There were no changes to the way object detection is done in 0.12, unless you changed your config to use one of the new detector types. So most likely this is unrelated to the update or there is some other issue. More info, config, screenshots, etc. would be helpful to see
Hi, I have 2 cameras that are properly working. Both of them have the VIDEOMAIN for RECORDING and VIDEOSUB for DETECTION
See the config
cameras:
camera1:
enabled: True
ffmpeg:
inputs:
- path: rtsp://user::password@IPAddress1:88/videoMain
hwaccel_args: preset-rpi-64-h264
#input_args: preset-rtsp-generic
input_args: preset-rtsp-restream
roles:
- record
- path: rtsp://user::password@IPAddress1:88/videoSub
roles:
- detect
output_args:
record: preset-record-generic
detect:
enabled: True
width: 1280
height: 720
fps: 5
record:
enabled: True
retain:
days: 7
mode: motion
events:
pre_capture: 15
post_capture: 15
retain:
default: 5
mode: active_objects
objects:
person: 5
objects:
- person
snapshots:
enabled: True
timestamp: True
bounding_box: True
retain:
default: 5
objects:
person: 5
camera2:
enabled: True
ffmpeg:
inputs:
- path: rtsp://user::password@IPAddress2:88/videoMain
roles:
- record
- path: rtsp://user:password@IPAddress2:88/videoSub
roles:
- detect
output_args:
detect:
enabled: True
width: 640
height: 360
fps: 5
record:
enabled: True
retain:
days: 7
mode: motion
events:
pre_capture: 15
post_capture: 15
retain:
default: 5
objects:
person: 5
objects:
- person
snapshots:
enabled: True
timestamp: True
bounding_box: True
retain:
default: 5
objects:
person: 5
rtmp:
enabled: False
now I would like to switch to the go2rtc, but I donāt understand how to properly match the stream.
if I add a single entry it works
go2rtc:
streams:
camera1:
- rtsp://user:password@camera1:88/videoMain
but how I can add the videosub? and how I can add the camera2?
this is wrong because as far I understood the name must be unique
`go2rtc:
streams:
camera1:
- rtsp://user:password@IPAddress1:88/videoSub
camera1:
- rtsp://user:password@IPAddress1:88/videoMain
do I have to define different cameras? and arrange to split the detect and record across the main and the sub definition?
eg:
cameres:
camera1_main:
roles:
- record
camera1_sub:
roles:
- detect
camera2_main:
roles:
- record
camera2_sub:
roles:
- detect
If sub is detection only you do not need to add to go2rtc. Just keep under ffmpeg with detect role as you currently have.
thank yoy, i got it
i have another question, i see only the jsmepg option, what i need to do to add go2rtc or mse?
@crzynik , I think that I have it
`go2rtc:
streams:
camera1_main:
- rtsp://user:[email protected]:88/videoMain
camera1_sub:
- rtsp://user:[email protected]:88/videoSub
camera2_main:
camera2_sub:
webrtc:
candidates:
- X.X.X.X:8555
- stun:8555
rtmp:
enabled: False`
this is the go2trc dashboard
if I click on the stream I see RTC
but in the frigate page I see only jsmpeg
this is the go2rtc config
api:
origin: '*'
log:
format: text
rtsp:
default_query: mp4
Iām missing something?
do you have any suggestions on my config?
the name of the go2rtc streams donāt match the name of the camera
OMG OMG , thank you so much @crzynik I didnāt really go it since you said it
I guess I should go for something like this, right?
