In what kind of environment did you set up authelia? On top of hassos?
I am running everything on Unraid. HA is running as HAOS in a VM. Frigate, Authelia and Nginx in docker containers.
Iâm going to have to a look into this for my stack, I like the fact it works with k8s and has ldap support
Ibracorp has a few great videos on youtube about setting up Authelia and nginx.
Reverse proxy? Iâm using the Full Access Frigate add-on. Am I missing a piece that is required?
Hi all,
after many months that frigate was working excellent with 3 ezviz ip cam on a U55 Beelink with coral TPU itâs since 2 weeks that during night vision it doesnât record anymore everytime person and dog clips on movements⊠During the day everything seems very good, but with night vision it misses many clips.
I cleaned the cams tooâŠ
Any ideas? Suggestions?
Try debug view, go outside and look if it detect movement
I have too many false positives with trees, trash cans detected as Person. Any way to improve detection accuracy (especially at night time with IR lighting)?
I read about custom models, but couldnât find any manual on how to train them & apply in Frigate.
Hi when i use your config i getting following error:
2 validation errors for FrigateConfig
cameras -> Eingang2 -> ffmpeg -> output_args -> clips
extra fields not permitted (type=value_error.extra)
cameras -> Eingang2 -> clips
The config not accept the clips Argument
My config:
cameras:
Eingang2:
ffmpeg:
inputs:
- path: rtsp://admin:[email protected]:554/
roles:
- clips
- detect
global_args: -hide_banner -loglevel info
output_args:
record: -f segment -segment_time 60 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c copy #removed -an parameter to enable audio
clips: -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c copy #removed -an parameter to enable audio
clips:
enabled: True
pre_capture: 5
post_capture: 5
rtmp:
enabled: True
Hi Chris,
that config was for old version, you need to adjust it for the new version, there were many breaking changes.
This is my latest config:
mqtt:
host: REDACTED
user: REDACTED
password: REDACTED
topic_prefix: frigate
#database:
#path: /frigate.db
#https://blakeblackshear.github.io/frigate/configuration/advanced#logger
#logger:
#default: debug #info
detectors:
coral:
type: edgetpu
device: usb
detect:
width: 640
height: 360
fps: 7
objects:
track:
- person
- car
filters:
person:
# Optional: minimum width*height of the bounding box for the detected object (default: 0)
min_area: 8000
# Optional: maximum width*height of the bounding box for the detected object (default: 24000000)
#max_area: 100000
# Optional: minimum score for the object to initiate tracking (default: 0.5)
#min_score: 0.5
# Optional: minimum decimal percentage for tracked object's computed score to be considered a true positive (default: 0.7)
#threshold: 0.7
car:
min_area: 5000
record:
enabled: True
retain_days: 0
events:
max_seconds: 300
pre_capture: 10
post_capture: 10
retain:
default: 14
snapshots:
enabled: True
timestamp: True
bounding_box: True
crop: True
retain:
default: 30
rtmp:
enabled: True
birdseye:
enabled: True
width: 1024 #1280
height: 576 #720
quality: 8
mode: objects #continuous #objects #motion
timestamp_style:
format: "%m.%d.%Y %H:%M:%S"
ffmpeg:
global_args: -hide_banner -loglevel warning #panic #info
hwaccel_args:
-hwaccel qsv -qsv_device /dev/dri/renderD128
#input_args: #https://ffmpeg.org/ffmpeg-formats.html
#-avoid_negative_ts make_zero -fflags +genpts+discardcorrupt -rtsp_transport tcp -stimeout 5000000 -use_wallclock_as_timestamps 1
output_args:
#detect: -f rawvideo -pix_fmt yuv420p
record: -f segment -segment_time 60 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c copy #-an removed to hear sound
#rtmp: -c copy -f flv
cameras:
pred_domom: #REOLINK RLC-810A firmware IPC_523128M8MP.236_21040831.RLC-810A.IMX415.8MP.REOLINK
ffmpeg:
inputs:
- path: rtsp://<UserName>:<Password>@<IpAddress>:554//h264Preview_01_sub
roles:
- detect
- rtmp
roles:
- record
motion:
mask:
- 434,34,640,34,640,0,436,0
- 640,271,640,0,224,0
objects:
mask:
filters:
car:
mask:
- 0,360,332,360,202,132,0,128
person:
mask:
- 158,360,640,360,640,0,64,0
zones:
PredDomom_PriPrednychOknach:
coordinates: 0,360,80,360,57,115,0,121
Ok config now valid thx. But I getting the error ffmpeg sent a broken frame. memoryview assignment: lvalue and rvalue have different structures. I upgraded the software as sensed from support and changed the settings as u described.
