabling the MotionEye stream doesn’t seem to help.
On the Dell, I can open the Frigate web interface. Sometimes it will display the image from the camera, sometimes not. This could be because the camera is still feeding images to Motioneys (?)
Since the Home Assistant Custom repository instructions on youtube didn’t work (“Invalid Add-on repository!”), I installed HACS and installed Frigate from there.
From Configuration->Integrations, I added Frigate.
There is no “configure” button in the integrations window for Frigate.
In the “three dots” menu, there is a “System Options” selection. This gives me a popup to enable automate adding of new entities. I enabled it.
media_source is enabled.
The Installation page in the documentation says to
Create the file frigate.yml in your config directory with your detailed Frigate configuration
Should this be the same configuration file on the Frigate install on Docker?
There is no entry in Supervisor->Dashboard->Installed add-ons.
A Frigate entry appeared in the Media Browser. Frigate->Clips produces a Media Browsing Error “Unknown error”.
There is no entry in the sidebar for Frigate.
The log summary shows:
Error fetching frigate data:
1:28:05 PM – (ERROR) Frigate (custom integration) - message first occurred at 12:10:51 PM and shows up 62 times
Error fetching information from http://192.168.1.229:5000/api/stats - 502, message='Bad Gateway', url=URL('http://192.168.1.229:5000/api/stats')
Config entry 'Frigate' for frigate integration not ready yet: None; Retrying in background
12:10:51 PM – (WARNING) config_entries.py - message first occurred at 12:10:51 PM and shows up 2 times
I must have missed something…
Any Idea what?
Thanks,
-Mike