As I have MAIN and SUB streams with different roles, I should also create different cameras
cameras:
camera1_main:
enabled: True
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/camera1_main
roles:
- record
record:
enabled: True
retain:
days: 7
mode: motion
events:
pre_capture: 15
post_capture: 15
retain:
default: 5
objects:
person: 5
objects:
- person
snapshots:
enabled: True
timestamp: True
bounding_box: True
retain:
default: 5
objects:
person: 5
birdseye:
enabled: True
restream: False
camera1_sub:
enabled: True
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/camera1_sub
roles:
- detect
output_args:
detect:
enabled: True
width: 1280
height: 720
fps: 5
I found the answer here use both primary stream and substream with go2rtc? Ā· blakeblackshear/frigate Ā· Discussion #5947 (github.com), it seem more easy
I see there is an option in the Frigate card to hide the camera from UI. Is there an option to hide the camera from UI based on sensor/switch state? I have three indoor cameras that only turn on when the house is in Away/Night mode. Currently these cameras take up space when scrolling through the frigate card when Iām at home and it would be great if they disappeared from the UI during these times. Iām hoping Iām just missing something here, but I havenāt had any luck when searching. TIA.
Can you please show me the whole config within the yaml for the doorbird? Thanks!!
I see this message in the log every 10 sec
2023-09-16 06:53:53.451374237 [2023-09-16 06:53:53] watchdog.camera1 ERROR : No new recording segments were created for camera1 in the last 120s. restarting the ffmpeg record processā¦
2023-09-16 06:53:53.451498541 [2023-09-16 06:53:53] watchdog.camera1 INFO : Terminating the existing ffmpeg processā¦
2023-09-16 06:53:53.451591478 [2023-09-16 06:53:53] watchdog.camera1 INFO : Waiting for ffmpeg to exit gracefullyā¦
I made any mistakes in the config?
can you check my config
detectors:
coral:
type: edgetpu
device: usbgo2rtc:
streams:
camera1:
- rtsp://user:[email protected]:88/videoMainwebrtc:
candidates:
- 1.1.1.12:8555
- stun:8555rtmp:
enabled: Falsebirdseye:
enabled: True
mode: continuous
#restream: Trueobjects:
track:
- person
- car
- bicycle
- motorcycle
- bird
- cat
- dog
ffmpeg:
hwaccel_args: preset-intel-qsv-h264cameras:
camera1:
enabled: Trueffmpeg:
inputs:
#hwaccel_args: preset-intel-qsv-h264
#hwaccel_args: preset-rpi-64-h264
roles:
- record- path: rtsp://user:[email protected]:88/videoSub #hwaccel_args: preset-rpi-64-h264 #input_args: preset-rtsp-generic input_args: preset-rtsp-restream roles: - detect output_args: record: preset-record-generic
record:
enabled: True
retain:
days: 7
mode: motion
events:
pre_capture: 15
post_capture: 15
retain:
default: 5
objects:
person: 5
objects:
- personsnapshots:
enabled: True
timestamp: True
bounding_box: True
retain:
default: 5
objects:
person: 5detect:
enabled: True
width: 1280
height: 720
fps: 5
here my camera settings
VLC stream
Thank you the community support i got my errror, i was referring to the wrong camera name
Hi everyone,
I am trying to get Frigate up and running and got stuck with errors. The log is:
2023-10-04 11:00:25.252235006 [2023-10-04 13:00:25] watchdog.Eingang ERROR : Ffmpeg process crashed unexpectedly for Eingang.
2023-10-04 11:00:25.257906533 [2023-10-04 13:00:25] watchdog.Eingang ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-10-04 11:00:25.258024327 [2023-10-04 13:00:25] ffmpeg.Eingang.detect ERROR : [rtsp @ 0x559bf2106c40] method OPTIONS failed: 401 Unauthorized
2023-10-04 11:00:25.258101239 [2023-10-04 13:00:25] ffmpeg.Eingang.detect ERROR : rtsp://*:*@IP:554/cam/realmonitor?channel=1&subtype=1: Server returned 401 Unauthorized (authorization failed)
2023-10-04 11:00:25.262051502 [2023-10-04 13:00:25] watchdog.Eingang ERROR : No new recording segments were created for Eingang in the last 120s. restarting the ffmpeg record process...