well, there is no motion detected unless i donât switch on my phone flashlightâŠ
this is the nightly vision:
my question is why until some weeks ago it worked? maybe summer time (?)
this is part of my config:
detectors:
coral:
type: edgetpu
device: usb
objects:
track:
- person
- dog
- car
record:
enabled: true
retain_days: 0
events:
max_seconds: 300
pre_capture: 5
post_capture: 5
retain:
default: 7
objects:
person: 14
snapshots:
enabled: true
timestamp: False
bounding_box: true
crop: true
height: 175
required_zones: []
retain:
default: 7
objects:
person: 14
rtmp:
enabled: True
live:
height: 720
quality: 8
cameras:
Fontanella:
ffmpeg:
inputs:
- path: rtsp://xxxxx@<myip>/h264_stream
roles:
- detect
- rtmp
- record
motion:
mask:
- 1085,339,1280,542,1280,0,982,0,659,0,887,176
- 235,710,355,710,355,686,235,686
zones:
balcony:
coordinates: 0,1080,546,1080,433,828,358,628,329,610,249,334,207,338,0,380
garder:
coordinates: 260,321,258,0,1029,0,1322,211,1604,442,1920,748,1920,1080,591,1080
the camera is a EZVIZ C3WN 1080p.
Thanks!
Hi Chris,
I got them from ffmepg too but only after start. Then they doesnât appear anymore and all works properly. I didnât get a chance to paste them here if the community knows what to reconfigure or open an issue on github to get help from developers. But you can try
After changing some motion parameters (by chance) Iâm having motion detection, but not person detectedâŠ
Fontanella:
ffmpeg:
inputs:
- path: <PATH>
roles:
- detect
- rtmp
- record
motion:
threshold: 13
contour_area: 50
delta_alpha: 0.5
frame_alpha: 0.2
frame_height: 180
mask:
I still donât know what you mean by reverse proxy, as I use no proxy locally.
In case anyone else is having the same issue. Turned out the cameras needed to be changed from Variable Bit Rate to Constant Bit Rate.
Just to reiterate, the issue: lovelace video feeds were not visible on Fire HD 10 v7 tablets using the Frigate integration and Frigate Lovelace Card. Feeds were visible on Apple devices. Must have been a change with HA Core 2021.11.
Hi Everyone,
Not sure if itâs the right place to open a new âthreadâ but I wanted to ask about âentered_zonesâ.
I tried using Zones to avoid alerts/events on stationary objects (cars) but nothing seems to solve this issue. I was thinking that âentered_sonzesâ might be the solution (if it is in fact another parameter that could be defined). If I can send an alert only if the car enters my driveway from one zone and then pass through the second one, only then it would alert that there is a car there. is it possible? ârequired_zonesâ is an âORâ not âANDâ as far as I know, so I get events no matter what
Can you help me, how to configure the Tapo c200 into frigate, and HA? Which components need to be configured? (ffmpeg, stream, frigate.yml, which lovlece cardâŠ) Thank you
hello, you install the frigate addon and make a frigate.yml
configuration file.