2023-10-04 11:00:25.262178804 [2023-10-04 13:00:25] watchdog.Eingang INFO : Terminating the existing ffmpeg process...
2023-10-04 11:00:25.262256908 [2023-10-04 13:00:25] watchdog.Eingang INFO : Waiting for ffmpeg to exit gracefully...
2023-10-04 11:00:25.293230352 [2023-10-04 13:00:25] frigate.video ERROR : Eingang: Unable to read frames from ffmpeg process.
2023-10-04 11:00:25.293416767 [2023-10-04 13:00:25] frigate.video ERROR : Eingang: ffmpeg process is not running. exiting capture thread...
2023-10-04 11:00:35.268555395 [2023-10-04 13:00:35] watchdog.Eingang ERROR : Ffmpeg process crashed unexpectedly for Eingang.
2023-10-04 11:00:35.268750736 [2023-10-04 13:00:35] watchdog.Eingang ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-10-04 11:00:35.269093626 [2023-10-04 13:00:35] ffmpeg.Eingang.detect ERROR : [rtsp @ 0x55d7808ccc40] method OPTIONS failed: 401 Unauthorized
2023-10-04 11:00:35.269340046 [2023-10-04 13:00:35] ffmpeg.Eingang.detect ERROR : rtsp://*:*@IP:554/cam/realmonitor?channel=1&subtype=1: Server returned 401 Unauthorized (authorization failed)
2023-10-04 11:00:35.276318604 [2023-10-04 13:00:35] watchdog.Eingang ERROR : No new recording segments were created for Eingang in the last 120s. restarting the ffmpeg record process...
2023-10-04 11:00:35.276449757 [2023-10-04 13:00:35] watchdog.Eingang INFO : Terminating the existing ffmpeg process...
2023-10-04 11:00:35.276496843 [2023-10-04 13:00:35] watchdog.Eingang INFO : Waiting for ffmpeg to exit gracefully...
2023-10-04 11:00:35.319631440 [2023-10-04 13:00:35] frigate.video ERROR : Eingang: Unable to read frames from ffmpeg process.
2023-10-04 11:00:35.319721573 [2023-10-04 13:00:35] frigate.video ERROR : Eingang: ffmpeg process is not running. exiting capture thread...
The frigate.yaml is:
mqtt:
host: HAOS IP #mqttserver ohne port
user: mqtt #mqttuser
password: PASSWORD #mqttpassword
database:
path: /config/frigate.db
detectors:
coral:
type: edgetpu
device: usb
# cpu1:
# type: cpu
# num_threads: 3
cameras:
Eingang: #Kameraname
ffmpeg:
inputs:
- path: rtsp://USER:PASSWORD@IP:554/cam/realmonitor?channel=1&subtype=0 #RTSP Stream High Res
roles:
- record
- path: rtsp://USER:PASSWORD@IP:554/cam/realmonitor?channel=1&subtype=1 #RTPS Stream Low Res
roles:
- detect
detect:
enable: True
width: 640
height: 480
fps: 5
objects:
track:
- person
- cat
- dog
snapshots:
enabled: True
timestamp: False
bounding_box: True
retain:
default: 30
record:
enabled: True
events:
retain:
default: 14
My camera stream is:
I can view the stream via VLC player withouth any further authentification, so the RTSP link works. I have also disabled any motion detection on the camera.
Does someone has a clue?
the camera might be UDP only, that or the password is being entered incorrectly in frigate (nothing should be url encoded)
Hi, I have had the camera configured in WebRTC with the same link and it is working. Also I veryfied the link (incl. user and password) with VLC which instantly connects.
The camera logs indeed show that the login is blocked, but how can the exact same link connect via VLC and not via frigate?
Limit of number of logged in users?
There is only one user logged in at a time.