mine looks like:
host: 192.168.1.41
port: 1883
client_id: frigate
user: hass
password: hass
stats_interval: 60
detectors:
coral:
type: edgetpu
device: pci
logger:
default: info
logs:
frigate.event: debug
birdseye:
enabled: True
width: 1280
height: 720
quality: 8
mode: continuous
ffmpeg:
global_args:
- -hide_banner
- -loglevel
- warning
# input_args:
# - -avoid_negative_ts
# - make_zero
# - -fflags
# - +genpts+discardcorrupt
# - -rtsp_transport
# - tcp
# - -stimeout
# - '5000000'
# - -use_wallclock_as_timestamps
# - '1'
hwaccel_args:
- -hwaccel
- vaapi
- -hwaccel_device
- /dev/dri/renderD128
- -hwaccel_output_format
- yuv420p
detect:
width: 1280
height: 720
fps: 5
enabled: False
max_disappeared: 5
objects:
track:
- person
motion:
threshold: 25
contour_area: 100
delta_alpha: 0.2
frame_alpha: 0.2
frame_height: 180
record:
enabled: True
retain_days: 3
events:
max_seconds: 300
pre_capture: 5
post_capture: 5
objects:
- person
required_zones: []
retain:
default: 10
objects:
person: 15
snapshots:
enabled: True
timestamp: True
bounding_box: True
crop: True
height: 175
required_zones: []
retain:
default: 10
objects:
person: 15
rtmp:
enabled: True
live:
height: 720
quality: 8
timestamp_style:
position: "tl"
format: "%d.%m.%Y %H:%M:%S"
color:
red: 255
green: 255
blue: 255
thickness: 2
effect: shadow
cameras:
front_door:
ffmpeg:
inputs:
- path: rtsp://hass:[email protected]:88/videoMain
roles:
- detect
- rtmp
- record
best_image_timeout: 60
mqtt:
enabled: True
timestamp: True
bounding_box: True
crop: True
height: 270
quality: 70
required_zones: []
garden_upstairs:
ffmpeg:
inputs:
- path: rtsp://hassio:[email protected]:554/stream1
roles:
- detect
- rtmp
- record
mqtt:
enabled: True
timestamp: True
bounding_box: True
crop: True
height: 270
quality: 70
required_zones: []
garage:
ffmpeg:
inputs:
- path: rtsp://40.40.40.220:554/media/stream1
roles:
- detect
- rtmp
- record
mqtt:
enabled: True
timestamp: True
bounding_box: True
crop: True
height: 270
quality: 70
required_zones: []
garden:
ffmpeg:
inputs:
- path: rtsp://40.40.40.14:554/media/stream1
roles:
- detect
- rtmp
- record
mqtt:
enabled: True
timestamp: True
bounding_box: True
crop: True
height: 270
quality: 70
required_zones: []
My tapo cam is the garden cam configured. No wirries privacy interested peoples. My cams have NO access to internet trying to hack them⊠good luck
well then i have Dwain*s dashboard installed
and I created my more_page addon which lookslike:
## Created by Thorsten Fröhlich
## More-page add-on: Camera
## Version: 1.0.0
- type: custom:swipe-card
card_width: "1160px"
parameters:
effect: "coverflow"
grabCursor: true
centeredSlides: true
slidesPerView: "auto"
coverflowEffect:
rotate: 50
stretch: 0
depth: 100
modifier: 1
slideShadows: true
pagination:
type: "bullets"
cards:
# - type: custom:frigate-card
# menu:
# buttons:
# image: false
# frigate: false
# live: false
# clips: false
# snapshots: false
# download: false
# fullscreen: false
# frigate_ui: false
# live:
# provider: frigate-jsmpeg
# preload: true
# frigate:
# camera_name: birdseye
# view:
# default: live
camera_entity: camera.front_door
live:
provider: frigate
preload: true
elements:
- type: state-badge
entity: sensor.dark_sky_humidity
style:
right: '40px'
top: 86px
color: rgba(0,0,0,0)
opacity: 0.7
- type: state-badge
entity: sensor.solar_powered_outdoor_siren_air_temperature
style:
right: '-20px'
top: 110px
opacity: 0.7
- type: custom:frigate-card-menu-state-icon
entity: lock.main_door
tap_action:
action: toggle
entity: script.restart_foscam
tap_action:
action: toggle
entity: script.preset_garage
tap_action:
action: toggle
entity: script.preset_street
tap_action:
action: toggle
entity: script.preset_maindoor
tap_action:
action: toggle
- type: custom:frigate-card-conditional
conditions:
view:
- live
elements:
# - type: custom:frigate-card-menu-icon
# icon: mdi:butterfly
# tap_action:
# action: custom:frigate-card-action
# frigate_card_action: image
- type: icon
icon: mdi:arrow-up
style:
background: rgba(10, 10, 10, 0.75)
border-radius: 5px
right: 150px
bottom: 250px
transform: scale(3, 3)
tap_action:
action: call-service
service: script.turn_on
service_data:
entity_id: script.turn_up
- type: icon
icon: mdi:arrow-down
style:
border-radius: 5px
right: 150px
bottom: 125px
tap_action:
service_data:
entity_id: script.turn_down
- type: icon
icon: mdi:arrow-left
style:
border-radius: 5px
right: 225px
bottom: 185px
tap_action:
service_data:
entity_id: script.turn_left
- type: icon
icon: mdi:arrow-right
style:
border-radius: 5px
right: 75px
bottom: 185px
tap_action:
service_data:
entity_id: script.turn_right
- type: icon
icon: mdi:magnify-plus
style:
border-radius: 5px
right: 75px
bottom: 450px
tap_action:
service_data:
entity_id: script.zoom_in
- type: icon
icon: mdi:magnify-minus
style:
border-radius: 5px
right: 75px
bottom: 350px
tap_action:
service_data:
entity_id: script.zoom_out
image:
src: /local/incognito.jpg
view:
default: live
timeout: '60'
menu:
buttons:
image: true
mode: overlay-bottom
button_size: 80px
event_viewer:
autoplay_clip: true
controls:
next_previous:
style: chevrons
dimensions:
aspect_ratio_mode: dynamic
## END ##
camera_entity: camera.garden
dimensions:
aspect_ratio_mode: unconstrained
aspect_ratio: "16:9"
elements:
entity: light.porch_garden
icon: mdi:track-light
tap_action:
action: toggle
menu:
buttons:
download: true
image: false
frigate_ui: false
button_size: 80px
view:
default: live
timeout: "15"
live:
preload: true
provider: frigate
webrtc:
event_viewer:
autoplay_clip: true
controls:
next_previous:
style: thumbnails
frigate:
url: 192.168.1.41
camera_name: garden
camera_entity: camera.garden_upstairs_2
dimensions:
view:
default: live
timeout: "15"
live:
preload: true
provider: frigate
webrtc:
event_viewer:
autoplay_clip: true
controls:
next_previous:
style: thumbnails
menu:
button_size: 80px
# webrtc: {}
camera_entity: camera.garage
dimensions:
elements:
entity: light.garage
tap_action:
action: toggle
view:
default: live
timeout: "15"
live:
preload: true
provider: frigate
webrtc:
event_viewer:
autoplay_clip: true
controls:
next_previous:
style: thumbnails
menu:
button_size: 80px
# camera_entity: camera.front_door_24h
# camera_entity: camera.garden_24h
# camera_entity: camera.garage_24h
# camera_entity: camera.porch_24h
Well but therefor u need a lot of stuff. but it can look something like
it is a swipe card with frigate lovelace card inside
well but in this ard is more than this I would recommend to start installing and configuring frigate via addon.
Huhh quite complex configuration. Try to understand. Thank you
my Tapo use different address
rtsp://x.y.z.y:554/stream1
no media folderâŠ