I thought I will give it another go, with a bare minimum config.
mqtt:
enabled: False
cameras:
Eingang: # <------ Name the camera
ffmpeg:
inputs:
- path: rtsp://USER:PASSWORD@IP:554/cam/realmonitor?channel=1&subtype=0 # <----- The stream you want to use for detection
roles:
- detect
detect:
enabled: False # <---- disable detection until you have a working camera feed
width: 640 # <---- update for your camera's resolution
height: 480 # <---- update for your camera's resolution
s6-rc: info: service s6rc-fdholder: starting
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service s6rc-fdholder successfully started
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service log-prepare: starting
s6-rc: info: service log-prepare successfully started
s6-rc: info: service nginx-log: starting
s6-rc: info: service go2rtc-log: starting
s6-rc: info: service frigate-log: starting
s6-rc: info: service nginx-log successfully started
s6-rc: info: service go2rtc-log successfully started
s6-rc: info: service go2rtc: starting
s6-rc: info: service frigate-log successfully started
s6-rc: info: service go2rtc successfully started
s6-rc: info: service go2rtc-healthcheck: starting
s6-rc: info: service frigate: starting
s6-rc: info: service go2rtc-healthcheck successfully started
s6-rc: info: service frigate successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service legacy-services: starting
2023-10-04 15:07:29.181820949 [INFO] Preparing go2rtc config...
2023-10-04 15:07:29.182304873 [INFO] Starting Frigate...
2023-10-04 15:07:29.183198890 [INFO] Starting NGINX...
s6-rc: info: service legacy-services successfully started
2023-10-04 15:07:29.219446889 [INFO] Got IP address from supervisor: 192.168.20.10
2023-10-04 15:07:29.252151148 [INFO] Got WebRTC port from supervisor: 8555
2023-10-04 15:07:29.464616081 [INFO] Starting go2rtc...
2023-10-04 15:07:29.550105779 17:07:29.550 INF go2rtc version 1.2.0 linux/amd64
2023-10-04 15:07:29.550318647 17:07:29.550 INF [api] listen addr=:1984
2023-10-04 15:07:29.550497632 17:07:29.550 INF [rtsp] listen addr=:8554
2023-10-04 15:07:29.550645796 17:07:29.550 INF [srtp] listen addr=:8443
2023-10-04 15:07:29.550760151 17:07:29.550 INF [webrtc] listen addr=:8555
2023-10-04 15:07:30.239732211 [2023-10-04 17:07:30] frigate.app INFO : Starting Frigate (0.12.1-367d724)
2023-10-04 15:07:30.249851306 [2023-10-04 17:07:30] frigate.app INFO : Creating directory: /tmp/cache
2023-10-04 15:07:30.250552766 [2023-10-04 17:07:30] peewee_migrate INFO : Starting migrations
2023-10-04 15:07:30.254130669 [2023-10-04 17:07:30] peewee_migrate INFO : There is nothing to migrate
2023-10-04 15:07:30.263742074 [2023-10-04 17:07:30] detector.cpu INFO : Starting detection process: 443
2023-10-04 15:07:30.264079800 [2023-10-04 17:07:30] frigate.app INFO : Output process started: 445
2023-10-04 15:07:30.266067681 [2023-10-04 17:07:30] frigate.detectors WARNING : CPU detectors are not recommended and should only be used for testing or for trial purposes.
2023-10-04 15:07:30.267765004 [2023-10-04 17:07:30] frigate.app INFO : Camera processor started for Eingang: 448
2023-10-04 15:07:30.271605976 [2023-10-04 17:07:30] frigate.app INFO : Capture process started for Eingang: 450
2023-10-04 15:07:39.183326481 [INFO] Starting go2rtc healthcheck service...
Now it is stuck at the go2rtc healthcheck and nothing happens further.
Anyone seen this Frigate behaviour on Firefox 118.01 and recent versions? All the cameras flicker when viewing the cameras page. Itās OK when on Birdseye view. Been doing it for about 6~8 weeks. Doesnāt do it on Chrome or Edge. Frigate 0.12.1-367d724 & go2rtc version 1.8.1
